all Zwave data lost after a general Power cut
Tylou
Post by Tylou »
I'm facing an issue with Domoticz and my zwave devices.
I lost all nodes in the Zwave devices list but Hardware liste is OK. The openZwave Control Panel is empty too
I have 9 devices in my home (NodeOn, Figaro, Qubino, ...) All worked fine since 5 years, with buggs sometimes but nothing I couldn't solved ;) .
here is the hardware list
device list (empty)
No error in the log and all other things are working fine (MQTT, lua script python script, HTTP API,...)
If I ask to include a new node an error appears:
2020-11-06 11:27:44.290 Error: OpenZWave: Exception. Type: 100, Msg: Invalid HomeId passed to GetDriver, File: /home/pi/build32/open-zwave-read-only/cpp/src/Manager.cpp (Line 410) OpenZWave.cpp:3483
2020-11-06 11:27:51.623 Error: OpenZWave: Exception. Type: 100, Msg: Invalid HomeId passed to GetDriver, File: /home/pi/build32/open-zwave-read-only/cpp/src/Manager.cpp (Line 410) OpenZWave.cpp:3877
I tryed with a DB backup ==> still same issue
I tryed a former SD backup of the whole Rasp that worked ==> still same issue
I opened the DB and it seem OK (but not sure : I'm not confident with SQL DB)
Configuration :
Rasp3 model B - Buster and up to date (OS + firmware)
Domoticz stable 2020.1
RaZberry V1
Please, is someone has an idea to help?
And I would like avoid to reset all zwave devices & controller :?
mark.sellwood
Re: all Zwave data lost after a general Power cut
Post by mark.sellwood »
Is the Serial Port correct as it can change?
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Tylou
Post by Tylou »
Thanks for your help
I think it's OK, I have 4 serial port deteted and ttyAMAO0 which is a links to SERIAL0
(I made that when I upgrate to Rasp3 keeping my existing DB)
Thus RaZberry controller is detected with both
But how can I check the communication between RazBerry and the Raspi? I didn't find any tutos yet
Tylou
Post by Tylou »
update,
found that : https://forum.z-wave.me/viewtopic.php?p=86789#p86789
in /boot/config.txt, I added
enable_uart=1
I execute following command
sudo systemctl stop [email protected]
sudo systemctl disable [email protected]
Now I retreive the full list of Zwave devices
But I'm not able to controle my devices
now I have this error in log
2020-11-06 15:27:20.752 Error: OpenZWave: Type_Notification, NodeID not found internally!. HomeID: 0, NodeID: 255 (0xff)
I tested update some devices :
from devices to Domoticz ==> it's refreshing Domoticz
command from Domoticz ==> nothing appends
Help still needed,
thanks
Number8
Domoticz version: 2022.1
Post by Number8 »
I don't know whether you solved your problem. I had same issue today running beta 12467. Pretty scarry. After several reboot, several service stop/start, I unplugged zwave stick, plugged it back, rebooted once again, and everything was back up. I can testify it was no a wrong USB port issue. I just don't know what was the issue.
Debian buster on NUC and three RPi with buster.
jake
Post by jake »
Number8 wrote:I don't know whether you solved your problem. I had same issue today running beta 12467. Pretty scarry. After several reboot, several service stop/start, I unplugged zwave stick, plugged it back, rebooted once again, and everything was back up. I can testify it was no a wrong USB port issue. I just don't know what was the issue.
I seem to have the same problem now. I had one Fibaro plug that 1 out of 5 times did not want to turn OFF (ON always worked). I tried the same trick as with another one of those plugs: reset the device, let domotic detect the failed node and do a 'replace failed' and include again under the same ID.
However, it didn't work for this one, so I turned the OpenZwave hardware off and on again in Domoticz (build 13058) and ever since the OpenZwave is dead, the setup button is red. I tried a soft reset of the controller, after renaming the openzwave config file in pi/domoticz/Config. It than built a new file which was slowly growing, it showed all devices with red text, but none would work. Updated times were improving as well (except some sensors). Unfortunately, after a reboot of the complete pi, I'm back to square 1 with no OpenZwave at all.
lsusb shows the Gen2 Stick (Bus 001 Device 008: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]) but it seems improper loaded in Domoticz.
When I now disable the OpenZwave, Domoticz locks up and isreset by Monit after some time. Afterwards OpenZwave is disabled, but when I enable it again, I only get the following in the log (while filtered on zwave):
2021-03-10 23:34:43.329 Status: OpenZWave: Starting...
2021-03-10 23:34:43.329 Status: OpenZWave: Version: 1.6-1520-g893e076a
2021-03-10 23:35:07.645 Status: OpenZWave: A Config File Failed to download
2021-03-10 23:35:48.384 Status: OpenZWave: A Config File Failed to download
2021-03-10 23:36:23.663 Status: OpenZWave: A Config File Failed to download
2021-03-10 23:36:58.807 Status: OpenZWave: A Config File Failed to download
How to fix this?
EDIT:
Patiently waiting for 15 minutes fixed it by itself luckily. For now, I won't touch Zwave anymore :-)
jake wrote: Wednesday 10 March 2021 23:38 When I now disable the OpenZwave, Domoticz locks up and isreset by Monit after some time. Afterwards OpenZwave is disabled, but when I enable it again, I only get the following in the log (while filtered on zwave):
How to fix this?
There seems to be a recent change in the OpenZwave part of domoticz. I am on build 13063 and see something similar. A github issue is created for this and I will link this topic into it.
Until the code is fixed again in a next build, the best you can do is to sit tight and don't touch it. I almost destroyed my config in the process to fix it and only because I could recover the mess I created using a recent backup and after waiting almost an hour the devices appeared again.
Alcloud
Post by Alcloud »
Yes, I have the same error
Number8
Post by Number8 »
waaren wrote: Thursday 11 March 2021 0:08
How to fix this?
When a cold reboot is performed the same error is reported. Currently running 12485
Number8 wrote: Thursday 11 March 2021 7:35 When a cold reboot is performed the same error is reported. Currently running 12485
Seems to be related with an outage of the OpenZwave download server. Check github issue 4723
antwan
Domoticz version: Latest
Post by antwan »
There is an update available for this problem (openzwave server down).
If you update to the latest version 13064 then domoticz /Zwave start again super fast.
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
jake
Post by jake »
antwan wrote:There is an update available for this problem (openzwave server down).
Yes, this fixed it for me too!
Verstuurd vanaf mijn SM-G970F met Tapatalk
