Dashticz v3.7.2 beta (read update instructions!!)
Lokonli
Post by Lokonli »
A new beta release.
Update instructions
I've removed 'custom/custom.css' and 'custom/custom.js' from the Dashticz repository, because these are user configuration files, and should not be part of the Dashticz repository.
However, that means this update cannot be installed with git pull directly, because then git will report an error if you have modified one or both files.
To solve this, first make a backup of these two files:
mv custom/custom.js custom/custom.js.bak
mv custom/custom.css custom/custom.css.bak
And if you use the custom_2 folder, then repeat this for that folder:
mv custom_2/custom.js custom_2/custom.js.bak
mv custom_2/custom.css custom_2/custom.css.bak
Then update to the latest version as usual:
git pull
And restore your backups::
mv custom/custom.js.bak custom/custom.js
mv custom/custom.css.bak custom/custom.css
and for custom_2:
mv custom_2/custom.js.bak custom_2/custom.js
mv custom_2/custom.css.bak custom_2/custom.css
You only have to do this once: Next updates can be installed with a normal 'git pull'
Enhancements
  • Calendar: New block parameter 'emptytext' to define the text to show where there are no calendar appointments. Only works for the new calendar block.
  • Custom graph: aggregate parameter can be an array to specify different aggregation methods per data element.
  • Graph: New parameters 'axisRight' to show the first Y axis on the right (default is 'false'), and 'axisAlternating' to show Y axes alternating left/right (default: 'true').
  • Support for device (sub)type Managed Counter
  • Flipclock: New block parameters showSeconds (true or false) and clockFace (12 or 24)
  • Security panel: New block parameters ( decorate, headerText, footerText, scale).
Fixes
  • Graph: Fix for data acquistion day graph gas device.
  • Colorpicker: Some fixes in warm white/cold white color setting.
  • Improved styling of modal popup windows.
Release notes
https://dashticz.readthedocs.io/en/beta ... notes.html
Last edited by Lokonli on Tuesday 29 December 2020 10:10, edited 2 times in total.
pvklink
Domoticz version: latest b
Re: Dashticz v3.7.2 beta (read update instructions!!)
Post by pvklink »
Hi @lokonli
I use two custom folders
custom and custom_2
Do i have to rename both folders before upgrading ?
and you move the bak file to the same name !
mv custom/custom.css.bak custom/custom.css.bak
Jablotron connection, Ikea
Lokonli
Post by Lokonli »
pvklink wrote: Tuesday 29 December 2020 9:36 Hi @lokonli
custom and custom_2
Yes, and thanks, I've updated the instructions in the first post.
pvklink
Post by pvklink »
Hi, i changed my update procedure, but still no update!
#!/bin/bash
# update van dashticz/ Eerst een copy,m dan update. Als t fout gaat nieuwe folder rename naar oud en de bck de nieuwe naam geven
echo "please standby... (Bezig met backuppen Dashticz)"
sudo cp -R /home/pi/dashticz /home/pi/dashticz_bck
cd /home/pi/dashticz
echo "please standby... (Bezig met renamen custom files)"
#echo "please standby... (Bezig met updaten Dashticz)"
sudo git pull
#echo "please standby... (Bezig met updaten Dashticz patch)"
#sudo git checkout beta
#sudo git pull
pvklink
Post by pvklink »
when i move the files and do a git pull
git pull i get:
Updating bd8b65e..cd4f3a6
error: Your local changes to the following files would be overwritten by merge:
dist/bundle.js
docs/blocks/domoticzblocks.rst
docs/blocks/graphs.rst
docs/blocks/specials/clock.rst
docs/blocks/specials/security_panel.rst
docs/releasenotes/releasenotes.rst
index.html
js/blocktypes.js
js/colorpicker.js
js/components/calendar.js
js/components/flipclock.js
js/components/garbage.js
js/components/graph.js
js/components/secpanel.js
js/dt_function.js
src/templateengine.js
tpl/secpanel.tpl
version.txt
Please commit your changes or stash them before you merge.
Aborting
Lokonli
Post by Lokonli »
pvklink wrote: Tuesday 29 December 2020 10:31 when i move the files and do a git pull
git pull i get:
dist/bundle.js
index.html
js/blocktypes.js
js/colorpicker.js
js/dt_function.js
tpl/secpanel.tpl
version.txt
Aborting
Can it be that you did some manual copying of files in the past?
Can you post the output of 'git status'?
Recipe to return to an unchanged state:
First make a backup of the complete Dashticz folder (just to be able to recover from errors ...)
Start from the Dashticz home folder. Then:
The script below assumes that your dashticz folder is named 'dashticz'.
Change it to your own dashticz folder name (two lines)
#Go to the parent
cd ..
#Create a copy (can take some time! Be patient ...)
cp -r dashticz dashticzbak
#Enter Dashticz folder
cd dashticz
#Move the configuration files if not done already
#Bring back your local repository to a clean state. This will delete all files that you changed
#The renamed files custom.css and custom.js will not be deleted.
git reset --hard HEAD
#Update to the latest version
git pull
#Move back your configuration files
You can remove your Dashticz backup folder after testing.
From the dashticz parent folder:
rm -r dashticzbak
And then next time, just a simple 'git pull' in the Dashticz folder will be sufficient :)
pvklink
Post by pvklink »
git status
On branch beta
Your branch is behind 'origin/beta' by 23 commits, and can be fast-forwarded.
