Planner for central heating
Maxx
Post by Maxx »
All,
This may be usefull,I have been using this script to plan my central heating system for the last two years now (flawlessly :-)).
It only publisches setpoints for two rooms based on a time and a day of week. It also calculates when the heating should turn on in order to reach the temperature on the desired time. It supports manual mode.(Manual mode will override at the next planned time in case someone forgets to put it back)
You can use the setpoints in another script to control your heater.
You will have to adjust the script for your own use and it most probably can be optimised.
You have to create two selector switches:
Livingroom periods: Wake, Home, Comfort, Away, Sleep
Heating Mode: Off, Normal, Vakantie, Weg, Thuis (Thuis is for Thuiswerken)
local ComfortSetting   = 20
local HomeSetting      = 19
local SleepSetting     = 15
local AwaySetting      = 15
local WakeSetting      = 19
		devices = {'Livingroom periods'},
		timer = {'every minute'},
	data = {    Period  = { initial = {},
	            oneShot = { initial = 0},
--    logging =   {   level                   = domoticz.LOG_DEBUG,
--                    marker                  = "Planner" },
	execute = function(dz, Item)
    local Heating_period            = dz.devices('Livingroom periods')
    local TK_Temp                   = dz.devices('TK_Eetkamer_Temp')
    local ManualSetpointLiving      = dz.devices('Temperature')
    t = {}
    local function initPersistent()
            t.periods       = {}
            t.periods       =  {
                                {Day="Mon",Wake='7:00',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:00'},
                                {Day="Tue",Wake='7:30',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:00'},
                                {Day="Wed",Wake='7:30',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:00'},
                                {Day="Thu",Wake='7:15',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:00'},
                                {Day="Fri",Wake='7:10',Home='17:00',Comfort='20:00',Away='9:00', Sleep='23:59'},
                                {Day="Sat",Wake='8:30',Home='17:00',Comfort='20:00',Sleep='23:59'},
                                {Day="Sun",Wake='9:30',Home='17:00',Comfort='20:00',Sleep='23:30'},
                                {Day="Vak",Wake='8:30',Home='17:00',Comfort='20:00',Sleep='23:59'},
                                {Day="Thuis",Wake='7:30',Home='17:00',Comfort='20:00',Sleep='23:00'},
            dz.data.Period = t
    function round(n)
	    return n % 1 >= 0.5 and math.ceil(n) or math.floor(n)
    local function calcCurve(Setpoint)
        local difference = Setpoint - TK_Temp.temperature
        if difference > 0 then
            local curve = 0.03 --C/min
            timeReq = difference / curve
            return round(timeReq)
        elseif difference <= 0 then
            return 0
    local function correctedTime(Time, Setpoint)
        h, m = string.match(Time, "(%d+):(%d+)")
        local hour = tonumber(h)
        local minute = tonumber(m)
        local totalMinutes = (hour * 60) + minute
        local startTime = totalMinutes - calcCurve(Setpoint)
        dz.log('Correctie ' .. calcCurve(Setpoint))
        dz.log(round(startTime))
        return round(startTime)
    local function directTime(Time)
        dz.log(startTime)
    local function processPeriods(t)
        for i=1,#t.periods do
            local Day       = t.periods[i].Day
            local Wake      = t.periods[i].Wake
            local Home      = t.periods[i].Home
            local Comfort   = t.periods[i].Comfort
            local Away      = t.periods[i].Away
            local Sleep     = t.periods[i].Sleep
            local HeatingMode   = dz.devices('Heating Mode').levelName
            if HeatingMode == 'Normal' or HeatingMode == 'Off' then
                ToDay     = os.date("%a")
            elseif HeatingMode == 'Vakantie' then
                ToDay     = 'Vak'
            elseif HeatingMode == 'Weg' then
                Today = 'Weg'
            elseif HeatingMode == 'Thuis' then
                Today = 'Thuis'
            if Today ~= 'Weg' then
                dz.data.oneShot = 0
                if ToDay == Day then
                    totalTijd = os.date("*t")
	                tijd = totalTijd.min + totalTijd.hour * 60
	                dz.log('Present time :' .. tijd)
                    if tijd >= correctedTime(Wake, WakeSetting) and tijd <= correctedTime(Wake, WakeSetting) + 5  then
                        dz.log('Wakker worden')
                        Heating_period.switchSelector('Wake')
                    if not (ToDay == 'Sat' or ToDay == 'Sun'or ToDay == 'Vak' or Today == 'Thuis') then
                        if tijd == directTime(Away) then
                            dz.log('Away')
                            Heating_period.switchSelector('Away')
                    if tijd >= correctedTime(Home, HomeSetting) and tijd <= correctedTime(Home, HomeSetting) + 5 then
                        dz.log('Home')
                        Heating_period.switchSelector('Home')
                    if tijd >= correctedTime(Comfort, ComfortSetting) and tijd <= correctedTime(Comfort, ComfortSetting) + 5 then
                        dz.log('Comfort')
                        Heating_period.switchSelector('Comfort')
                    if tijd == directTime(Sleep) then
                        dz.log('Sleep')
                        Heating_period.switchSelector('Sleep')
            elseif Today == 'Weg' then
                dz.log('Iedereen is weg')
                dz.globalData.Setpoint_Woonkamer    = AwaySetting
                dz.globalData.Setpoint_Eetkamer     = AwaySetting
    if Item.isTimer then
        initPersistent()
        t = dz.data.Period
        processPeriods(t)
    if Item.isDevice and (Item.name == 'Livingroom periods') then
        local currentPeriod = dz.devices('Livingroom periods').levelName
        if currentPeriod == 'Comfort' then
            dz.globalData.Setpoint_Woonkamer    = ComfortSetting
            dz.globalData.Setpoint_Eetkamer     = ComfortSetting
        elseif currentPeriod == 'Away' then
        elseif currentPeriod == 'Sleep' then
            dz.globalData.Setpoint_Woonkamer    = SleepSetting
            dz.globalData.Setpoint_Eetkamer     = SleepSetting
        elseif currentPeriod == 'Home' then
            dz.globalData.Setpoint_Woonkamer    = HomeSetting
            dz.globalData.Setpoint_Eetkamer     = HomeSetting
        elseif currentPeriod == 'Wake' then
            dz.globalData.Setpoint_Woonkamer    = WakeSetting
            dz.globalData.Setpoint_Eetkamer     = WakeSetting
