DarksSky API Key OK but NO devices
rick8245
Post by rick8245 »
I added DarkSky to the Hardware and within 5 or 10 minutes there should be some devices added to the devices tab.
All the info I setup is OK (like API key, Latitude, longitude) but the devices do NOT appear whatever i try.
What is wrong ??
Thanks in advance for your answers
kiddigital
Re: DarksSky API Key OK but NO devices
Post by kiddigital »
Check the logs..
Not sure if Darksky still works as expected.
Otherwise try OpenWeatherMap (free registration for an API key).
rick8245
Post by rick8245 »
Darksy should work while it supports everything and also provided a api key.
The log file says:
2021-03-13 14:26:29.049 Error: Darksky: Error getting http data!.
I also tried OpenWahtermap but here it is the same problem.
As Location i have the latitud and longitude but tried the townname also.
Whatever i try i still also get here the same error
2021-03-13 14:23:46.339 Error: OpenWeatherMap: Error getting http data!
has it something to do with http data while the url is https ??
