This may be usefull,I have been using this script to plan my central heating system for the last two years now (flawlessly
It only publisches setpoints for two rooms based on a time and a day of week. It also calculates when the heating should turn on in order to reach the temperature on the desired time. It supports manual mode.(Manual mode will override at the next planned time in case someone forgets to put it back)
You can use the setpoints in another script to control your heater.
You will have to adjust the script for your own use and it most probably can be optimised.
You have to create two selector switches:
Livingroom periods: Wake, Home, Comfort, Away, Sleep
Heating Mode: Off, Normal, Vakantie, Weg, Thuis (Thuis is for Thuiswerken)
local ComfortSetting = 20
local HomeSetting = 19
local SleepSetting = 15
local AwaySetting = 15
local WakeSetting = 19
devices = {'Livingroom periods'},
timer = {'every minute'},
data = { Period = { initial = {},
oneShot = { initial = 0},
-- logging = { level = domoticz.LOG_DEBUG,
-- marker = "Planner" },
execute = function(dz, Item)
local Heating_period = dz.devices('Livingroom periods')
local TK_Temp = dz.devices('TK_Eetkamer_Temp')
local ManualSetpointLiving = dz.devices('Temperature')
t = {}
local function initPersistent()
t.periods = {}
t.periods = {
{Day="Mon",Wake='7:00',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:00'},
{Day="Tue",Wake='7:30',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:00'},
{Day="Wed",Wake='7:30',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:00'},
{Day="Thu",Wake='7:15',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:00'},
{Day="Fri",Wake='7:10',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:59'},
{Day="Sat",Wake='8:30',Home='17:00',Comfort='20:00',Sleep='23:59'},
{Day="Sun",Wake='9:30',Home='17:00',Comfort='20:00',Sleep='23:30'},
{Day="Vak",Wake='8:30',Home='17:00',Comfort='20:00',Sleep='23:59'},
{Day="Thuis",Wake='7:30',Home='17:00',Comfort='20:00',Sleep='23:00'},
dz.data.Period = t
function round(n)
return n % 1 >= 0.5 and math.ceil(n) or math.floor(n)
local function calcCurve(Setpoint)
local difference = Setpoint - TK_Temp.temperature
if difference > 0 then
local curve = 0.03 --C/min
timeReq = difference / curve
return round(timeReq)
elseif difference <= 0 then
return 0
local function correctedTime(Time, Setpoint)
h, m = string.match(Time, "(%d+):(%d+)")
local hour = tonumber(h)
local minute = tonumber(m)
local totalMinutes = (hour * 60) + minute
local startTime = totalMinutes - calcCurve(Setpoint)
dz.log('Correctie ' .. calcCurve(Setpoint))
dz.log(round(startTime))
return round(startTime)
local function directTime(Time)
dz.log(startTime)
local function processPeriods(t)
for i=1,#t.periods do
local Day = t.periods[i].Day
local Wake = t.periods[i].Wake
local Home = t.periods[i].Home
local Comfort = t.periods[i].Comfort
local Away = t.periods[i].Away
local Sleep = t.periods[i].Sleep
local HeatingMode = dz.devices('Heating Mode').levelName
if HeatingMode == 'Normal' or HeatingMode == 'Off' then
ToDay = os.date("%a")
elseif HeatingMode == 'Vakantie' then
ToDay = 'Vak'
elseif HeatingMode == 'Weg' then
Today = 'Weg'
elseif HeatingMode == 'Thuis' then
Today = 'Thuis'
if Today ~= 'Weg' then
dz.data.oneShot = 0
if ToDay == Day then
totalTijd = os.date("*t")
tijd = totalTijd.min + totalTijd.hour * 60
dz.log('Present time :' .. tijd)
if tijd >= correctedTime(Wake, WakeSetting) and tijd <= correctedTime(Wake, WakeSetting) + 5 then
dz.log('Wakker worden')
Heating_period.switchSelector('Wake')
if not (ToDay == 'Sat' or ToDay == 'Sun'or ToDay == 'Vak' or Today == 'Thuis') then
if tijd == directTime(Away) then
dz.log('Away')
Heating_period.switchSelector('Away')
if tijd >= correctedTime(Home, HomeSetting) and tijd <= correctedTime(Home, HomeSetting) + 5 then
dz.log('Home')
Heating_period.switchSelector('Home')
if tijd >= correctedTime(Comfort, ComfortSetting) and tijd <= correctedTime(Comfort, ComfortSetting) + 5 then
dz.log('Comfort')
Heating_period.switchSelector('Comfort')
if tijd == directTime(Sleep) then
dz.log('Sleep')
Heating_period.switchSelector('Sleep')
elseif Today == 'Weg' then
dz.log('Iedereen is weg')
dz.globalData.Setpoint_Woonkamer = AwaySetting
dz.globalData.Setpoint_Eetkamer = AwaySetting
if Item.isTimer then
initPersistent()
t = dz.data.Period
processPeriods(t)
if Item.isDevice and (Item.name == 'Livingroom periods') then
local currentPeriod = dz.devices('Livingroom periods').levelName
if currentPeriod == 'Comfort' then
dz.globalData.Setpoint_Woonkamer = ComfortSetting
dz.globalData.Setpoint_Eetkamer = ComfortSetting
elseif currentPeriod == 'Away' then
elseif currentPeriod == 'Sleep' then
dz.globalData.Setpoint_Woonkamer = SleepSetting
dz.globalData.Setpoint_Eetkamer = SleepSetting
elseif currentPeriod == 'Home' then
dz.globalData.Setpoint_Woonkamer = HomeSetting
dz.globalData.Setpoint_Eetkamer = HomeSetting
elseif currentPeriod == 'Wake' then
dz.globalData.Setpoint_Woonkamer = WakeSetting
dz.globalData.Setpoint_Eetkamer = WakeSetting
