Question Set After Seconds
Jasper79
Post by Jasper79 »
I used the Set after Seconds option and now wonder if I there's a place I can see how many seconds left on that timer.
I used it for a delay switch for 1800 and a 2700 seconds (30/45min) timer turning something off.
Thanks,
Re: Question Set After Seconds
Jasper79 wrote: Thursday 29 October 2020 11:47 I used the Set after Seconds option and now wonder if I there's a place I can see how many seconds left on that timer.
No, that timer is not accessible via the GUI or in Blocky, classic Lua or dzVents.
Jasper79
Post by Jasper79 »
Thanks, then I may have to start studying LUA or DzVents some day.
ILoveIOT
Post by ILoveIOT »
I use dummy switches for that, and set the seconds in de the switch, before/after, so you can stop de timer if a value changed, also I use a timer check script (somewhere on this forum) that checks if a timer should end or not, if Domoticz restarts all the timers are lost, this script will end the timer if he has expire.
1x OPI PC 5.8.16 Debian 10, MiniDNLA,SMD230,EpEver,MPD,800GB,Wiegand,7 temps,DHT,32/64 I/O,2022.1
2x OPI PC 4.19.25 Debian 9, MPD,7 temps,16/32 I/O,BMP,4.10717
1x IntelNUC 5.10 Debian 10, 2TB,DalyBMS,2023.1
3x ESPEasy NodeMCU V3, 16/16 I/O
Jasper79
Post by Jasper79 »
Thanks, I'll have a look at that.
ILoveIOT
Post by ILoveIOT »
The timer check script;
viewtopic.php?t=27601
I got maybe 20 dummy switches that work as a timer, works easy, and you can stay in the frontend, easy blocky setup.
Have fun !! :D