  (use "git pull" to update your local branch)
Changes not staged for commit:
  (use "git add/rm <file>..." to update what will be committed)
  (use "git checkout -- <file>..." to discard changes in working directory)
        modified:   .babelrc
        modified:   .eslintrc.js
        modified:   .gitignore
        modified:   .jsbeautifyrc
        modified:   .prettierignore
        modified:   .prettierrc
        modified:   .vscode/settings.json
        modified:   Dockerfile
        modified:   Makefile
        modified:   README.md
        modified:   babel.config.js
        modified:   bin/glob-ls.js
        modified:   css/helpers.css
        modified:   css/plugins.css
        modified:   css/sortable.css
        deleted:    custom/CONFIG_DEFAULT.js
        deleted:    custom/custom.DEFAULT.js
        deleted:    custom/custom.css
        deleted:    custom/custom.js
        deleted:    custom_2/CONFIG_DEFAULT.js
        deleted:    custom_2/custom.css
        deleted:    custom_2/custom.js
        modified:   dist/assets/fonts/fa-brands-400.eot
        modified:   dist/assets/fonts/fa-brands-400.svg
        modified:   dist/assets/fonts/fa-brands-400.ttf
        modified:   dist/assets/fonts/fa-brands-400.woff
        modified:   dist/assets/fonts/fa-brands-400.woff2
        modified:   dist/assets/fonts/fa-regular-400.eot
        modified:   dist/assets/fonts/fa-regular-400.svg
        modified:   dist/assets/fonts/fa-regular-400.ttf
        modified:   dist/assets/fonts/fa-regular-400.woff
        modified:   dist/assets/fonts/fa-regular-400.woff2
        modified:   dist/assets/fonts/fa-solid-900.eot
        modified:   dist/assets/fonts/fa-solid-900.svg
        modified:   dist/assets/fonts/fa-solid-900.ttf
        modified:   dist/assets/fonts/fa-solid-900.woff
        modified:   dist/assets/fonts/fa-solid-900.woff2
        modified:   dist/assets/fonts/glyphicons-halflings-regular.eot
        modified:   dist/assets/fonts/glyphicons-halflings-regular.svg
        modified:   dist/assets/fonts/glyphicons-halflings-regular.ttf
        modified:   dist/assets/fonts/glyphicons-halflings-regular.woff
        modified:   dist/assets/fonts/glyphicons-halflings-regular.woff2
        modified:   dist/assets/images/ui-icons_444444_256x240.png
        modified:   dist/assets/images/ui-icons_555555_256x240.png
        modified:   dist/assets/images/ui-icons_777620_256x240.png
        modified:   dist/assets/images/ui-icons_777777_256x240.png
        modified:   dist/assets/images/ui-icons_cc0000_256x240.png
        modified:   dist/assets/images/ui-icons_ffffff_256x240.png
        modified:   dist/bundle.js
        modified:   docs/Makefile
        modified:   docs/_static/.gitignore
        modified:   docs/_static/css/custom.css
        modified:   docs/_themes/sphinx_rtd_theme/__init__.py
        modified:   docs/_themes/sphinx_rtd_theme/breadcrumbs.html
        modified:   docs/_themes/sphinx_rtd_theme/footer.html
        modified:   docs/_themes/sphinx_rtd_theme/layout.html
        modified:   docs/_themes/sphinx_rtd_theme/search.html
        modified:   docs/_themes/sphinx_rtd_theme/searchbox.html
        modified:   docs/_themes/sphinx_rtd_theme/static/css/badge_only.css
        modified:   docs/_themes/sphinx_rtd_theme/static/css/theme.css
        modified:   docs/_themes/sphinx_rtd_theme/static/fonts/FontAwesome.otf
        modified:   docs/_themes/sphinx_rtd_theme/static/fonts/fontawesome-webfont.eot
        modified:   docs/_themes/sphinx_rtd_theme/static/fonts/fontawesome-webfont.svg
        modified:   docs/_themes/sphinx_rtd_theme/static/fonts/fontawesome-webfont.ttf
        modified:   docs/_themes/sphinx_rtd_theme/static/fonts/fontawesome-webfont.woff
        modified:   docs/_themes/sphinx_rtd_theme/static/fonts/fontawesome-webfont.woff2
        modified:   docs/_themes/sphinx_rtd_theme/static/js/modernizr.min.js
        modified:   docs/_themes/sphinx_rtd_theme/static/js/theme.js
        modified:   docs/_themes/sphinx_rtd_theme/theme.conf
        modified:   docs/_themes/sphinx_rtd_theme/versions.html
        modified:   docs/blocks/blocks.rst
        modified:   docs/blocks/buttons.rst
        modified:   docs/blocks/domoticzblocks.rst
        modified:   docs/blocks/frames.rst
        modified:   docs/blocks/framesexample.jpg
        modified:   docs/blocks/graphs.rst
        modified:   docs/blocks/img/659_1_2.jpg
        modified:   docs/blocks/img/block659.jpg
        modified:   docs/blocks/img/block659_4_custom.jpg
        modified:   docs/blocks/img/block659_w3.jpg
        modified:   docs/blocks/img/block_another.jpg
        modified:   docs/blocks/img/climate.jpg
        modified:   docs/blocks/img/climate_te_hu.jpg
        modified:   docs/blocks/img/colorpicker1.jpg
        modified:   docs/blocks/img/cprgb.jpg
        modified:   docs/blocks/img/cprgbw.jpg
        modified:   docs/blocks/img/cprgbwwz.jpg
        modified:   docs/blocks/img/customlabels.jpg
        modified:   docs/blocks/img/dial.png
        modified:   docs/blocks/img/evohome.png
        modified:   docs/blocks/img/graph_bar.jpg
        modified:   docs/blocks/img/graph_buttons1.png
        modified:   docs/blocks/img/graph_buttons2.png
        modified:   docs/blocks/img/graph_buttons3.png
        modified:   docs/blocks/img/graph_buttons4.png
        modified:   docs/blocks/img/graph_customheader_after.png
        modified:   docs/blocks/img/graph_customheader_before.png
        modified:   docs/blocks/img/graph_debug.jpg
        modified:   docs/blocks/img/graph_groupByDevice_tooltip1.png
        modified:   docs/blocks/img/graph_groupby_day.png
        modified:   docs/blocks/img/graph_stacked.png
        modified:   docs/blocks/img/graph_zoom_x.jpg
        modified:   docs/blocks/img/graph_zoom_x2.jpg
        modified:   docs/blocks/img/group_by_device_1.png
        modified:   docs/blocks/img/group_by_device_2.png
