I want to create a script that, at a certain time, turn on a led strip, with a 10 minute delay, ranging from 0% -100%. ex. after 5 minutes be at 50% of the delay! Someone already did something like that?
TY
Time Delay Light
- waaren
Re: Time Delay Light
Something likeNefsolive wrote: Friday 05 February 2021 13:40 I want to create a script that, at a certain time, turn on a led strip, with a 10 minute delay, ranging from 0% -100%. ex. after 5 minutes be at 50% of the delay! Someone already did something like that?
return
on =
timer =
'at 08:13', -- Change to the time you want the light to be switched on
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when script is OK
marker = 'dim light',
execute = function(dz)
local light = dz.devices('your dimmable light') -- change to name of your light
local dimMinutes = 10 -- amount of time from dim 0 to 100
local step = math.floor(dimMinutes * 60 / 100)
for i = 0, 99 do
light.dimTo(i+1).afterSec(i * step)
- Domoticz version: 2025.1
For inspiration you could also check a wake-up-light script: viewtopic.php?p=174803#p174803
Nefsolive
Hello Waaren,waaren wrote: Friday 05 February 2021 14:42Something likeNefsolive wrote: Friday 05 February 2021 13:40 I want to create a script that, at a certain time, turn on a led strip, with a 10 minute delay, ranging from 0% -100%. ex. after 5 minutes be at 50% of the delay! Someone already did something like that?
return { on = { timer = { 'at 08:13', -- Change to the time you want the light to be switched on }, }, logging = { level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when script is OK marker = 'dim light', }, execute = function(dz) local light = dz.devices('your dimmable light') -- change to name of your light local dimMinutes = 10 -- amount of time from dim 0 to 100 local step = math.floor(dimMinutes * 60 / 100) for i = 0, 99 do light.dimTo(i+1).afterSec(i * step) end end }
Thanks again for the help. The script works perfect.
Nefsolive
Thank´s waltervlwaltervl wrote: Friday 05 February 2021 14:49 For inspiration you could also check a wake-up-light script: viewtopic.php?p=174803#p174803
