how to change switch-icon on the fly
- Domoticz version: V2024.7
I am controlling a light in the garden via an url sent from Domoticz to arduino. e.g.:
http://192.168.2.17/LED=ON and http://192.168.2.17/LED=OFF
Up to now the switch icon immediately turns into yellow-color but I only want to change the switch icon if it's sure the light is on. (Same as with Zwave switches.)
Communication in two ways works already fine for me but it's unclear how to change an icon control.
e.g. set a var named 'LightIsOn' [1=on; 0 I=off]. depending on status of that var the icon should change.
So if the light is on Arduino (in the garden) sents:Domoticz_IP:8080//json.htm?type=command¶m=updateuservariable&vname=USERVARIABLENAME&vtype=USERVARIABLETYPE
&vvalue=USERVARIABLEVALUE. A contact of a relay which is connected across the lamp informs Arduino : light is on.
Basically same procedure will be applied later on in the project to show whether or not a gardendoor has been locked (by activation of inductive limit switch). In that case only comm from Arduino towards Domoticz.
Any suggestion?
TIA
-Bart
Any suggestion?
TIA
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Re: how to change switch-icon on the fly
Hi.
Over 2 years since I asked about changing icons on the fly but never got a suggestion.
Maybe now?
TIA
-Bart
Maybe now?
TIA
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- waaren
http://<domoticz ip: domoticz port>/json.htm?type=setused&used=true&name=<name>&description=<description>&idx=<idx>&switchtype=<switchType>&customimage=<iconNumber>
domoticz.devices('device name').setIcon('icon number')
Hi Waaren,waaren wrote: ↑Monday 04 January 2021 0:26or in a dzVents script:Code: Select all
Is it possible with this dzVents command to change the Icon 'text' at a custom dummy created device?
BR, Jeroen
- waaren
Yes but you need to be on the Beta version build >= 12750.
Please note tat the iconchange will only be visible when you reopen the screen or after you manually refresh [(ctrl] r in Chrome) or switch back and forth via another screen.
Great!
Ehh @waaren, how do I find the Icon number? I've got the name but not a number
BR,
Jeroen
- waaren
Maybe there are better / easier ways but I do
cd <domoticz dir>
sudo sqlite3 -header domoticz.db " select id+100 id ,name from customimages"
Hi Waaren,
Thanks for this info.
I played a bit but for me it seems to academic (syntax).
Would it be possible that you give kind of practic example?
TIA
-Bart
TIA
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- waaren
Sure, if you have a dzVents script in where you want to use the setIcon() method and an icon number you uploaded, I will show you how it can be done.
I use it in below dzVents script but because of some of the other techniques used in that code I don't know if it will help or confuse you more.
dz Moonphase script
Version 1.03
dzVents >= 3.0.1)
More info https://github.com/JoopIdema/dz-MoonPhases and dz forum https://www.domoticz.com/forum/search.php?keywords=Moonphase
local scriptVar = 'moonScript'
local api_key = 'Obscured'
local town = 'Rotterdam'
return
on =
timer =
'at 00:11',
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG,
marker = scriptVar,
execute = function(dz, item)
if not( item.isHTTPResponse ) then
dz.openURL(
url = 'https://weather.ls.hereapi.com/weather/1.0/report.json?apiKey=' .. api_key .. '&product=forecast_astronomy&name=' .. town ,
method = 'GET',
callback = scriptVar,
return
local firstIcon = 100
local moonPhaseIDX = 164
local function make24hTime(myTime)
local pattern = "(%d+)%:(%d+)(%w*)"
local hour, minute, meridiem = myTime:match(pattern)
return string.format("%02d:%02d", ( meridiem == 'PM' and ( hour or 0 ) + 12 or ( hour or 0 )), minute or 0)
local function makeMoonPhase(phase)
local moonPhaseTable =
['new moon'] = { 1, 'Nieuwe maan'},
['waxing crescent'] = { 2, 'Wassende halve maan'},
['first quarter'] = { 3, 'Eerste kwartier'},
['waxing gibbous'] = { 4, 'Wassende maan'},
['full moon'] = { 5, 'Volle maan'},
['waning gibbous'] = { 6, 'Afnemende maan'},
['last quarter'] = { 7, 'Laatste kwartier'},
['waning crescent'] = { 8, 'Afnemende halve maan'},
return moonPhaseTable[phase:lower()][1] + firstIcon, moonPhaseTable[phase:lower()][2]
if item.ok and item.isJSON then
local moonPhase = dz.devices('MoonPhase')
-- dz.utils.dumpTable(item.json)
local rt = item.json.astronomy.astronomy[1]
local moonPhasePercentage = math.abs(rt.moonPhase * 100)
local moonPhaseIconNumber, moonPhaseName= makeMoonPhase(rt.moonPhaseDesc)
local currentIcon = math.tointeger((moonPhase.icon):gsub('MoonPhases',''):sub(1,1) + firstIcon)
dz.devices('MoonPhaseDesc').updateText(moonPhaseName .. '\nmoonrise: ' .. make24hTime(rt.moonrise) .. '\nmoonset: ' .. make24hTime(rt.moonset))
dz.devices('MoonPhase').updateCustomSensor(moonPhasePercentage)
if currentIcon ~= moonPhaseIconNumber then dz.devices('MoonPhase').setIcon(moonPhaseIconNumber) end
dz.log('moonPhasePercentage: ' .. moonPhasePercentage, dz.LOG_DEBUG)
dz.log('moonPhaseIcon: ' .. dz.devices('MoonPhase').icon, dz.LOG_DEBUG)
dz.log('There was a problem handling the request', dz.LOG_ERROR)
dz.log(item, dz.LOG_ERROR)
Dear Waaren, I hoped you might make available an example using the http:/domoticz-ip,domoticz-port etc syntax.
That way It would be possible to change an icon from a device such as esp-easy as well other network devices too. Can you give me a hand on this?
Bart
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2024.7
Why not make a virtual switch instead of a text device? Then you have an on/off icon. If you want to make a custom icon garden lights then you can do that too. No need to do a complicated thing with scripts, just update the device status on/off with the domotica API/json from Arduino.
- waaren
I already did earlier in this topic.BartSr wrote: ↑Saturday 16 January 2021 16:22 Dear Waaren, I hoped you might make available an example using the http:/domoticz-ip,domoticz-port etc syntax.
in this post
Dear Waaren. That one I referred to when I spoke about "academic" .
I know once you know how to interprete the syntax it's pretty easy. But the otherway around it might, as for me, have an academic look....
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- waaren
http://192.168.192.115:8084/json.htm?type=setused&used=true&name=MoonPhase&description=&idx=164&switchtype=0&customimage=102
the idx of this Sensor = 164 and is a Generic device type (0)
The customImage number can be found
using
cd <domoticz dir>
cd /opt/domoticz
- Spoiler: show
Waaren, thanks a lot. This makes sense to me. Going to try and will of course revert with results.
-Bart
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
but I can't figure out how to actually change the icons to on or off. If I write down the numbers assigned to the icons, the group of icons (where there are two icons on and off) has only one number...