        modified:   docs/blocks/img/group_by_device_3.png
        modified:   docs/blocks/img/muligraph_patch4_1.png
        modified:   docs/blocks/img/muligraph_patch4_2.png
        modified:   docs/blocks/img/muligraph_patch4_3.png
        modified:   docs/blocks/img/muligraph_patch4_4.png
        modified:   docs/blocks/img/muligraph_patch4_5.png
        modified:   docs/blocks/img/multigraph3.png
        modified:   docs/blocks/img/multigraph4.png
        modified:   docs/blocks/img/multigraph5.png
        modified:   docs/blocks/img/multigraph6.png
        modified:   docs/blocks/img/multigraph_button_styling.jpg
        modified:   docs/blocks/img/multigraph_custom.png
        modified:   docs/blocks/img/multigraph_point_styling.jpg
        modified:   docs/blocks/img/multigraph_setpoints.png
        modified:   docs/blocks/img/p1.jpg
        modified:   docs/blocks/img/p1_custom.jpg
        modified:   docs/blocks/img/p1_legend.jpg
        modified:   docs/blocks/img/p1_legend_2.jpg
        modified:   docs/blocks/img/solar_1_default.jpg
        modified:   docs/blocks/img/solar_custom_legend.jpg
        modified:   docs/blocks/img/solar_default.jpg
        modified:   docs/blocks/img/solar_legend.jpg
        modified:   docs/blocks/img/solar_yellow_bar.jpg
        modified:   docs/blocks/img/tooltiptotal_array.png
        modified:   docs/blocks/img/tooltiptotal_false.png
        modified:   docs/blocks/img/tooltiptotal_true.png
        modified:   docs/blocks/img/water.jpg
        modified:   docs/blocks/specials.rst
        modified:   docs/blocks/specials/Stationclock.jpg
        modified:   docs/blocks/specials/alarmmeldingen.JPG
        modified:   docs/blocks/specials/alarmmeldingen.rst
        modified:   docs/blocks/specials/blocktitle.rst
        modified:   docs/blocks/specials/calendar.jpg
        modified:   docs/blocks/specials/calendar.rst
        modified:   docs/blocks/specials/camera_block.gif
        modified:   docs/blocks/specials/camera_block.jpg
        modified:   docs/blocks/specials/cameras.rst
        modified:   docs/blocks/specials/clock.jpg
        modified:   docs/blocks/specials/clock.rst
        modified:   docs/blocks/specials/clocks.jpg
        modified:   docs/blocks/specials/custom9292.png
        modified:   docs/blocks/specials/customstreamplayer.png
        modified:   docs/blocks/specials/dial.rst
        modified:   docs/blocks/specials/domoticzlog.png
        modified:   docs/blocks/specials/domoticzlog.rst
        modified:   docs/blocks/specials/garbage.rst
        modified:   docs/blocks/specials/gmChooseMaps.png
        modified:   docs/blocks/specials/googlemaps.png
        modified:   docs/blocks/specials/googlemaps.rst
        modified:   docs/blocks/specials/haymanclock.jpg
        modified:   docs/blocks/specials/html.rst
        modified:   docs/blocks/specials/img/blocktitle.jpg
        modified:   docs/blocks/specials/img/calendar0.png
        modified:   docs/blocks/specials/img/calendar1.jpg
        modified:   docs/blocks/specials/img/calendar1.png
        modified:   docs/blocks/specials/img/calendar2.png
        modified:   docs/blocks/specials/img/calendar2_modal.png
        modified:   docs/blocks/specials/img/dial_dimmer.jpg
        modified:   docs/blocks/specials/img/dial_on-of_switch.jpg
        modified:   docs/blocks/specials/img/dial_p1-meter-cons.jpg
        modified:   docs/blocks/specials/img/dial_p1-meter-prod.jpg
        modified:   docs/blocks/specials/img/dial_temp-hum-baro.jpg
        modified:   docs/blocks/specials/img/dial_temp-humidity.jpg
        modified:   docs/blocks/specials/img/dial_wind.jpg
        modified:   docs/blocks/specials/img/dials.jpg
        modified:   docs/blocks/specials/img/flipclock.jpg
        modified:   docs/blocks/specials/img/haymanclock.jpg
        modified:   docs/blocks/specials/img/hb-dial.jpg
        modified:   docs/blocks/specials/img/humbar-dial.jpg
        modified:   docs/blocks/specials/img/longfonds.jpg
        modified:   docs/blocks/specials/img/miniclock.jpg
        modified:   docs/blocks/specials/img/timechart.gif
        modified:   docs/blocks/specials/img/timechart2.jpg
        modified:   docs/blocks/specials/img/timechart3.jpg
        modified:   docs/blocks/specials/img/toon_dial.jpg
        modified:   docs/blocks/specials/img/trafficinfo.jpg
        modified:   docs/blocks/specials/img/weatherwidget.jpg
        modified:   docs/blocks/specials/longfonds.rst
        modified:   docs/blocks/specials/moon.17.png
        modified:   docs/blocks/specials/moon.rst
        modified:   docs/blocks/specials/news.jpg
        modified:   docs/blocks/specials/news.rst
        modified:   docs/blocks/specials/nzbget.rst
        modified:   docs/blocks/specials/publictransport.rst
        modified:   docs/blocks/specials/secpanel.jpg
        modified:   docs/blocks/specials/security_panel.rst
        modified:   docs/blocks/specials/security_panel_block.jpg
        modified:   docs/blocks/specials/security_panel_frame.jpg
        modified:   docs/blocks/specials/sonarr.rst
        modified:   docs/blocks/specials/spotify.rst
        modified:   docs/blocks/specials/streamplayer.rst
        modified:   docs/blocks/specials/sunrise.jpg
        modified:   docs/blocks/specials/sunrise.rst
        modified:   docs/blocks/specials/timegraph.rst
        modified:   docs/blocks/specials/topbar.rst
        modified:   docs/blocks/specials/trafficinfo.rst
        modified:   docs/blocks/specials/traffictrain.png
        modified:   docs/blocks/specials/tv-guide.png
        modified:   docs/blocks/specials/tvguide.rst
        modified:   docs/blocks/specials/weather.rst
        modified:   docs/blocks/specials/weather_owm.png
        modified:   docs/blocks/specials/ziggohorizon.rst
        modified:   docs/columns.rst
        modified:   docs/conf.py
        modified:   docs/configuration.rst
