Getting started, basic setup not working
johansson
Post by johansson »
I've installed the latest beta (V3.7.3) based on the great instructions, but am having a probably simple/stupid problem: if I add no blocks or columns at all, I get all Domoticz devices as expected. If I copy-paste the basic custom layout with some of my own devices idx's, I get a blank page.
This produces a complete list of all Domoticz devices:
var config = {}
config['language'] = 'en_US'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['domoticz_ip'] = 'http://***.***.***.***:***';
config['user_name'] = '****';
config['pass_word'] = '****';
Just the connection stuff in custom.js
no blocks.png (197.98 KiB) Viewed 466 times
But when adding example blocks & columns, just a blank screen is shown:
var config = {}
//config['use_favorites'] = 0; //Request all Domoticz Devices, not only favorites
//config['auto_positioning'] = 0; // Use 0 this if you have defined your own columns
//Definition of blocks
blocks = {}
blocks[3] = {
  width: 6
blocks[34] = {
  width: 6
//Definition of columns
columns = {}
columns[1] = {
  //In this example: No blocks are defined in this column
  //This column will be empty
  width: 4
columns[2] = {
  blocks : [3, 34],
  width: 8
//Definition of screens
screens = {}
screens[1] = {
  columns: [1, 2]
Blank screen with blocks in custom.js
With blocks.png (253.22 KiB) Viewed 466 times
Cannot figure out what's going on, probably too simple but I'm lost - any pointers?
Lokonli
Re: Getting started, basic setup not working
Post by Lokonli »
I guess device 3 and 34 are not marked as favorite in Domoticz.
Remove the two slashes before the config parameter, like this:
johansson
Post by johansson »
Thanks for the tip, but unfortunately no help - one of the other was marked as favorite, the other one not. Choosing two non-favorite ones and removing the slashes had no impact, neither did two favorites with or without the slashes. I'm sure the solution is obvious, but I'm just missing something.
Lokonli
Post by Lokonli »
There is a bug in beta: Each column must have a parameter 'block'
The block array can be empty, like this:
columns[1] = {
   blocks: [],
   width: 4
but the blocks parameter must be present.
johansson
Post by johansson »
Indeed, that was it - great, thanks! Now at least (only) the test devices are seen in Dashticz.
