Push notifications via Nextcloud
m147
Post by m147 »
I think that a lot of users has installed Nextcloud server along with Domoticz and would be nice to use a Nextcloud as push notification server for Domoticz. Unfortunately I don't have enough skills to write plug-in for that.
m147
Re: Push notifications via Nextcloud
Post by m147 »
Please can anyone help me how to configure domoticz.openURL function to act like this command?
curl -H "OCS-APIREQUEST: true" -X POST   https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER   -d "shortMessage=test"
At least I am trying to make DzVents script for notification...
m147 wrote: Tuesday 19 January 2021 13:26 Please can anyone help me how to configure domoticz.openURL function to act like this command?
Something like
domoticz.openURL({
    url = 'https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER',
    headers = { ['OCS-APIREQUEST'] = true },
    postData = { ['shortMessage'] = 'test' },
    method = 'POST',
    callback = 'Could be any string or left out completely',
m147
Post by m147 »
waaren wrote: Tuesday 19 January 2021 13:43
Something like
domoticz.openURL({
    method = 'POST',
The "-d" is missing in postData.
If i try to add it like this:
postData = {"-d", ['shortMessage'] = 'test' },
This is result:
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: method = POST
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: post data = {"shortMessage":"test","1":"-d"}
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: headers = !#OCS-APIREQUEST: true
2021-01-19 14:06:00.077 Status: dzVents: Debug: OpenURL: callback = Could be any string or left out completely
Thank you for your help.
m147 wrote: Tuesday 19 January 2021 14:10 The "-d" is missing in postData.
The -d is no data but a control switch for curl.
 -d, --data <data>   HTTP POST data
     --data-ascii <data> HTTP POST ASCII data
     --data-binary <data> HTTP POST binary data
     --data-raw <data> HTTP POST data, '@' allowed
     --data-urlencode <data> HTTP POST data url encoded
     --delegation <LEVEL> GSS-API delegation permission
     --digest        Use HTTP Digest Authentication
You don't use it with the openURL switch.
If you use the callback option you will see the result of the call (including errors (if any))
m147
Post by m147 »
waaren wrote: Tuesday 19 January 2021 14:18
Of course you are right! Sorry.
But anyway the result is not same as posted curl command >> It doesn't work :(
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: method = POST
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: post data = {"shortMessage":"test"}
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: headers = !#OCS-APIREQUEST: true
2021-01-19 14:24:00.343 Status: dzVents: Debug: OpenURL: callback = Could be any string or left out completely
m147 wrote: Tuesday 19 January 2021 14:25 Of course you are right! Sorry.
What is you domoticz version?
The Header section does not look right.
Can you send me your script so I can help you adding a response section? It might help in identifying what happens.
m147
Post by m147 »
waaren wrote: Tuesday 19 January 2021 14:31
Version: 2020.2 (build 12738)
Well the "script" is so far just openUrl function. I wanted to figure it out before I move forward.
--		devices = {},
		timer = {'every minute'},
	logging = {
        level = domoticz.LOG_DEBUG,
	execute = function(domoticz, triggeredItem)
	domoticz.openURL({
        url = 'https://admin:token@url/ocs/v2.php/apps/admin_notifications/api/v1/notifications/user',
        headers = { ['OCS-APIREQUEST'] = 'true' },
        postData = {['shortMessage'] = 'test' },
        method = 'POST',
m147 wrote: Tuesday 19 January 2021 14:46 Well the "script" is so far just openUrl function. I wanted to figure it out before I move forward.
Below version should give some more info..