        modified:   docs/customcss/Bulb_rgba.jpg
        modified:   docs/customcss/Customcode_bulb.jpg
        modified:   docs/customcss/Lmslargebuttons.jpg
        modified:   docs/customcss/block_120_css.jpg
        modified:   docs/customcss/block_120_lastupdate.jpg
        modified:   docs/customcss/cust_drop_down_block.jpg
        modified:   docs/customcss/customcss.rst
        modified:   docs/customcss/specialclasses.jpg
        modified:   docs/customization.rst
        modified:   docs/customjs/customjs.rst
        modified:   docs/dashticzconfiguration.rst
        modified:   docs/develop/code.rst
        modified:   docs/develop/design.rst
        modified:   docs/develop/develop.rst
        modified:   docs/develop/documentation.rst
        modified:   docs/develop/translations.rst
        modified:   docs/gettingstarted/automaticinstall.rst
        modified:   docs/gettingstarted/basicdashboard.rst
        modified:   docs/gettingstarted/guide_step_1.png
        modified:   docs/gettingstarted/guide_step_2.png
        modified:   docs/gettingstarted/index.rst
        modified:   docs/gettingstarted/installation.rst
        modified:   docs/gettingstarted/manualinstall.rst
        modified:   docs/img/dashticz-websocket.gif
        modified:   docs/index.rst
        modified:   docs/introduction.rst
        modified:   docs/make.bat
        modified:   docs/releasenotes/index.rst
        modified:   docs/releasenotes/releasenotes.rst
        modified:   docs/releasenotes/upgrading/upgrading.rst
        modified:   docs/releasenotes/upgrading/v320.rst
        modified:   docs/releasenotes/upgrading/v341.rst
        modified:   docs/releasenotes/upgrading/v349.rst
        modified:   docs/screens.rst
        modified:   docs/tipsandtricks.rst
        modified:   docs/tipsandtricks/buttonimage.jpg
        modified:   docs/troubleshooting/docker.rst
        modified:   docs/troubleshooting/index.rst
        modified:   dz_logo.png
        modified:   font/Audiowide.eot
        modified:   font/Audiowide.svg
        modified:   font/Audiowide.ttf
        modified:   font/Audiowide.woff
        modified:   font/Digital.eot
        modified:   font/Digital.svg
        modified:   font/Digital.ttf
        modified:   font/Digital.woff
        modified:   img/Coltemp48.png
        modified:   img/Customw48.png
        modified:   img/Customww48.png
        modified:   img/RGB48.png
        modified:   img/White48.png
        modified:   img/air.png
        modified:   img/alarm.png
        modified:   img/alarmeringen.png
        modified:   img/bg0.jpg
        modified:   img/bg1.jpg
        modified:   img/bg10.jpg
        modified:   img/bg11.jpg
        modified:   img/bg12.jpg
        modified:   img/bg13.jpg
        modified:   img/bg14.jpg
        modified:   img/bg2.jpg
        modified:   img/bg3.jpg
        modified:   img/bg4.jpg
        modified:   img/bg5.jpg
        modified:   img/bg6.jpg
        modified:   img/bg7.jpg
        modified:   img/bg8.jpg
        modified:   img/bg9.jpg
        modified:   img/bg_afternoon.jpg
        modified:   img/bg_morning.jpg
        modified:   img/bg_night.jpg
        modified:   img/bg_noon.jpg
        modified:   img/blinds_closed.png
        modified:   img/blinds_open.png
        modified:   img/buien_radar.png
        modified:   img/bulb.png
        modified:   img/bulb_off.png
        modified:   img/bulb_on.png
        modified:   img/bulbyellow.png
        modified:   img/bulbyellow_off.png
        modified:   img/bulbyellow_on.png
        modified:   img/coldwarm.jpg
        modified:   img/curtainclosed.png
        modified:   img/curtainopen.png
        modified:   img/dishwasher_240px.png
        modified:   img/dishwasher_off.png
        modified:   img/dishwasher_on.png
        modified:   img/door_closed.png
        modified:   img/door_open.png
        modified:   img/evohome.png
        modified:   img/fan.png
        modified:   img/fan_off.png
        modified:   img/fan_on.png
        modified:   img/favicon/android-chrome-192x192.png
        modified:   img/favicon/apple-touch-icon-114x114.png
        modified:   img/favicon/apple-touch-icon-120x120.png
        modified:   img/favicon/apple-touch-icon-144x144.png
        modified:   img/favicon/apple-touch-icon-152x152.png
        modified:   img/favicon/apple-touch-icon-180x180.png
        modified:   img/favicon/apple-touch-icon-57x57.png
        modified:   img/favicon/apple-touch-icon-60x60.png
        modified:   img/favicon/apple-touch-icon-72x72.png
        modified:   img/favicon/apple-touch-icon-76x76.png
        modified:   img/favicon/favicon-16x16.png
        modified:   img/favicon/favicon-32x32.png
        modified:   img/favicon/favicon-96x96.png
        modified:   img/favicon/favicon.ico
        modified:   img/favicon/largetile.png
        modified:   img/favicon/mediumtile.png
        modified:   img/favicon/smalltile.png
        modified:   img/favicon/widetile.png
        modified:   img/fr24.png
        modified:   img/garbage/kliko.png
        modified:   img/garbage/kliko_black.png
        modified:   img/garbage/kliko_blue.png
        modified:   img/garbage/kliko_brown.png
        modified:   img/garbage/kliko_green.png
        modified:   img/garbage/kliko_grey.png
        modified:   img/garbage/kliko_orange.png
        modified:   img/garbage/kliko_red.png
        modified:   img/garbage/kliko_white.png
        modified:   img/garbage/kliko_yellow.png
        modified:   img/garbage/tree.png
        modified:   img/heating.png
        modified:   img/heating_off.png
        modified:   img/heating_on.png
        modified:   img/hot_water_on.png
        modified:   img/kodi.png
        modified:   img/longfonds.png
        modified:   img/mi_robot.svg
        modified:   img/microphone_off.png
        modified:   img/microphone_on.png
        modified:   img/moon/moon.0.png
