Button/block color 'hangs' on touchscreen
whoami
Post by whoami »
When I press the switches(block) in my dashtics screen I see the colour of the block change for half a second. So you know you touched the right switch....
That is okay, but sometimes the button 'hangs' and the more light colour is still shown when i release the block. Switch is working normaly, when I touch anywhere different on my touchscreen it is okay again.
Can I change this behaviour or change the colour or disable this function somewhere? I looked already in the CSS options, but cantn find it...
Anybody an idea?
toro
Re: Button/block color 'hangs' on touchscreen
Post by toro »
Yes, I experience the same here. This has been an issue before but was fixed than. I searched, but could't find the post. But now it’s back, since a couple of months al least I think. Not in the browsers on a Windows machine though, but on a tablet the background of the touched button stays lighter. Using Fully Kiosk on the tablet.
Button touch.png (25.78 KiB) Viewed 1223 times
whoami
Post by whoami »
Yes, this is exactly the same, also with my christmastree :-)
Nobody knows how to fix it?
Lokonli
Post by Lokonli »
I can't reproduce this issue. I've checked the code. I had made some changes 8 months, so it could be related to that.
I've created a test branch, which may fix this issue. Could you test this?
to switch to the test branch via terminal:
git fetch
git checkout test
You can always go back to the master/beta branch via:
git checkout master
or:
git checkout beta
If you don't use git, you can also download the test branch from github.
toro
Post by toro »
Thanks Lokonli for looking in to this, really appreciate it.
I downloaded the test branch, but unfortunately it doesn’t fix it.
I tried it in Chrome browser on the tablet also, same result.
Removed cookies, cache and web storage, nope.
If I use Chrome on my android phone, I don’t have this behavior.
So, very strange why the (Android) tablet still has this problem
Lokonli
Post by Lokonli »
What's your android version on the tablet?
whoami
Post by whoami »
For me it is on a normal windows 10 computer with a touchscreen monitor still the same.
On my iPhone there is no issue.
Lokonli
Post by Lokonli »
whoami wrote:For me it is on a normal windows 10 computer with a touchscreen monitor still the same.
Could you also try with the test branch?
Which browser do you use?
How many domoticz devices do you approximately have?
Do you know whether you are using the websocket connection?
Do you see this issue with all switches, or only certain devices?
toro
Post by toro »
Lokonli wrote: Friday 04 December 2020 23:32 What's your android version on the tablet?
On the tablet (and on my phone) it's Android 9.
This issue is with all switches.
There is something else I noticed, maybe this will help.
I have a block for weather prediction. It’s a dummy text device.
If I touch this block, it also stays highlighted until I touch the screen on an empty space.
In the browser on my pc, this highlighting happens with mouse over. Maybe it has to something to do with this.
blocks[333] = {
	title:'',
	width:12,
	icon:'',
	switch: true,
	addClass:'weersverwachting',
	protected:true
Lokonli
Post by Lokonli »
Found it.
On some (?) touch devices the last touch point is kept as mouse position resulting that the 'hover' effect is applied on that position.
I'll look for a solution. Probably I'll remove the hover effect for touch devices.
Lokonli
Post by Lokonli »
I've created a fix in latest beta. Could you test whether it works on your systems as well?
git checkout beta
git pull
toro
Post by toro »
Wow, it works great!
Good job Lokonli, thank you so much.
And very fast, as always. :)
whoami
Post by whoami »
Lokonli wrote: Sunday 06 December 2020 15:19 I've created a fix in latest beta. Could you test whether it works on your systems as well?
git checkout beta
git pull
Yes!!! Superb, it worked. Can I use this beta for now or do you advise this onlt for testing?
Lokonli
Post by Lokonli »
You can use beta.
I'll derive a new master release from this version probably this week.
darrepac
Post by darrepac »
I have the same problem on current dashticz version on raspberry with touchscreen screen... Is there something to activate to avoid this hover effect where the virtual mouse is?
