I use dzVents scripts initially entered using the Domoticz editor. I notice that each day at midnight, Domoticz rewrite the DzVents script files (see log below).
Why such behavior?
2021-01-14 00:00:00.338 Status: EventSystem: reset all events...
2021-01-14 00:00:00.340 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/LINKYdelestage.lua
2021-01-14 00:00:00.340 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/Heating.lua
2021-01-14 00:00:00.341 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/global_data.lua
2021-01-14 00:00:02.873 Status: Starting manual database backup procedure...
It's midnight! Time to rewrite the dzVents files! WHY?
- Antori91
- Domoticz version: 4.10717
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
- waaren
Re: It's midnight! Time to rewrite the dzVents files! WHY?
It's part of the refresh routine. It is also done at every domoticz start and on every activate, delete, deactivate, change and create of a script when done from the internal editor. The process delete all files in the generated script dir and rebuild them.Antori91 wrote: Thursday 14 January 2021 23:11 Hello,
Why such behavior?
ak97
- Domoticz version: latest
can this interfere with the execution of any tasks at 0:00 ?
- waaren
No.ak97 wrote: Thursday 11 March 2021 6:21 can this interfere with the execution of any tasks at 0:00 ?
