How to modify Utility Text icon
cyberfilou
Domoticz version: V3.4834
Post by cyberfilou »
would like to change the icon of my device variables.
How can I do.
Thank you
Cyberfilou
Domoticz Instance + Zwave.Me + zigate+ RFXcom( RPI4 )
Re: How to modify Utility Text icon
cyberfilou wrote: Wednesday 13 January 2021 20:40 How can I do.
Check this post / topic
cyberfilou
Thank you but I can't find the answer,
this is not for a switch, because there I found, but for icons which are in the UTILITY tab, the Text icon
I would like to have different icons for each equipment
Cyberfilou
cyberfilou wrote: Wednesday 13 January 2021 21:57 Thank you but I can't find the answer,
I cannot make it more clear than what was already posted.
jeroenkl wrote: Monday 04 January 2021 16:41 Is it possible with this dzVents command to change the Icon 'text' at a custom dummy created device?
Yes but you need to be on the Beta version build >= 12750.
Please note that the iconchange will only be visible when you reopen the screen or after you manually refresh [(ctrl] r in Chrome) or switch back and forth via another screen.
