Definition stationclock in css
Enz0jacco
Post by Enz0jacco »
hi guys, (Lokonli probably :P)
I'm trying to make the stationclock bigger on the standby screen.
all I manage to do now is center the clock within the screen but i'm unable to make the clock bigger.
this is what i tried:
.standby .stationclock {
display: flex !important;
justify-content: center !important;
align-items: center !important;
height: 800px !important; }
it seems that the container in which the clock exists is getting bigger but not the clock itself.
am I forgetting something behind the .stationclock?
thnx again!
Lokonli
Re: Definition stationclock in css
Post by Lokonli »
Enz0jacco wrote: Monday 07 December 2020 20:05 hi guys, (Lokonli probably :P)
thnx again!
Challenge accepted :)
It was not possible to set the size of the station clock.
I've changed that in latest beta.
By default the size of the stationclock will be the block width.
If needed, you can overrule the size by setting the block parameter 'size' of the station clock block.
blocks['stationclock'] = {
  width: 6
Enz0jacco
Post by Enz0jacco »
thnx for the quick reply (as always) !
unfortunately this doesn't work.
just to be sure, this code is for the config.js right?
i deleted everything in css and just put your code in config.js.
Lokonli
Post by Lokonli »
Did you update your Dashticz version?
(git pull)
Enz0jacco
Post by Enz0jacco »
oops :P
Lokonli
Post by Lokonli »
  width: 1,
blocks['stationclock2'] = {
  type: 'stationclock',
  width: 2,
blocks['stationclock3'] = {
  width: 3,
blocks['stationclock6'] = {
  width: 6,
blocks['stationclock12'] = {
  width: 12,
var columns = {};
columns[1] = {};
columns[1]['blocks'] = [
  'stationclock',
  'stationclock2',
  'stationclock3',
  'stationclock6',
  {type: 'stationclock', width: 12, size: 50},
  {type: 'stationclock', width: 12, size: 250}
columns[1]['width'] = 6;
columns[2] = {};
columns[2]['blocks'] = ['stationclock12'];
columns[2]['width'] = 6;
Lokonli
Post by Lokonli »
Fun fact:
As you can see the station clock is 2 seconds ahead of the digital time in the top bar.
The reason is:
The red second dial of the station clock will make a round in 58 seconds. At the whole minute it will wait two seconds to 'synchronize' the time again. :)
Enz0jacco
Post by Enz0jacco »
Haha didn’t notice that one. But I use it on the standby screen anyway. Are there are other layout clocks available as well? The boss doesn’t think this clock is tastefull with the rest of the interior...
Sent from my iPad using Tapatalk
HansieNL
Post by HansieNL »
Enz0jacco wrote: Wednesday 09 December 2020 13:30 Haha didn’t notice that one. But I use it on the standby screen anyway. Are there are other layout clocks available as well? The boss doesn’t think this clock is tastefull with the rest of the interior...
There's also a flipclock. You can add it by adding 'flipclock' to a column.
Blah blah blah
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Lokonli
Post by Lokonli »
That's indeed the station clock that is used at the moment. I can make available the configuration parameters.
One of the following could also be implemented:
https://freefrontend.com/css-clocks/
madpatrick
Those are real cool. !!
Great for the standby screen !
Lokonli
Post by Lokonli »
ok, can I have your votes please :)
madpatrick
I think these are the names as mentioned on the site
- WALL CLOCK
- SLIDE CLOCK
- CSS VARIABLE-POWERED CLOCK
HansieNL
Post by HansieNL »
I vote for these ones:
- CSS Clock by Nils Rasmusson
- Apple Watch Clock by Malik Dellidj
- CSS Variable-Powered Clock by Emily Hayman
Blah blah blah
Lokonli
Post by Lokonli »
Current set of clocks as of beta 3.6.9
  width: 3,
  width: 3,
  boss: 'NoBoss',
  body: 4,
  secondhand: 0
  width: 3,
  body: 0,
  dial: 0,
  secondhand: 1
blocks['stationclock4'] = {
  width: 3,
  body: 3,
  dial: 1,
  boss: 'ViennaBoss',
  secondhandbehavior: 2
blocks['stationclock5'] = {
  width: 3,
  boss: 'RedBoss'
blocks['clock'] = {
    width: 4
blocks['flipclock'] = {
    width: 8
blocks['miniclock'] = {
  width: 4
var columns = {};
columns[1] = {};
  'stationclock',
  'stationclock2',
  'stationclock3',
  'stationclock4',
  'clock',
  'flipclock',
  'miniclock',
Next addition will be - CSS Variable-Powered Clock by Emily Hayman (2 votes)
Lokonli
Post by Lokonli »
Chris12
Domoticz version: 2021.1
Post by Chris12 »
Nice aditions!
I realy like the:
- The QLOCKTWO
- SVG Clock UI
- CSS Rotary Clock
- Analog Digital Clock
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
Lokonli
Post by Lokonli »
An additional clock requires at least two votes.
Enz0jacco
Post by Enz0jacco »
I like the following 2:
12. SVG Clock UI
13. CSS Clock
:D