local scriptVar = 'nextCloud'
return
    on =
        devices =
        timer =
            'every minute'
        httpResponses =
            scriptVar,
    logging = {
        marker = scriptVar,
    execute = function(dz, item)
        local function sendTo()
            dz.openURL(
                method = 'POST',
                callback = scriptVar,
        if item.isTimer or item.isDevice then
            sendTo()
            dz.log(item,dz.LOG_DEBUG)
m147
Post by m147 »
waaren wrote: Tuesday 19 January 2021 15:11
Here is output:
[/code]
2021-01-19 16:38:00.321 Status: dzVents: Info: nextCloud: ------ Start internal script: notifikace:, trigger: "every minute"
2021-01-19 16:38:00.321 Status: dzVents: Debug: nextCloud: OpenURL: url = https://admin:###@###/ocs/v2.php/apps/a ... fications/###
2021-01-19 16:38:00.321 Status: dzVents: Debug: nextCloud: OpenURL: method = POST
2021-01-19 16:38:00.321 Status: dzVents: Debug: nextCloud: OpenURL: post data = {"shortMessage":"test"}
2021-01-19 16:38:00.322 Status: dzVents: Debug: nextCloud: OpenURL: headers = !#OCS-APIREQUEST: true
2021-01-19 16:38:00.322 Status: dzVents: Debug: nextCloud: OpenURL: callback = nextCloud
2021-01-19 16:38:00.322 Status: dzVents: Info: nextCloud: ------ Finished notifikace
2021-01-19 16:38:00.322 Status: EventSystem: Script event triggered: /home/michal/domoticz/dzVents/runtime/dzVents.lua
2021-01-19 16:38:00.445 Status: dzVents: Info: Handling httpResponse-events for: "nextCloud"
2021-01-19 16:38:00.445 Status: dzVents: Info: nextCloud: ------ Start internal script: notifikace: HTTPResponse: "nextCloud"
2021-01-19 16:38:00.447 Status: dzVents: Debug: nextCloud: {["xmlVersion"]="1.0", ["headers"]={["Content-Type"]="application/xml; charset=utf-8", ["Date"]="Tue, 19 Jan 2021 15:38:00 GMT", ["Feature-Policy"]="autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'", ["X-Download-Options"]="noopen", ["X-Permitted-Cross-Domain-Policies"]="none", ["X-Content-Type-Options"]="nosniff", ["X-Robots-Tag"]="none", ["Content-Length"]="170", ["Server"]="Apache/2.4.25 (Debian)", ["Cache-Control"]="no-cache, no-store, must-revalidate", ["X-Frame-Options"]="SAMEORIGIN", ["Expires"]="Thu, 19 Nov 1981 08:52:00 GMT", ["Pragma"]="no-cache", ["Strict-Transport-Security"]="max-age=15552000", ["Content-Security-Policy"]="default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'", ["Referrer-Policy"]="no-referrer", ["X-XSS-Protection"]="1; mode=block"}, ["isDevice"]=false, ["protocol"]="HTTP/1.1", ["_contentType"]="application/xml; charset=utf-8", ["isJSON"]=false, ["isHardware"]=false, ["ok"]=false, ["xml"]={["ocs"]={["data"]={}, ["meta"]={["statuscode"]="997", ["status"]="failure", ["message"]="Current user is not logged in"}}}, ["isVariable"]=false, ["trigger"]="nextCloud", ["isSystem"]=false, ["baseType"]="httpResponse", ["isCustomEvent"]=false, ["isSecurity"]=false, ["callback"]="nextCloud", ["isScene"]=false, ["data"]="<?xml version="1.0"?>
2021-01-19 16:38:00.447 <ocs>
2021-01-19 16:38:00.447 <meta>
2021-01-19 16:38:00.447 <status>failure</status>
2021-01-19 16:38:00.447 <statuscode>997</statuscode>
2021-01-19 16:38:00.447 <message>Current user is not logged in</message>
2021-01-19 16:38:00.447 </meta>
2021-01-19 16:38:00.447 <data/>
2021-01-19 16:38:00.447 </ocs>
2021-01-19 16:38:00.447 ", ["isTimer"]=false, ["dump"]=function, ["isHTTPResponse"]=true, ["isGroup"]=false, ["statusCode"]=401, ["statusText"]="Unauthorized", ["isXML"]=true}
2021-01-19 16:38:00.447 Status: dzVents: Info: nextCloud: ------ Finished notifikace [/code]
Authorization failure... If I use same user and token in curl, it woks. I have also tried token generated especially for this purpose and still same issue :(
m147 wrote: Tuesday 19 January 2021 16:47 Authorization failure... If I use same user and token in curl, it woks. I have also tried token generated especially for this purpose and still same issue :(
Could it be something with a string that needs url encoding?
Anyway can you test this one? ( After updating to a later version )
-- Requires dzVents >= 3.1 (domoticz build >= 12771)
return
    on =
        devices =
        timer =
            'every minute',
        shellCommandResponses =
            scriptVar,
    logging = {
        marker = scriptVar,
            dz.executeShellCommand(
                command = 'curl -H "OCS-APIREQUEST: true" -X POST   https://ADMIN:TOKEN@URL/ocs/v2.php/apps/admin_notifications/api/v1/notifications/USER   -d "shortMessage=test"',
                timeout = 300,
            sendTo()
m147
Post by m147 »
I don't really understand.
I am afraid I have to wait until the build issue will be solved.
https://github.com/domoticz/domoticz/issues/4546
m147 wrote: Tuesday 19 January 2021 17:21 I don't really understand.
Probably a long shot but the characters '!', '*', "'", "(", ")", ";", ":", "@", "&", "=", "+", "$", ",", "/", "?", "%", "#", "[", "]" in a string are not very well interpreted when sending in a url. To convert these chars to something that can be part of a url, the function dz.utils.urlEncode() is available. So if ADMIN:TOKEN does contain any of these chars you could try to urlEncode the string first.
OK. @gizmocuz is working that now so should not take much longer
m147 wrote: Tuesday 19 January 2021 17:21 I am afraid I have to wait until the build issue will be solved.
If you have a windows system in your network you could test this now.
Installing domoticz on windows can be done in a couple of minutes. Only other thing needed would then be curl
m147
Post by m147 »
waaren wrote: Tuesday 19 January 2021 22:58
Ok I have tried install last beta on windows and it works!
Token contains doesn't contain any of these characters. Only weird character there is "-" .
