Time Delay Light
Nefsolive
Time Delay Light
Post by Nefsolive »
I want to create a script that, at a certain time, turn on a led strip, with a 10 minute delay, ranging from 0% -100%. ex. after 5 minutes be at 50% of the delay! Someone already did something like that?
TY
Re: Time Delay Light
Nefsolive wrote: Friday 05 February 2021 13:40 I want to create a script that, at a certain time, turn on a led strip, with a 10 minute delay, ranging from 0% -100%. ex. after 5 minutes be at 50% of the delay! Someone already did something like that?
Something like
return
    on =
        timer =
            'at 08:13', -- Change to the time you want the light to be switched on
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when script is OK
        marker = 'dim light',
    execute = function(dz)
        local light = dz.devices('your dimmable light') -- change to name of your light
        local dimMinutes = 10 -- amount of time from dim 0 to 100
        local step = math.floor(dimMinutes * 60 / 100)
        for i = 0, 99 do
            light.dimTo(i+1).afterSec(i * step)
Domoticz version: 2025.1
For inspiration you could also check a wake-up-light script: viewtopic.php?p=174803#p174803
Nefsolive
Post by Nefsolive »
waaren wrote: Friday 05 February 2021 14:42
Something like
return
    on =
        timer =
    logging =
        for i = 0, 99 do
Hello Waaren,
Thanks again for the help. The script works perfect.
Nefsolive
Post by Nefsolive »
waltervl wrote: Friday 05 February 2021 14:49 For inspiration you could also check a wake-up-light script: viewtopic.php?p=174803#p174803
Thank´s waltervl
