Push notifications via Nextcloud
Posted: Monday 18 January 2021 11:45
by m147
I think that a lot of users has installed Nextcloud server along with Domoticz and would be nice to use a Nextcloud as push notification server for Domoticz. Unfortunately I don't have enough skills to write plug-in for that.
Re: Push notifications via Nextcloud
Posted: Tuesday 19 January 2021 13:26
by m147
Please can anyone help me how to configure
domoticz.openURL function to act like this command?
curl -H "OCS-APIREQUEST: true" -X POST https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER -d "shortMessage=test"
At least I am trying to make DzVents script for notification...
Posted: Tuesday 19 January 2021 13:43
by waaren
m147 wrote: Tuesday 19 January 2021 13:26
Something like
domoticz.openURL({
url = 'https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER',
headers = { ['OCS-APIREQUEST'] = true },
postData = { ['shortMessage'] = 'test' },
method = 'POST',
callback = 'Could be any string or left out completely',
Posted: Tuesday 19 January 2021 14:10
by m147
waaren wrote: Tuesday 19 January 2021 13:43
Something like
domoticz.openURL({
method = 'POST',
The "-d" is missing in postData.
If i try to add it like this:
postData = {"-d", ['shortMessage'] = 'test' },
This is result:
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: method = POST
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: post data = {"shortMessage":"test","1":"-d"}
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: headers = !#OCS-APIREQUEST: true
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: callback = Could be any string or left out completely
Thank you for your help.
Posted: Tuesday 19 January 2021 14:18
by waaren
m147 wrote: Tuesday 19 January 2021 14:10
The -d is no data but a control switch for curl.
-d, --data <data> HTTP POST data
--data-ascii <data> HTTP POST ASCII data
--data-binary <data> HTTP POST binary data
--data-raw <data> HTTP POST data, '@' allowed
--data-urlencode <data> HTTP POST data url encoded
--delegation <LEVEL> GSS-API delegation permission
--digest Use HTTP Digest Authentication
You don't use it with the openURL switch.
If you use the callback option you will see the result of the call (including errors (if any))
Posted: Tuesday 19 January 2021 14:25
by m147
waaren wrote: Tuesday 19 January 2021 14:18
Of course you are right! Sorry.
But anyway the result is not same as posted curl command >> It doesn't work
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: method = POST
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: post data = {"shortMessage":"test"}
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: headers = !#OCS-APIREQUEST: true
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: callback = Could be any string or left out completely
Posted: Tuesday 19 January 2021 14:31
by waaren
m147 wrote: Tuesday 19 January 2021 14:25
What is you domoticz version?
The Header section does not look right.
Can you send me your script so I can help you adding a response section? It might help in identifying what happens.
Posted: Tuesday 19 January 2021 14:46
by m147
waaren wrote: Tuesday 19 January 2021 14:31
Version: 2020.2 (build 12738)
Well the "script" is so far just openUrl function. I wanted to figure it out before I move forward.
-- devices = {},
timer = {'every minute'},
logging = {
level = domoticz.LOG_DEBUG,
execute = function(domoticz, triggeredItem)
domoticz.openURL({
url = 'https://admin:token@url/ocs/v2.php/apps/admin_notifications/api/v1/notifications/user',
headers = { ['OCS-APIREQUEST'] = 'true' },
postData = {['shortMessage'] = 'test' },
method = 'POST',
Posted: Tuesday 19 January 2021 15:11
by waaren
m147 wrote: Tuesday 19 January 2021 14:46
Below version should give some more info..
