Non Visiable Blocks, until Switch state change Topic is solved
lastofthejediknights
Domoticz version: 2021.1
Post by lastofthejediknights »
I have spent several hours building my first Dashticz display. I have just about got my head around the layouts, but have hit an odd problem.
my latest blocks show the prescence of myself and my wife, these are dummy switches activated normally via geofencing, and all is well on the Domoticz front.
The issue is that these blocks (have also tried substituting other switches) do not show up on the Dashticz screen UNLESS I change the state of the corresponding switch in Domoticz.
Once it shows up in Dashticz, it functions as one would expect, but then disappears if I refresh the Dashticz browser page, but will reappear if I change the switch state again.
The logic level doesn't matter it is the change in state which "allows" the Dashticz block to become visiable.
Screenshots and my messy config enclosed
Help?
var config = {}
config['domoticz_ip'] = 'http://192.168.1.13:8080';
config['app_title'] = 'Dashticz V3.7';
config['login_timeout'] = '60';
config['user_name'] = '';
config['pass_word'] = '';
config['domoticz_timeout'] = '5000';
config['room_plan'] = '0';
config['colorpicker'] = '2';
config['default_news_url'] = 'http://feeds.bbci.co.uk/news/england/rss.xml#';
config['news_scroll_after'] = '7';
config['default_cors_url'] = '';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = '';
config['standby_call_url_on_end'] = '';
config['theme'] = 'default';
config['background_image'] = 'img/bg14.jpg';
config['standby_after'] = '0';
config['start_page'] = '1';
config['enable_swiper'] = '2';
config['vertical_scroll'] = '2';
config['auto_swipe_back_to'] = '1';
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = '';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'en_US';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = '';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = '';
config['gm_zoomlevel'] = '';
config['gm_latitude'] = '';
config['gm_longitude'] = '';
config['speak_lang'] = '';
config['wu_api'] = '';
config['wu_city'] = 'London';
config['wu_name'] = '';
config['wu_country'] = 'GB';
config['owm_api'] = '';
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = '';
config['owm_country'] = 'gb';
config['owm_lang'] = '';
config['owm_cnt'] = '4';
config['idx_moonpicture'] = '';
config['longfonds_zipcode'] = '';
config['longfonds_housenumber'] = '';
config['switch_horizon'] = '';
config['host_nzbget'] = '';
config['spot_clientid'] = '';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['garbage_company'] = '';
config['garbage_icalurl'] = '';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '';
config['garbage_street'] = '';
config['garbage_housenumber'] = '';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '';
config['garbage_width'] = '';
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['evohome_boost_zone'] = '60';
config['evohome_boost_hw'] = '15';
config['disable_update_check'] = 0;
config['loginEnabled'] = 0;
config['enable_websocket'] = 1;
config['auto_positioning'] = 0;
config['use_favorites'] = 1;
config['last_update'] = 1;
config['disable_googleanalytics'] = 0;
config['hide_topbar'] = 0;
config['swiper_touch_move'] = 1;
config['security_button_icons'] = 0;
config['security_panel_lock'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['owm_days'] = 0;
config['owm_min'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
_DECIMAL_POINT = '.';
_THOUSAND_SEPARATOR = ',';
 // REMOVE THIS LINE, INCLUDING THIS TEXT IF YOU WANT TO USE THE CODE BELOW, ALS REMOVE THE LAST LINE OF THIS FILE ( the asterisk * with the slash)
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fas fa-tv', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS  	= [
	{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
	{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
	{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
	{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl',  width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos',  width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
var blocks = {}
blocks[424] = {
  width: 2,               //1 to 12, remove this line if you want to use the default (4)
  title : 'Thermostat',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
  color: "#57c4d6",
  type : 'dial',
  min: 10, // set the minimum value for the dial range (default is 5)
  max: 25, // set the maximum value for the dial range (default is 35)
    shownumbers: true,  // display the numbers on the dial (default is false)
