ConBee II - Domoticz - Deconz, error: This device don't support action
oeps
Domoticz version: 2022.1
Post by oeps »
Installed yesterday my new ConBee II USB and added the first Zigbee switch to it (Blitzwolf SHP13).
I can switch the outlet from the Phoscon web interface.
Next step was to add Zigbee to Domoticz (2020.2).
Installed Deconz plugin, generated API, added hardware and the SHP13 shows up. Even power figures show up.
The SHP13 was initially added as "Push On" button. I changed that to On/Off.
I can't switch the SHP13 from Domoticz. An error message appears in the log:
2021-02-20 10:19:42.409 Status: User: admin initiated a switch command (1697/BWZ01 - test/Off)
2021-02-20 10:19:42.427 Error: (Deconz 192.168.178.143) This device don't support action
Googled on this error message but no real clues.
The SHP13 appeared as light in Phoscon. I expected that it would appear as switch.
I do not see a way to change that kind of detail in Phoscon. Is it correct that it is added as light?
I must have done something wrong but can't figure out what.
Anyone have a clue?
Thanks!!
Domoticz 2020.2 on a Raspberry Pi
ConBee II firmware 2.09.03 (26660700). Installed in a separate Raspberry Pi
Deconz plugin Domoticz version 1.0.16
Domoticz RPI 2022.1, Domoticz Ubuntu 2022.1
Thorgal789
Re: ConBee II - Domoticz - Deconz, error: This device don't support action
Post by Thorgal789 »
Hello, Your device can create 1 "light" device and 1 "sensor" (for consumption if your device support it)
The "light" one need to be a "light/switch, switch, on/off"
This error happen when you try to send a command to a "sensor" instead of a "light", for exemple using virtual sensors.
Yep he need to be a light, switch are used to receive command, when you press it you receive an information, your plug receive information, like a light.
I think the problem is from here, can you delete the widget in "device", and reload the plugin (hardware/deconz/update), the widget will be re-created. you need to have this one
The "push to on" is the same too from my memory, except the icon.
Else can you show me the device json ? Visible in log or in custom/deconz.
oeps
Post by oeps »
Thorgal789 wrote: Saturday 20 February 2021 11:31
Thanks! Don't know the cause but simply deleting the switch and recreating it from settins/devices solved. Now it became a true switch which I can operate. See the images below.
Sometimes solutions are soo simple ;)
The energy monitoring is also shown (although I do not see the energy sensor in Phoscon. Not a big deal as all real monitoring is done in Domoticz. kWh meter was added too.
I'm a happy camper. Next is to move all the Ikea lights to this controller en move the Ikea controller to my daughter!
Thorgal789
Yep phoscon have less feature than domoticz, lot of devices are not displayed in it.