        modified:   img/moon/moon.00.png
        modified:   img/moon/moon.01.png
        modified:   img/moon/moon.02.png
        modified:   img/moon/moon.03.png
        modified:   img/moon/moon.04.png
        modified:   img/moon/moon.05.png
        modified:   img/moon/moon.06.png
        modified:   img/moon/moon.07.png
        modified:   img/moon/moon.08.png
        modified:   img/moon/moon.09.png
        modified:   img/moon/moon.10.png
        modified:   img/moon/moon.11.png
        modified:   img/moon/moon.12.png
        modified:   img/moon/moon.13.png
        modified:   img/moon/moon.14.png
        modified:   img/moon/moon.15.png
        modified:   img/moon/moon.16.png
        modified:   img/moon/moon.17.png
        modified:   img/moon/moon.18.png
        modified:   img/moon/moon.19.png
        modified:   img/moon/moon.20.png
        modified:   img/moon/moon.21.png
        modified:   img/moon/moon.22.png
        modified:   img/moon/moon.23.png
        modified:   img/moon/moon.24.png
        modified:   img/moon/moon.25.png
        modified:   img/moon/moon.26.png
        modified:   img/moon/moon.27.png
        modified:   img/moon/moon.28.png
        modified:   img/moon/moon.29.png
        modified:   img/moon/moon.30.png
        modified:   img/moon/moon.31.png
        modified:   img/moon/moon.32.png
        modified:   img/moon/moon.33.png
        modified:   img/moon/moon.34.png
        modified:   img/moon/moon.35.png
        modified:   img/moon/moon.36.png
        modified:   img/moon/moon.37.png
        modified:   img/moon/moon.38.png
        modified:   img/moon/moon.39.png
        modified:   img/moon/moon.40.png
        modified:   img/moon/moon.41.png
        modified:   img/moon/moon.42.png
        modified:   img/moon/moon.43.png
        modified:   img/moon/moon.44.png
        modified:   img/moon/moon.45.png
        modified:   img/moon/moon.46.png
        modified:   img/moon/moon.47.png
        modified:   img/moon/moon.48.png
        modified:   img/moon/moon.49.png
        modified:   img/moon/moon.50.png
        modified:   img/moon/moon.51.png
        modified:   img/moon/moon.52.png
        modified:   img/moon/moon.53.png
        modified:   img/moon/moon.54.png
        modified:   img/moon/moon.55.png
        modified:   img/moon/moon.56.png
        modified:   img/moon/moon.57.png
        modified:   img/moon/moon.58.png
        modified:   img/moon/moon.59.png
        modified:   img/moon/moon.60.png
        modified:   img/moon/moon.61.png
        modified:   img/moon/moon.62.png
        modified:   img/moon/moon.63.png
        modified:   img/moon/moon.64.png
        modified:   img/moon/moon.65.png
        modified:   img/moon/moon.66.png
        modified:   img/moon/moon.67.png
        modified:   img/moon/moon.68.png
        modified:   img/moon/moon.69.png
        modified:   img/moon/moon.70.png
        modified:   img/moon/moon.71.png
        modified:   img/moon/moon.72.png
        modified:   img/moon/moon.73.png
        modified:   img/moon/moon.74.png
        modified:   img/moon/moon.75.png
        modified:   img/moon/moon.76.png
        modified:   img/moon/moon.77.png
        modified:   img/moon/moon.78.png
        modified:   img/moon/moon.79.png
        modified:   img/moon/moon.80.png
        modified:   img/moon/moon.81.png
        modified:   img/moon/moon.82.png
        modified:   img/moon/moon.83.png
        modified:   img/moon/moon.84.png
        modified:   img/moon/moon.85.png
        modified:   img/moon/moon.86.png
        modified:   img/moon/moon.87.png
        modified:   img/moon/moon.88.png
        modified:   img/moon/moon.89.png
        modified:   img/moon/moon.90.png
        modified:   img/moon/moon.91.png
        modified:   img/moon/moon.92.png
        modified:   img/moon/moon.93.png
        modified:   img/moon/moon.94.png
        modified:   img/moon/moon.95.png
        modified:   img/moon/moon.96.png
        modified:   img/moon/moon.97.png
        modified:   img/moon/moon.98.png
        modified:   img/moon/moon.99.png
        modified:   img/motion_off.png
        modified:   img/motion_on.png
        modified:   img/ns.png
        modified:   img/radiator.svg
        modified:   img/radio-streaming.png
        modified:   img/radio.png
        modified:   img/radio_on.png
        modified:   img/roofwindow_closed.svg
        modified:   img/roofwindow_open.svg
        modified:   img/rpi.svg
        modified:   img/sleep.png
        modified:   img/sleep_off.png
        modified:   img/sleep_on.png
        modified:   img/speaker_off.png
        modified:   img/speaker_on.png
        modified:   img/toon.png
        modified:   img/tv.png
        modified:   img/tv_off.png
        modified:   img/uptime.png
        modified:   img/volumio.png
        modified:   img/wii.svg
        modified:   index.html
        modified:   index2.html
        modified:   js/blocktypes.js
        modified:   js/calendar.js
        modified:   js/chromecast.js
        modified:   js/coins.js
        modified:   js/colorpicker.js
        modified:   js/components/alarmmeldingen.js
        modified:   js/components/basicclock.css
        modified:   js/components/basicclock.js
        modified:   js/components/blocktitle.js
        modified:   js/components/button.js
        modified:   js/components/calendar.js
        modified:   js/components/camera.js
        modified:   js/components/coronavirus.js
        modified:   js/components/dial.js
        modified:   js/components/flipclock.css
        modified:   js/components/flipclock.js
        modified:   js/components/frame.js
        modified:   js/components/garbage.js
        modified:   js/components/graph.js
        modified:   js/components/haymanclock.css
        modified:   js/components/haymanclock.js
        modified:   js/components/html.js
