Domoticz doesn't keep running very long
wkossen
Post by wkossen »
i'm quite new to this, so this will probably be user error. My domoticz install will only run for a few hours and then not run anymore. There are error log entries, that i really cant logically tie to crashes like
2020-11-11 08:42:59.938 Error: (Space Weather) Device creation failed, Hardware/Unit combination (26:1) already exists in Domoticz.
2020-11-11 08:42:59.924 Error: (Corona Dashboard) 'onStart' failed 'KeyError'.
2020-11-11 08:43:40.236 Error: (FritzBox) restart cnx: ? last None or 0
so i did the old windows system administration trick to at least schedule restart at night in crontab, but that's not what i want.
how do i figure out what makes it stop/crash? and how to fix it? What info do you need on my setup (which is very much only a beginning/tryout type of thing) to help me with this?
Thanks for helping me.
Regards,
Willem
psubiaco
Re: Domoticz doesn't keep running very long
Post by psubiaco »
Hi Willem,
did you try to disable Space Weather, then Corona Dashboard, .... to determine which one is the problem?
I'm running domoticz in a raspberry PI3 and it works like a charme. No need to restart it or reset every day/week/month!
Paolo
Paolo
elzorrovega
Domoticz version: 2025.2
Post by elzorrovega »
Hello Willem
I have the following setup
Linux raspberrypi2 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l GNU/Linux
Domoticz Version 2020.2 running on Raspberry Pi (RPI) 3 B+ , 1G RAM
I and have the following connected
Node		Name			Description					Manufacturer	ID	Type
014 (0x0e)	Garage D/W		FIBARO System FGDW002 Door Opening Sensor 2+	FIBARO System	0x1000	0x0702
013 (0x0d)	Chamber 2 Motion Sensor	FIBARO System FGMS001-ZW5 Motion Sensor+	FIBARO System	0x1002	0x0801
012 (0x0c)	Chamber 1 Motion Sensor	FIBARO System FGMS001-ZW5 Motion Sensor+	FIBARO System	0x1002	0x0801
011 (0x0b)	Chamber 2 D/W		FIBARO System FGK101 Door Opening Sensor	FIBARO System	0x1000	0x0700
010 (0x0a)	Chamber 3 D/W		FIBARO System FGK101 Door Opening Sensor	FIBARO System	0x1000	0x0700
009 (0x09)	Bathroom D/W		FIBARO System FGK101 Door Opening Sensor	FIBARO System	0x1000	0x0700
008 (0x08)	Hall Siren		AEON Labs ZW080 Siren Gen5+			AEON Labs	0x0050	0x0004
007 (0x07)	Hall Keyboard		Schlage Link (Wintop) Mini Keypad RFID		Schlage Link 	0x4501	0x6131
006 (0x06)	Living Motion Sensor	FIBARO System FGMS001 Motion Sensor		FIBARO System	0x1001	0x0800
005 (0x05)	Hall Motion Sensor	FIBARO System FGMS001 Motion Sensor		FIBARO System	0x1001	0x0800
004 (0x04)	Chamber 1 D/W		FIBARO System FGK101 Door Opening Sensor	FIBARO System	0x1000	0x0700
003 (0x03)	Chamber 1 Siren		AEON Labs ZW080 Siren Gen5+			AEON Labs	0x0050	0x0004
002 (0x02)	Fibaro Wall Plug 1	FIBARO System FGWPE/F Wall Plug			FIBARO System	0x1000	0x0600
001 (0x01)	Controller		AEON Labs ZW090 Z-Stick Gen5 EU			AEON Labs	0x005a	0x0001
Like all RPIs you need to restart LXPANEL, windows manager, periodically because it has memory leaks. You can put thjis in a script in cron.
Do you have the latest updates in your RPI? Are you running the Buster flavour of the Debian Distribution?
El Zorrovega
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bookworm 64 bit OS 6.12.47+rpt-rpi-v8
Domoticz Version: 2025.2
zwave-js-ui: 10.4.2.d3a89a7
zwave-js: 15.3.1
home id: 3714679688
home hex: 0xdd698388
wkossen
Post by wkossen »
i have lates rpi. how do i restart lxpanel? in fact, i don't need the gui at all, as i am running headless anyway and know my way around the cli (or at least, well enough)
