Push notifications via Nextcloud
I think that a lot of users has installed Nextcloud server along with Domoticz and would be nice to use a Nextcloud as push notification server for Domoticz. Unfortunately I don't have enough skills to write plug-in for that.
Re: Push notifications via Nextcloud
Please can anyone help me how to configure domoticz.openURL function to act like this command?
At least I am trying to make DzVents script for notification...
curl -H "OCS-APIREQUEST: true" -X POST https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER -d "shortMessage=test"- waaren
Something likem147 wrote: Tuesday 19 January 2021 13:26 Please can anyone help me how to configure domoticz.openURL function to act like this command?Code: Select all
domoticz.openURL({
url = 'https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER',
headers = { ['OCS-APIREQUEST'] = true },
postData = { ['shortMessage'] = 'test' },
method = 'POST',
callback = 'Could be any string or left out completely',
The "-d" is missing in postData.waaren wrote: Tuesday 19 January 2021 13:43Something likem147 wrote: Tuesday 19 January 2021 13:26 Please can anyone help me how to configure domoticz.openURL function to act like this command?Code: Select all
domoticz.openURL({ url = 'https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER', headers = { ['OCS-APIREQUEST'] = true }, postData = { ['shortMessage'] = 'test' }, method = 'POST', callback = 'Could be any string or left out completely', })
If i try to add it like this:
postData = {"-d", ['shortMessage'] = 'test' },Thank you for your help.2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: method = POST
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: post data = {"shortMessage":"test","1":"-d"}
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: headers = !#OCS-APIREQUEST: true
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: callback = Could be any string or left out completely
- waaren
The -d is no data but a control switch for curl.
-d, --data <data> HTTP POST data
--data-ascii <data> HTTP POST ASCII data
--data-binary <data> HTTP POST binary data
--data-raw <data> HTTP POST data, '@' allowed
--data-urlencode <data> HTTP POST data url encoded
--delegation <LEVEL> GSS-API delegation permission
--digest Use HTTP Digest Authentication
If you use the callback option you will see the result of the call (including errors (if any))
Of course you are right! Sorry.waaren wrote: Tuesday 19 January 2021 14:18The -d is no data but a control switch for curl.
You don't use it with the openURL switch.Code: Select all
-d, --data <data> HTTP POST data --data-ascii <data> HTTP POST ASCII data --data-binary <data> HTTP POST binary data --data-raw <data> HTTP POST data, '@' allowed --data-urlencode <data> HTTP POST data url encoded --delegation <LEVEL> GSS-API delegation permission --digest Use HTTP Digest Authentication
But anyway the result is not same as posted curl command >> It doesn't work
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: method = POST
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: post data = {"shortMessage":"test"}
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: headers = !#OCS-APIREQUEST: true
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: callback = Could be any string or left out completely
- waaren
What is you domoticz version?m147 wrote: Tuesday 19 January 2021 14:25 Of course you are right! Sorry.
But anyway the result is not same as posted curl command >> It doesn't work![]()
The Header section does not look right.
Can you send me your script so I can help you adding a response section? It might help in identifying what happens.
Version: 2020.2 (build 12738)waaren wrote: Tuesday 19 January 2021 14:31What is you domoticz version?m147 wrote: Tuesday 19 January 2021 14:25 Of course you are right! Sorry.
Well the "script" is so far just openUrl function. I wanted to figure it out before I move forward.
-- devices = {},
timer = {'every minute'},
logging = {
level = domoticz.LOG_DEBUG,
execute = function(domoticz, triggeredItem)
domoticz.openURL({
url = 'https://admin:token@url/ocs/v2.php/apps/admin_notifications/api/v1/notifications/user',
headers = { ['OCS-APIREQUEST'] = 'true' },
postData = {['shortMessage'] = 'test' },
method = 'POST',
}- waaren
Below version should give some more info..m147 wrote: Tuesday 19 January 2021 14:46 Well the "script" is so far just openUrl function. I wanted to figure it out before I move forward.
local scriptVar = 'nextCloud'
return
on =
devices =
timer =
'every minute'
httpResponses =
scriptVar,
logging = {
marker = scriptVar,
execute = function(dz, item)
local function sendTo()
dz.openURL(
method = 'POST',
callback = scriptVar,
if item.isTimer or item.isDevice then
sendTo()
dz.log(item,dz.LOG_DEBUG)
}Debian buster, bullseye on RPI-4, Intel NUC.
waaren wrote: Tuesday 19 January 2021 15:11Below version should give some more info..m147 wrote: Tuesday 19 January 2021 14:46 Well the "script" is so far just openUrl function. I wanted to figure it out before I move forward.
Here is output:
Authorization failure... If I use same user and token in curl, it woks. I have also tried token generated especially for this purpose and still same issue
- Spoiler: show
- waaren
Could it be something with a string that needs url encoding?m147 wrote: Tuesday 19 January 2021 16:47 Authorization failure... If I use same user and token in curl, it woks. I have also tried token generated especially for this purpose and still same issue![]()
Anyway can you test this one? ( After updating to a later version )
-- Requires dzVents >= 3.1 (domoticz build >= 12771)
return
on =
devices =
timer =
'every minute',
shellCommandResponses =
scriptVar,
logging = {
marker = scriptVar,
dz.executeShellCommand(
command = 'curl -H "OCS-APIREQUEST: true" -X POST https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER -d "shortMessage=test"',
timeout = 300,
sendTo()
I don't really understand.Could it be something with a string that needs url encoding?
I am afraid I have to wait until the build issue will be solved.Anyway can you test this one? ( After updating to a later version )
https://github.com/domoticz/domoticz/issues/4546
- waaren
Probably a long shot but the characters '!', '*', "'", "(", ")", ";", ":", "@", "&", "=", "+", "$", ",", "/", "?", "%", "#", "[", "]" in a string are not very well interpreted when sending in a url. To convert these chars to something that can be part of a url, the function dz.utils.urlEncode() is available. So if ADMIN:TOKEN does contain any of these chars you could try to urlEncode the string first.
OK. @gizmocuz is working that now so should not take much longerI am afraid I have to wait until the build issue will be solved.
- waaren
If you have a windows system in your network you could test this now.m147 wrote: Tuesday 19 January 2021 17:21 I am afraid I have to wait until the build issue will be solved.
Installing domoticz on windows can be done in a couple of minutes. Only other thing needed would then be curl
Ok I have tried install last beta on windows and it works!waaren wrote: Tuesday 19 January 2021 22:58If you have a windows system in your network you could test this now.m147 wrote: Tuesday 19 January 2021 17:21 I am afraid I have to wait until the build issue will be solved.
Token contains doesn't contain any of these characters. Only weird character there is "-" .Probably a long shot but the characters '!', '*', "'", "(", ")", ";", ":", "@", "&", "=", "+", "$", ",", "/", "?", "%", "#", "[", "]" in a string are not very well interpreted when sending in a url. To convert these chars to something that can be part of a url, the function dz.utils.urlEncode() is available. So if ADMIN:TOKEN does contain any of these chars you could try to urlEncode the string first.