        modified:   js/components/longfonds.js
        modified:   js/components/news.js
        modified:   js/components/nzbget.js
        modified:   js/components/publictransport.js
        modified:   js/components/secpanel.js
        modified:   js/components/stationclock.js
        modified:   js/components/streamplayer.js
        modified:   js/components/timegraph.js
        modified:   js/components/traffic.js
        modified:   js/components/trafficinfo.js
        modified:   js/components/train.js
        modified:   js/components/tvguide.js
        modified:   js/dashticz.js
        modified:   js/domoticz-api.js
        modified:   js/dt_function.js
        modified:   js/fullscreen.js
        modified:   js/log.js
        modified:   js/login.js
        modified:   js/main.js
        modified:   js/moon.js
        modified:   js/polyfills.js
        modified:   js/savesettings.php
        modified:   js/settings.js
        modified:   js/sonarr.js
        modified:   js/sortable.js
        modified:   js/spotify.js
        modified:   js/switches.js
        modified:   js/thermostat.js
        modified:   js/version.js
        modified:   js/weather.js
        modified:   js/weather_owm.js
        modified:   jsconfig.json
        modified:   lang/bs_BA.json
        modified:   lang/ca_ES.json
        modified:   lang/cs_CZ.json
        modified:   lang/da_DK.json
        modified:   lang/de_DE.json
        modified:   lang/en_US.json
        modified:   lang/es_ES.json
        modified:   lang/fi_FI.json
        modified:   lang/fr_FR.json
        modified:   lang/hu_HU.json
        modified:   lang/it_IT.json
        modified:   lang/ja_JP.json
        modified:   lang/lt_LT.json
        modified:   lang/nb_NO.json
        modified:   lang/nl_NL.json
        modified:   lang/nn_NO.json
        modified:   lang/pl_PL.json
        modified:   lang/pt_PT.json
        modified:   lang/ro_RO.json
        modified:   lang/ru_RU.json
        modified:   lang/sk_SK.json
        modified:   lang/sl_SI.json
        modified:   lang/sr_RS.json
        modified:   lang/sv_SE.json
        modified:   lang/tr_TR.json
        modified:   lang/uk_UA.json
        modified:   lang/zh_CN.json
        modified:   nginx.conf
        modified:   package-lock.json
        modified:   package.json
        modified:   sounds/airplane.aac
        modified:   sounds/airplane.mp3
        modified:   sounds/airplane.ogg
        modified:   sounds/arm.aac
        modified:   sounds/arm.mp3
        modified:   sounds/arm.ogg
        modified:   sounds/beer_can_opening.aac
        modified:   sounds/beer_can_opening.mp3
        modified:   sounds/beer_can_opening.ogg
        modified:   sounds/bell_ring.aac
        modified:   sounds/bell_ring.mp3
        modified:   sounds/bell_ring.ogg
        modified:   sounds/branch_break.aac
        modified:   sounds/branch_break.mp3
        modified:   sounds/branch_break.ogg
        modified:   sounds/button_click.aac
        modified:   sounds/button_click.mp3
        modified:   sounds/button_click.ogg
        modified:   sounds/button_click_on.aac
        modified:   sounds/button_click_on.mp3
        modified:   sounds/button_click_on.ogg
        modified:   sounds/button_push.aac
        modified:   sounds/button_push.mp3
        modified:   sounds/button_push.ogg
        modified:   sounds/camera_flashing.aac
        modified:   sounds/camera_flashing.mp3
        modified:   sounds/camera_flashing.ogg
        modified:   sounds/computer_error.aac
        modified:   sounds/computer_error.mp3
        modified:   sounds/computer_error.ogg
        modified:   sounds/disarm.aac
        modified:   sounds/disarm.mp3
        modified:   sounds/disarm.ogg
        modified:   sounds/door_bell.aac
        modified:   sounds/door_bell.mp3
        modified:   sounds/door_bell.ogg
        modified:   sounds/door_bump.aac
        modified:   sounds/door_bump.mp3
        modified:   sounds/door_bump.ogg
        modified:   sounds/doorbell.aac
        modified:   sounds/doorbell.mp3
        modified:   sounds/doorbell.ogg
        modified:   sounds/glass.aac
        modified:   sounds/glass.mp3
        modified:   sounds/glass.ogg
        modified:   sounds/key.aac
        modified:   sounds/key.mp3
        modified:   sounds/key.ogg
        modified:   sounds/light_bulb_breaking.aac
        modified:   sounds/light_bulb_breaking.mp3
        modified:   sounds/light_bulb_breaking.ogg
        modified:   sounds/ping.aac
        modified:   sounds/ping.mp3
        modified:   sounds/ping.ogg
        modified:   sounds/pop_cork.aac
        modified:   sounds/pop_cork.mp3
        modified:   sounds/pop_cork.ogg
        modified:   sounds/snap.aac
        modified:   sounds/snap.mp3
        modified:   sounds/snap.ogg
        modified:   sounds/sonar.aac
        modified:   sounds/sonar.mp3
        modified:   sounds/sonar.ogg
        modified:   sounds/tap.aac
        modified:   sounds/tap.mp3
        modified:   sounds/tap.ogg
        modified:   sounds/water_droplet.aac
        modified:   sounds/water_droplet.mp3
        modified:   sounds/water_droplet.ogg
        modified:   sounds/wrongcode.aac
        modified:   sounds/wrongcode.mp3
        modified:   sounds/wrongcode.ogg
        modified:   src/functions.js
        modified:   src/handlebars-helpers.js
        modified:   src/index.js
        modified:   src/templateengine.js
        modified:   switch_horizon.php
        modified:   themes/white/white.css
        modified:   tpl/calendar_0.tpl
        modified:   tpl/calendar_1.tpl
        modified:   tpl/calendar_2_event.tpl
        modified:   tpl/calendar_2_modal.tpl
        modified:   tpl/calendar_2_template.tpl
        modified:   tpl/calendar_modal_iframe.tpl
        modified:   tpl/camera_image.tpl
        modified:   tpl/camera_video.tpl
        modified:   tpl/clock_hayman.tpl