      showring: true, // display outer ring color all the time (default is false, will only display when hover over)
  showunit: true, // display unit for the dial value (default is false)
  //Type ='Heating',
blocks[427] = {
  width: 4,               //1 to 12, remove this line if you want to use the default (4)
  title : 'Water Temp',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
  color: "#57c4d6",
  type : 'dial',
  max: 65, // set the maximum value for the dial range (default is 35)
blocks[625] = {
  title : 'Wind',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
  color: "#57c4d6",
  type : 'dial',
 // min: 10, // set the minimum value for the dial range (default is 5)
 // max: 65, // set the maximum value for the dial range (default is 35)
blocks[568] = {
  title : 'Heating',  //if you want change the name of switch different then domoticz
  last_update:false,
  type : 'dial',
  color: "#57c4d6",
blocks[422] = {
  title : 'Living Room Temperature',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
blocks['597_1'] = {
  title : 'Bed Room Temperature',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
blocks[597] = {
  title : 'Bed Room',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
  type : 'dial',
  color: "#57c4d6",
  showunit: true // display unit for the dial value (default is false)
blocks[596] = {
  title : 'Living Room',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
  type : 'dial',
  color: "#57c4d6",
blocks['476_0'] = {//476
  //width: 4,               //1 to 12, remove this line if you want to use the default (4)
  title : 'Power',  //if you want change the name of switch different then domoticz
 //last_update:false,
  type : 'dial',
  //color: "#57c4d6",
  //    min: 100, // set the minimum value for the dial range (default is 5)
  //max: 10000, // set the maximum value for the dial range (default is 35)
  //shownumbers: true,  // display the numbers on the dial (default is false)
//    showring: true, // display outer ring color all the time (default is false, will only display when hover over)
 // showunit: true // display unit for the dial value (default is false)
blocks['597_2'] = {
  title : 'Bed Room Humidity',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
blocks['596_2'] = {
  title : 'Living Room Humidity',  //if you want change the name of switch different then domoticz
  flash:5000,
  last_update:false,
blocks[439] = {
  title : 'Outside Temp',  //if you want change the name of switch different then domoticz
  flash:5000,
    last_update:false,
    min: -10, // set the minimum value for the dial range (default is 5)
  max: 40, // set the maximum value for the dial range (default is 35)
    type : 'dial',
    color: "#57c4d6",
blocks[33] = {
  title : 'Oil Tank',  //if you want change the name of switch different then domoticz
  flash:5000,
    last_update:false,
    min: -100, // set the minimum value for the dial range (default is 5)
  max: 1250, // set the maximum value for the dial range (default is 35)
    type : 'dial',
    color: "#57c4d6",
blocks[4] = {
  title : 'Dehumidifier',  //if you want change the name of switch different then domoticz
    flash:5000,
    type : 'dial',
    color: "#57c4d6",
  last_update:false,
blocks['s2'] = {
  title : 'Hot Water',  //if you want change the name of switch different then domoticz
  flash:5000,
  type : 'dial',
  color: "#57c4d6",
  last_update:false,
blocks['s3'] = {
  title : 'Living Lights',  //if you want change the name of switch different then domoticz
  flash:5000,
  type : 'dial',
  color: "#57c4d6",
  last_update:false,
blocks[421] = {
  title : 'Heating Boost',  //if you want change the name of switch different then domoticz
  flash:5000,
  type : 'dial',
  color: "#57c4d6",
  last_update:false,
blocks[6] = {
  title : 'Nigel',  //if you want change the name of switch different then domoticz
  flash:5000,
  //type : 'dial',
  color: "#57c4d6",
  last_update:false,
blocks[410] = {// emma at home
  title : 'Emma',  //if you want change the name of switch different then domoticz
  flash:5000,
  //type : 'dial',
  color: "#57c4d6",
  last_update:false,
blocks['graph_476'] = {
  height :'120px',
  last_update:false,
blocks['Hot_Water'] = { // Hot Water Combined block dial
        type: 'dial',
        width: 1,
        min: 10,
        max: 60,
        values : [
                        value: 'Temp',
                        idx: 427,
                        unit: 'C'
                        value: 'ON/OFF',
                        idx: 's3',
                        icon: 'fas fa-cloud',
buttons = {}            //only once!!
