I used the Set after Seconds option and now wonder if I there's a place I can see how many seconds left on that timer.
I used it for a delay switch for 1800 and a 2700 seconds (30/45min) timer turning something off.
Thanks,
Question Set After Seconds
- waaren
Re: Question Set After Seconds
No, that timer is not accessible via the GUI or in Blocky, classic Lua or dzVents.
- Domoticz version: 2020.2
Thanks, then I may have to start studying LUA or DzVents some day.
- ILoveIOT
I use dummy switches for that, and set the seconds in de the switch, before/after, so you can stop de timer if a value changed, also I use a timer check script (somewhere on this forum) that checks if a timer should end or not, if Domoticz restarts all the timers are lost, this script will end the timer if he has expire.
1x OPI PC 5.8.16 Debian 10, MiniDNLA,SMD230,EpEver,MPD,800GB,Wiegand,7 temps,DHT,32/64 I/O,2022.1
2x OPI PC 4.19.25 Debian 9, MPD,7 temps,16/32 I/O,BMP,4.10717
1x IntelNUC 5.10 Debian 10, 2TB,DalyBMS,2023.1
3x ESPEasy NodeMCU V3, 16/16 I/O
Thanks, I'll have a look at that.
- ILoveIOT
The timer check script;
viewtopic.php?t=27601
I got maybe 20 dummy switches that work as a timer, works easy, and you can stay in the frontend, easy blocky setup.
Have fun !!
Have fun !!
