Make a POST with application/x-www-form-urlencoded payload  [Solved]
Number8
Domoticz version: 2022.1
Post by Number8 »
I have to send a POST with an application/x-www-form-urlencoded payload. I'm wondering what the syntax should be?
Current script is:
dz.openURL({
        url = url,
	method = "POST",
        callback = "return",
        postData = {
          turn = "toggle"
Thank you
Debian buster on NUC and three RPi with buster.
Re: Make a POST with application/x-www-form-urlencoded payload
Number8 wrote: Wednesday 28 October 2020 9:31 I have to send a POST with an application/x-www-form-urlencoded payload. I'm wondering what the syntax should be?
Something like this ?
dz.openURL({
                url = url,
                method = 'POST',
                headers = { ['content-Type'] = 'application/x-www-form-urlencoded' },
                postData = { ['turn'] = 'toggle' },
                callback = 'return',
Number8
Post by Number8 »
Thanks waaren
Unfortunately it does not work, I don't know why. Strange the API does not return any error.
Using GET however works
'IPAddress/relay/0?turn=toggle'
Number8
Post by Number8 »
Using this curl command works
curl -X POST -d "turn=toggle"  http://IPaddress/relay/0
What would be then dzVents syntax?
Number8
Re: Make a POST with application/x-www-form-urlencoded payload  [Solved]
Post by Number8 »
The correct syntax is
dz.openURL({
        url = url,
	method = 'POST',
        postData = { turn = 'on' },
        callback = 'return'