        modified:   tpl/colorpicker.tpl
        modified:   tpl/corona_graph_header.tpl
        modified:   tpl/corona_report.tpl
        modified:   tpl/dial.tpl
        modified:   tpl/garbage_0.tpl
        modified:   tpl/garbage_1.tpl
        modified:   tpl/garbage_2.tpl
        modified:   tpl/graph_header.tpl
        modified:   tpl/graph_tooltip.tpl
        modified:   tpl/graph_tooltip_table.tpl
        modified:   tpl/news_modal.tpl
        modified:   tpl/news_row.tpl
        modified:   tpl/secpanel.tpl
        modified:   tpl/secpanel_modal.tpl
        modified:   tpl/thermostat_block.tpl
        modified:   tpl/thermostat_evo_cont.tpl
        modified:   tpl/thermostat_evo_hw.tpl
        modified:   tpl/thermostat_evo_zone.tpl
        modified:   tpl/traffic.tpl
        modified:   vendor/dashticz/cors.php
        modified:   vendor/dashticz/garbage/index.php
        modified:   vendor/dashticz/ical/composer.json
        modified:   vendor/dashticz/ical/composer.lock
        modified:   vendor/dashticz/ical/ical5/SG_iCal.php
        modified:   vendor/dashticz/ical/ical5/blocks/SG_iCal_VCalendar.php
        modified:   vendor/dashticz/ical/ical5/blocks/SG_iCal_VEvent.php
        modified:   vendor/dashticz/ical/ical5/blocks/SG_iCal_VTimeZone.php
        modified:   vendor/dashticz/ical/ical5/helpers/SG_iCal_Duration.php
        modified:   vendor/dashticz/ical/ical5/helpers/SG_iCal_Factory.php
        modified:   vendor/dashticz/ical/ical5/helpers/SG_iCal_Freq.php
        modified:   vendor/dashticz/ical/ical5/helpers/SG_iCal_Line.php
        modified:   vendor/dashticz/ical/ical5/helpers/SG_iCal_Parser.php
        modified:   vendor/dashticz/ical/ical5/helpers/SG_iCal_Query.php
        modified:   vendor/dashticz/ical/ical5/helpers/SG_iCal_Recurrence.php
        modified:   vendor/dashticz/ical/ical5/index.php
        modified:   vendor/dashticz/ical/index.php
        modified:   vendor/dashticz/ical/vendor/autoload.php
        modified:   vendor/dashticz/ical/vendor/composer/ClassLoader.php
        modified:   vendor/dashticz/ical/vendor/composer/LICENSE
        modified:   vendor/dashticz/ical/vendor/composer/autoload_classmap.php
        modified:   vendor/dashticz/ical/vendor/composer/autoload_namespaces.php
        modified:   vendor/dashticz/ical/vendor/composer/autoload_psr4.php
        modified:   vendor/dashticz/ical/vendor/composer/autoload_real.php
        modified:   vendor/dashticz/ical/vendor/composer/autoload_static.php
        modified:   vendor/dashticz/ical/vendor/composer/installed.json
        modified:   vendor/dashticz/ical/vendor/om/icalparser/.github/workflows/php.yml
        modified:   vendor/dashticz/ical/vendor/om/icalparser/.gitignore
        modified:   vendor/dashticz/ical/vendor/om/icalparser/LICENSE
        modified:   vendor/dashticz/ical/vendor/om/icalparser/composer.json
        modified:   vendor/dashticz/ical/vendor/om/icalparser/example/index.php
        modified:   vendor/dashticz/ical/vendor/om/icalparser/readme.md
        modified:   vendor/dashticz/ical/vendor/om/icalparser/src/Freq.php
        modified:   vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php
        modified:   vendor/dashticz/ical/vendor/om/icalparser/src/Recurrence.php
        modified:   vendor/dashticz/ical/vendor/om/icalparser/src/WindowsTimezones.php
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/blank_description.phpt
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/38_weekly_recurring_event_missing_day.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/FrenchHolidays.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/basic.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/missing_RRULE_notice.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/multiline_description.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/readme.md
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/recur_instances_with_modifications.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/recur_instances_with_modifications_and_interval.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/url.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/weird_windows_timezones.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/cal/wrong_dates.ics
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/multiline_description.phpt
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/multiple_attachments.phpt
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/recurring_events.phpt
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/sort_events.phpt
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/timezone.phpt
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/url.phpt
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tests/wrong_dates.phpt
        modified:   vendor/dashticz/ical/vendor/om/icalparser/tools/windowstimezones.php
        modified:   vendor/dashticz/info.php
        modified:   vendor/dashticz/nocache.php
        modified:   vendor/jquery.newsTicker.min.js
        modified:   vendor/stationclock.js
        modified:   vendor/weather/css/weather-icons-wind.min.css
        modified:   vendor/weather/css/weather-icons.min.css
        modified:   vendor/weather/font/weathericons-regular-webfont.eot
        modified:   vendor/weather/font/weathericons-regular-webfont.svg
        modified:   vendor/weather/font/weathericons-regular-webfont.ttf
        modified:   vendor/weather/font/weathericons-regular-webfont.woff
        modified:   vendor/weather/font/weathericons-regular-webfont.woff2
        modified:   version.txt
        modified:   webpack.config.js
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        img/pvk_blind_off.png
        img/pvk_blind_on.png
        img/pvk_blindorg_off.png
        img/pvk_microphone_off.png
        img/pvk_microphone_on.png
no changes added to commit (use "git add" and/or "git commit -a")
pvklink
Post by pvklink »
ok, i used your script.
