Can´t get Domoticz to show right temperature data from Aqara Temperature and Pressure sensor via zigbee2mqtt
McLund
Post by McLund »
Hi there.
I think I need a little help..... ;-)
I can´t get Domoticz to show right temperature data from my WSDCGQ11LM Aqara Temperature and Pressure sensor via zigbee2mqtt. Domoticz just show only text and not any data as you can see in picture.
2020-12-28 14_35_11-Domoticz - Opera.png (35.63 KiB) Viewed 776 times
But, it looks like Domoticz can see the sensor in right way....
2020-12-28 14_45_11-Domoticz - Opera.png (42.22 KiB) Viewed 776 times
All works fine in server as you can see in picture.
2020-12-28 17_17_38-raspberrypi - KiTTY (ONTOP).png (77.61 KiB) Viewed 776 times
Domoticz server runs in an Raspberry Pi 3B+.
About Domoticz
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
zigbee2mqtt
Sniffer CC2531
node --version = v12.20.0
npm --version = 6.14.10
Thank you for all help!
Happy New Year! ;)
Best regard´s
McLund in warm and not snowy Sweden
rodaman
Re: Can´t get Domoticz to show right temperature data from Aqara Temperature and Pressure sensor via zigbee2mqtt
Post by rodaman »
Try to pair few times more by pressing buton on sensor for 6 sec. My was added after several tries.
rodaman
Post by rodaman »
Also try to plug off and plug in sniffer.
McLund
Post by McLund »
Hey rodaman.
Tnx for your tips, but hey Houston, we just got some new problems here..... ;-)
Now will the CC2531 sniffer shutdown (green lights turn off) after ca one minute after Raspberry reboot... This problem is new....
So I must find a solution on these sniffer problems first I suppose.
I will be in touched,
Best regard´s
McLund
McLund
Post by McLund »
Hi again.
Now is CC2531 sniffer up´n running again. I have just forget to run "sudo systemctl enable zigbee2mqtt.service"...... :D
But, I can´t get Domoticz to show right temperature data from my WSDCGQ11LM Aqara Temperature and Pressure sensor via zigbee2mqtt. Domoticz only show text and not any real data as you can see in picture in my first post.
So, I would be very happy if anyone can help me with these case.
Best regard´s
McLund in colder Sweden
