i'm quite new to this, so this will probably be user error. My domoticz install will only run for a few hours and then not run anymore. There are error log entries, that i really cant logically tie to crashes like
2020-11-11 08:42:59.938 Error: (Space Weather) Device creation failed, Hardware/Unit combination (26:1) already exists in Domoticz.
2020-11-11 08:42:59.924 Error: (Corona Dashboard) 'onStart' failed 'KeyError'.
2020-11-11 08:43:40.236 Error: (FritzBox) restart cnx: ? last None or 0
so i did the old windows system administration trick to at least schedule restart at night in crontab, but that's not what i want.
how do i figure out what makes it stop/crash? and how to fix it? What info do you need on my setup (which is very much only a beginning/tryout type of thing) to help me with this?
Thanks for helping me.
Regards,
Willem
Domoticz doesn't keep running very long
- psubiaco
Re: Domoticz doesn't keep running very long
Hi Willem,
did you try to disable Space Weather, then Corona Dashboard, .... to determine which one is the problem?
I'm running domoticz in a raspberry PI3 and it works like a charme. No need to restart it or reset every day/week/month!
Paolo
Paolo
Paolo
- elzorrovega
- Domoticz version: 2025.2
Hello Willem
I have the following setup
Linux raspberrypi2 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l GNU/Linux
Domoticz Version 2020.2 running on Raspberry Pi (RPI) 3 B+ , 1G RAM
I and have the following connected
Like all RPIs you need to restart LXPANEL, windows manager, periodically because it has memory leaks. You can put thjis in a script in cron.
Do you have the latest updates in your RPI? Are you running the Buster flavour of the Debian Distribution?
El Zorrovega
Node Name Description Manufacturer ID Type
014 (0x0e) Garage D/W FIBARO System FGDW002 Door Opening Sensor 2+ FIBARO System 0x1000 0x0702
013 (0x0d) Chamber 2 Motion Sensor FIBARO System FGMS001-ZW5 Motion Sensor+ FIBARO System 0x1002 0x0801
012 (0x0c) Chamber 1 Motion Sensor FIBARO System FGMS001-ZW5 Motion Sensor+ FIBARO System 0x1002 0x0801
011 (0x0b) Chamber 2 D/W FIBARO System FGK101 Door Opening Sensor FIBARO System 0x1000 0x0700
010 (0x0a) Chamber 3 D/W FIBARO System FGK101 Door Opening Sensor FIBARO System 0x1000 0x0700
009 (0x09) Bathroom D/W FIBARO System FGK101 Door Opening Sensor FIBARO System 0x1000 0x0700
008 (0x08) Hall Siren AEON Labs ZW080 Siren Gen5+ AEON Labs 0x0050 0x0004
007 (0x07) Hall Keyboard Schlage Link (Wintop) Mini Keypad RFID Schlage Link 0x4501 0x6131
006 (0x06) Living Motion Sensor FIBARO System FGMS001 Motion Sensor FIBARO System 0x1001 0x0800
005 (0x05) Hall Motion Sensor FIBARO System FGMS001 Motion Sensor FIBARO System 0x1001 0x0800
004 (0x04) Chamber 1 D/W FIBARO System FGK101 Door Opening Sensor FIBARO System 0x1000 0x0700
003 (0x03) Chamber 1 Siren AEON Labs ZW080 Siren Gen5+ AEON Labs 0x0050 0x0004
002 (0x02) Fibaro Wall Plug 1 FIBARO System FGWPE/F Wall Plug FIBARO System 0x1000 0x0600
001 (0x01) Controller AEON Labs ZW090 Z-Stick Gen5 EU AEON Labs 0x005a 0x0001Do you have the latest updates in your RPI? Are you running the Buster flavour of the Debian Distribution?
El Zorrovega
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bookworm 64 bit OS 6.12.47+rpt-rpi-v8
Domoticz Version: 2025.2
zwave-js-ui: 10.4.2.d3a89a7
zwave-js: 15.3.1
home id: 3714679688
home hex: 0xdd698388
zwave-js: 15.3.1
home id: 3714679688
wkossen
i have lates rpi. how do i restart lxpanel? in fact, i don't need the gui at all, as i am running headless anyway and know my way around the cli (or at least, well enough)
