Can the Bitron Smokedetector/Sirene (902010/124) be integrated? If yes, what information is needed?
Thanks in advance!
Arthur
Add support for Bitron Smokedetector/Sirene
- Domoticz version: Stable
Pi 3B, latest stable
RFXCOM, Z-wave, Zigate, Hue, Harmony hub, Netatmo Weather station, Opentherm Gateway, EnOcean,P1 SmartMeter, Plugwise Anna & Adam, Xiaomi Roborock, Sonos One, Google Home, Philips Hue, Homey, D-link and Bitron Video camera.
Re: Add support for Bitron Smokedetector/Sirene
Not sure what or which project should be concerned ?
If that is realated to Zigate and the plugin , I tried to explain what should be the approach here ( https://github.com/pipiche38/Domoticz-Z ... -device.md )
In case it is for other gateway, might be better to put in the subject the Gateway.
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
Hi Pipiche,
Thank you for the information. I would like the integration for Zigate / Domoticz.
Below the requested information.
Product Name: Optical Smoke Detector
Brand: Bitron
URL on a web site: https://en.smabit.eu/
What do you expect:
I expect an switch in Domoticz which is turned on when smoke is detected.
I expect an switch which i can toggle to enable the sirene on the smokedetector.
The logs from the pairing process:
Brand: Bitron
What do you expect:
Thanks for those information.
Is the smoke detection works ? Does it switch on the Door widget ?
Hi Pipiche,
I would love to test, but i find it difficult to create smoke in an house with young kids.
I hope i can get something done tomorrow and will come back to you.
What about the sirene function? I was hoping to use this for building an alarm system.
Arthur
Arthur
is there any way to check that is functioning. What is the purpose of the button ?
From what I saw on the export you sent me it did create
- 1 door widget
- 1 sirene widget
Did you try the Sirene widget ?
- 1 door widget
- 1 sirene widget
Hi Pipiche,
I'll be dammed. I added the selector switch and it just worked.
I thought it would not, so sorry to bother you with this request.
(note for self: test first before asking help)
Arthur
Arthur
Dont' worry , you made my day.
Anyway, I'll do a change in the code, so next time it will create a Smoke widget and not a Door