I changed the first line in cd /home/pi thats where my dashticz folder is...
And then runned the script...
everything went OK.
can i use your script as a future standard for updating beta dashticz or is this script only useful for this situatation ?
I will check my two configuartions
- one for my desktop (custom)
- one for my wall tablet
Only thing i can see this far is that my security panel has become greater and has an overlap with my other buttons (that are on the right of the panel
i use these setting in my css file
/* security panel */
/* div[data-id='secpanel'] {background-color: rgba(87, 64, 56, 1) !important; } dit is het block achter het zwarte secpanel, als je dit weglaat is het bruine block niet zichtbaar wel nodig als je eronder blokken wil tonen */
[data-id='secpanel'] .dt_content {height: 360px!important; width: 260px!important; }
div[data-id='secpanel'] {height: 400px !important;width: 340px!important;}
Lokonli
Post by Lokonli »
pvklink wrote: Tuesday 29 December 2020 11:37 ok, i used your script.
everything went OK.
The script is only needed in case something is messed up.
Normally you only have to do 'git pull'. This will always be risk free: git pull will not overwrite files you've changed.
In 3.7.2 there are indeed some changes in the css styling of the security panel.
I would expect there is no need anymore to set the height/width manually in custom.css. You can remove both lines from custom.css.
The security panel automatically scales to the width of the column. If it's too wide, set the block parameter 'scale ' to for instance 0.8 to scale it to 80% of the column width.
pvklink
Post by pvklink »
ok, clear!
I also tried:
blocks['secpanel'] = {width: 12, headerText: 'test',footerText: 'test2'}
This works ok on my desktop with custom folder settings on safari
When i use this in custom_2 folder for my rpi with small touchschreen and default buster browser it does not show the headerText and footerText ( shows the default)...
Lokonli
Post by Lokonli »
pvklink wrote: Tuesday 29 December 2020 13:19 ok, clear!
I also tried:
Probably a caching issue. I fixed this in index.html, but forgot to update index2.html.
I already made a change to beta.
Can you update to the latest version?
Just do a 'git pull' :)
pvklink
Post by pvklink »
i will..
pvklink
Post by pvklink »
And it works !!!
Do i have to test more securitypanel stuff ?
Lokonli
Post by Lokonli »
pvklink wrote: Tuesday 29 December 2020 14:19 And it works !!!
Can you test with decorate:false and your pi screen?
pvklink
Post by pvklink »
Works!
ThirstyThursten
Domoticz version: 2021.1
Post by ThirstyThursten »
Man Dashticz is giving me so much trouble lately..
I wanna try to update to the beta to see if it than at least uses my custom css, because right now it doesn't use ANY of my custom css.. But I'll open another topic for that.
So how does this work every time I try to do a git command I get the "fatal: not a git repository (or any of the parent directories): .git"
Now I just did a git clone into the folder /home/pi/dashticz which created an extra nested folder called dashticz with the actual stuff in it.
So how do I update it to the latest beta?
Secondly, is the documentation completely up to date?
I sometimes have a little trouble getting stuff to work because of the different syntaxes. I started way back when Dashticz V2 was just new, than I didn't touch it for a while DashticzV3 I believe or even after that changed the whole way the config was written.
Hope you guys can help me!
Thanks in advance!
Greets!
Lokonli
Post by Lokonli »
I can help :)
In case you come from an early version then I would recommend to make a fresh install.
You could try the automatic install first see:
https://dashticz.readthedocs.io/en/mast ... stall.html
Dashticz then should be up and running.
copy your old CONFIG.js, custom.css and custom.js to the new custom folder.
Most changes in the configuration are additions. There will be (at least) one breaking change for button images. See:
https://dashticz.readthedocs.io/en/mast ... tml#button
There are a few more changes related to custom.js.
For an example:
https://dashticz.readthedocs.io/en/mast ... -idx-block
ThirstyThursten
Thanks Lokonli, I am on the most recent release on the master branch.
However my Domoticz installation and Raspbnian image I'm using now have become somewwhat instable. So I think I'll just reinstall everything to a new SD Card and than move the appropriate files over to the new system! :)
So that will than work out! Thanks bud! :)
Lokonli
Post by Lokonli »
ok, if you encounter additional issues with updating the config files you can post your questions on the forum.