local scriptVar = 'nextCloud'
return
on =
devices =
timer =
'every minute'
httpResponses =
scriptVar,
logging = {
marker = scriptVar,
execute = function(dz, item)
local function sendTo()
dz.openURL(
method = 'POST',
callback = scriptVar,
if item.isTimer or item.isDevice then
sendTo()
dz.log(item,dz.LOG_DEBUG)
Posted: Tuesday 19 January 2021 16:47
by m147
waaren wrote: Tuesday 19 January 2021 15:11
Here is output:
- Spoiler: show
- [/code]
2021-01-19 16:38:00.321 Status: dzVents: Info: nextCloud: ------ Start internal script: notifikace:, trigger: "every minute"
2021-01-19 16:38:00.321 Status: dzVents: Debug: nextCloud: OpenURL: url = https://admin:###@###/ocs/v2.php/apps/a ... fications/###
2021-01-19 16:38:00.321 Status: dzVents: Debug: nextCloud: OpenURL: method = POST
2021-01-19 16:38:00.321 Status: dzVents: Debug: nextCloud: OpenURL: post data = {"shortMessage":"test"}
2021-01-19 16:38:00.322 Status: dzVents: Debug: nextCloud: OpenURL: headers = !#OCS-APIREQUEST: true
2021-01-19 16:38:00.322 Status: dzVents: Debug: nextCloud: OpenURL: callback = nextCloud
2021-01-19 16:38:00.322 Status: dzVents: Info: nextCloud: ------ Finished notifikace
2021-01-19 16:38:00.322 Status: EventSystem: Script event triggered: /home/michal/domoticz/dzVents/runtime/dzVents.lua
2021-01-19 16:38:00.445 Status: dzVents: Info: Handling httpResponse-events for: "nextCloud"
2021-01-19 16:38:00.445 Status: dzVents: Info: nextCloud: ------ Start internal script: notifikace: HTTPResponse: "nextCloud"
2021-01-19 16:38:00.447 Status: dzVents: Debug: nextCloud: {["xmlVersion"]="1.0", ["headers"]={["Content-Type"]="application/xml; charset=utf-8", ["Date"]="Tue, 19 Jan 2021 15:38:00 GMT", ["Feature-Policy"]="autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'", ["X-Download-Options"]="noopen", ["X-Permitted-Cross-Domain-Policies"]="none", ["X-Content-Type-Options"]="nosniff", ["X-Robots-Tag"]="none", ["Content-Length"]="170", ["Server"]="Apache/2.4.25 (Debian)", ["Cache-Control"]="no-cache, no-store, must-revalidate", ["X-Frame-Options"]="SAMEORIGIN", ["Expires"]="Thu, 19 Nov 1981 08:52:00 GMT", ["Pragma"]="no-cache", ["Strict-Transport-Security"]="max-age=15552000", ["Content-Security-Policy"]="default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'", ["Referrer-Policy"]="no-referrer", ["X-XSS-Protection"]="1; mode=block"}, ["isDevice"]=false, ["protocol"]="HTTP/1.1", ["_contentType"]="application/xml; charset=utf-8", ["isJSON"]=false, ["isHardware"]=false, ["ok"]=false, ["xml"]={["ocs"]={["data"]={}, ["meta"]={["statuscode"]="997", ["status"]="failure", ["message"]="Current user is not logged in"}}}, ["isVariable"]=false, ["trigger"]="nextCloud", ["isSystem"]=false, ["baseType"]="httpResponse", ["isCustomEvent"]=false, ["isSecurity"]=false, ["callback"]="nextCloud", ["isScene"]=false, ["data"]="<?xml version="1.0"?>
2021-01-19 16:38:00.447 <ocs>
2021-01-19 16:38:00.447 <meta>
2021-01-19 16:38:00.447 <status>failure</status>
2021-01-19 16:38:00.447 <statuscode>997</statuscode>
2021-01-19 16:38:00.447 <message>Current user is not logged in</message>
2021-01-19 16:38:00.447 </meta>
2021-01-19 16:38:00.447 <data/>
2021-01-19 16:38:00.447 </ocs>
2021-01-19 16:38:00.447 ", ["isTimer"]=false, ["dump"]=function, ["isHTTPResponse"]=true, ["isGroup"]=false, ["statusCode"]=401, ["statusText"]="Unauthorized", ["isXML"]=true}
2021-01-19 16:38:00.447 Status: dzVents: Info: nextCloud: ------ Finished notifikace [/code]
Authorization failure... If I use same user and token in curl, it woks. I have also tried token generated especially for this purpose and still same issue
Posted: Tuesday 19 January 2021 17:06
by waaren
m147 wrote: Tuesday 19 January 2021 16:47
Could it be something with a string that needs url encoding?
Anyway can you test this one? ( After updating to a later version )
-- Requires dzVents >= 3.1 (domoticz build >= 12771)
return
on =
devices =
timer =
'every minute',
shellCommandResponses =
scriptVar,
logging = {
marker = scriptVar,
dz.executeShellCommand(
command = 'curl -H "OCS-APIREQUEST: true" -X POST https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER -d "shortMessage=test"',
timeout = 300,
sendTo()
Posted: Tuesday 19 January 2021 17:21
by m147
I don't really understand.
I am afraid I have to wait until the build issue will be solved.
https://github.com/domoticz/domoticz/issues/4546
Posted: Tuesday 19 January 2021 18:08
by waaren
m147 wrote: Tuesday 19 January 2021 17:21
Probably a long shot but the characters '!', '*', "'", "(", ")", ";", ":", "@", "&", "=", "+", "$", ",", "/", "?", "%", "#", "[", "]" in a string are not very well interpreted when sending in a url. To convert these chars to something that can be part of a url, the function dz.utils.urlEncode() is available. So if ADMIN:TOKEN does contain any of these chars you could try to urlEncode the string first.
OK. @gizmocuz is working that now so should not take much longer
Posted: Tuesday 19 January 2021 22:58
by waaren
If you have a windows system in your network you could test this now.
Installing domoticz on windows can be done in a couple of minutes. Only other thing needed would then be curl
Posted: Wednesday 20 January 2021 15:53
by m147
waaren wrote: Tuesday 19 January 2021 22:58
Ok I have tried install last beta on windows and it works!
Token contains doesn't contain any of these characters. Only
weird character there is "-" .
