It's midnight! Time to rewrite the dzVents files! WHY?
Antori91
Domoticz version: 4.10717
Post by Antori91 »
I use dzVents scripts initially entered using the Domoticz editor. I notice that each day at midnight, Domoticz rewrite the DzVents script files (see log below).
Why such behavior?
2021-01-14 00:00:00.338 Status: EventSystem: reset all events...
2021-01-14 00:00:00.340 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/LINKYdelestage.lua
2021-01-14 00:00:00.340 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/Heating.lua
2021-01-14 00:00:00.341 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/global_data.lua
2021-01-14 00:00:02.873 Status: Starting manual database backup procedure...
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
Re: It's midnight! Time to rewrite the dzVents files! WHY?
Antori91 wrote: Thursday 14 January 2021 23:11 Hello,
Why such behavior?
It's part of the refresh routine. It is also done at every domoticz start and on every activate, delete, deactivate, change and create of a script when done from the internal editor. The process delete all files in the generated script dir and rebuild them.
ak97
Domoticz version: latest
Post by ak97 »
can this interfere with the execution of any tasks at 0:00 ?
ak97 wrote: Thursday 11 March 2021 6:21 can this interfere with the execution of any tasks at 0:00 ?
No.