buttons.Workshop = {width:12, isimage:true, forceheight:'200px',  image: 'Outside-20210121-1142294784.jpg', url: 'http://Domoticz:@192.168.1.31/tmpfs/auto.jpg'}
buttons.radio = {width:2, image: 'radio_on.png', title: 'Radio', url: 'http://nederland.fm'}
//   http://192.168.1.30/tmpfs/auto.jpg?1611159497347
//   https://calendar.google.com/calendar/u/0?cid=bmlnZWwud3lib3JuQGdvb2dsZW1haWwuY29t
blocks['NW_calendar'] = {
        type: 'calendar',
        maxitems: 6,
        layout: 1,
        url: 'https://calendar.google.com/calendar/embed?src=nigel.wyborn%40googlemail.com&ctz=Europe%2FLondon',
        icalurl: 'https://calendar.google.com/calendar/ical/nigel.wyborn%40googlemail.com/private-b6d561dd3cbf839abaca4d9c6bc84610/basic.ics',
        holidayurl: 'https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics',
        weeks: 5,
        lastweek: false,
        isoweek: false,
        width: 3,
        method: 1
blocks['EW_calendar'] = {
        type: 'calendar',
        maxitems: 6,
        layout: 1,
        url: 'https://calendar.google.com/calendar/embed?src=emma.wyborn%40gmail.com&ctz=Europe%2FLondon',
        icalurl: 'https://calendar.google.com/calendar/ical/emma.wyborn%40gmail.com/private-5bfa2f53f0ed15618e0ca608c106b53d/basic.ics',
        weeks: 5,
        lastweek: false,
        isoweek: false,
        width: 3,
        method: 1
blocks['garage_cam'] = {
        type: 'camera',
        imageUrl: 'http://Domoticz:@192.168.1.31/tmpfs/auto.jpg',
        videoUrl: 'http://Domoticz:@192.168.1.31/tmpfs/auto.jpg',
        refresh: 5,
        width: 2,
        height: 125
blocks['Workshop_cam'] = {
        type: 'camera',
        imageUrl: 'http://Domoticz:@192.168.1.30/tmpfs/auto.jpg',
        videoUrl: 'http://Domoticz:@192.168.1.30/tmpfs/auto.jpg',
        refresh: 5,
        width: 2,
        height: 125
blocks["cameras"] = {
        type: "camera",
        width: 2,
        height: 150,
        refresh: 5,
        traytimeout: 3,
        slidedelay: 5,
        cameras: [
                        title: "Drive",
                        imageUrl: "http://Domoticz:@192.168.1.31/tmpfs/auto.jpg",
                        videoUrl: "http://Domoticz:@192.168.1.31/tmpfs/auto.jpg",
                        title: "Workshop",
                        imageUrl: "http://Domoticz:@192.168.1.30/tmpfs/auto.jpg",
                        videoUrl: "http://Domoticz:@192.168.1.30/tmpfs/auto.jpg",
// weather block
//Configuring the OWM parameters
config['owm_api'] = '7b6d4242c95ce2b90bf6acb0c0d9bd74';
config['owm_city'] = 'Terrington St Clement';
config['owm_name'] = 'Clenchwarton';
config['owm_country'] = 'GB';
config['owm_lang'] = 'en_US';
config['owm_cnt'] = '5';
config['owm_min'] = true;
config['owm_days'] = false;
var columns = {}          //This line only once!!
columns['bar'] = {}
columns[1] = {
  blocks: [424,568,597,596,'garage_cam','Workshop_cam','graph_476']
columns[2] = {
  blocks: []
//Adding OWM to a column
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big_owm','weather_owm']
columns[2]['width'] = 4;
columns[3] = {
  blocks: ['s2','s3',421]
  columns[3]['width'] = 4;
columns[4] = {
 // blocks: ['buttons.Workshop','buttons.radio'],
blocks: [427,439,625,33],//476
columns[4]['width'] = 4;
columns[5] = {
  blocks: [6,410],
columns[5]['width'] = 4;
columns[6] = {
  blocks: ['NW_calendar']
columns[6]['width'] = 12;
columns[7] = {
  blocks: ['EW_calendar']
columns[7]['width'] = 12;
var screens = {}
screens[1] = {}
screens[1]['columns'] = [1,3,4,2,5,6,7]
CONFIG.js
(17.48 KiB) Downloaded 25 times
dashticz Showing.jpg (146.42 KiB) Viewed 393 times
dashticz missing.jpg (170.32 KiB) Viewed 393 times
Lokonli
Re: Non Visiable Blocks, until Switch state change
Post by Lokonli »
In your config set use_favorites to 0, or make your devices a favorite in Domoticz.
Brilliant! That worked.
Kind Regards
Nigel
