Page 1 of 2
Notification script
Posted: Tuesday 22 September 2020 21:42
by Larsoss
Hey,
I have another question about scripting. I have a number of dummy switches that I have sent a notification. now it is so that a script is running that switches my lamp. which causes me to get a notification quite often.
now I thought it might be possible to make 1 dzvents script in which I put all my idx of my switches of which I want a notification and if it changes status on / off then a notification via the script comes via telegram.
and maybe even adjust the notification.
so at idx 15 is my living room lamp and when it comes on the notification comes "lamp on" and when my dummy "ping television" comes on the notification "the tv is on" comes on.
who can help me in the right direction?
Re: Notification script
Posted: Tuesday 22 September 2020 22:13
by Tjalling94
You can also check the current state of your light.
if domoticz.devices('lamp').state == 'Off' then
   domoticz.devices('lamp').switchOn();
That's enough to prevent duplicate notifications
Posted: Tuesday 22 September 2020 22:33
by Larsoss
Ok. But still want to make a script with the notifications :)
Posted: Tuesday 22 September 2020 22:50
by kimot
And why script for this "switch custom message", when you can write notification directly in switch notification tab?
Posted: Tuesday 22 September 2020 22:57
by HvdW
Did you have a look at the 'System-alive-check' script which you can find here to see howto set it up in your own script?
Posted: Tuesday 22 September 2020 23:26
by Larsoss
kimot wrote: Tuesday 22 September 2020 22:50 And why script for this "switch custom message", when you can write notification directly in switch notification tab?
because i get to many notifications, even when there is nothing change's... it still sending me the same notification.
Posted: Wednesday 23 September 2020 0:04
by waaren
Larsoss wrote: Tuesday 22 September 2020 23:26 because i get to many notifications, even when there is nothing change's... it still sending me the same notification.
Could look like below
        script to send adjustable notifications
        Enter text in description field like below 2 lines
        Text within {} can be changed. device_name and device_id will be substituted by script
        active:{device device_name has been switched on}
        idle:{device device_id has been switched off}
return
    on =
        devices =
            551, 552, 553, -- All devices you want to check
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'notifyer',
    data =
        devices =
            initial = {},
    execute = function(dz, item)
        local function substitute(str)
            replacingText =
                ['device_id']  = item.id,
                ['device_name']  = item.name,
            for key, substitution in pairs(replacingText) do
               str = str:gsub(key, substitution)
           return str
        local function procesDescription(state)
            local _, _, msg = string.find(item.description,state .. ":(%b{})") -- get text between {}
            if msg then
                msg = msg:match("[^{].*[^}]") -- remove {}
                msg = substitute(msg)
                dz.log('procesDescription: ' .. msg, dz.LOG_DEBUG)
                dz.log('procesDescription: Text not found in description', dz.LOG_DEBUG)
            return msg
        local function procesNotification( state )
            if dz.data.devices[item.id] ~= state then
                dz.data.devices[item.id] = state
                return procesDescription(state)
                dz.log('procesNotification: State did not change', dz.LOG_DEBUG)
        --main
        local msg = procesNotification(item.active and 'active' or 'idle')
        if msg then
            dz.log(msg, dz.LOG_DEBUG)
            dz.notify('notifyer',msg, dz.PRIORITY_NORMAL,nil,nil,dz.NSS_TELEGRAM)
Posted: Wednesday 23 September 2020 0:09
by Larsoss
Almost Waaren, still no meassage to telegram.. but you get the point of what i was searching for.
Posted: Wednesday 23 September 2020 0:44
by waaren
Larsoss wrote: Wednesday 23 September 2020 0:09 Almost Waaren, still no meassage to telegram.. but you get the point of what i was searching for.
I tested the script before posting and it works for me. Did you add the required text in the description field for the devices at hand?
Do you see any messages in the log?
Posted: Wednesday 23 September 2020 0:47
by Larsoss
waaren wrote: Wednesday 23 September 2020 0:44
no error in log
2020-09-23 00:47:00.567 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-09-23 00:47:18.536 (MQTT Discovery) onCommand 004/Spots Overkapping: Command: 'Off', Level: 0, Color:
2020-09-23 00:47:18.537 (MQTT Discovery) MqttClient::Publish cmnd/spots_overkapping/POWER (OFF)
2020-09-23 00:47:18.590 (MQTT Discovery) 004/Spots Overkapping: Topic: 'tele/spots_overkapping/STATE 'Setting nValue: 1->0, sValue: ''->''
2020-09-23 00:47:18.526 Status: User: Admin initiated a switch command (147/Spots Overkapping/Off)
2020-09-23 00:47:18.732 Status: dzVents: Info: Handling events for: "Spots Overkapping", value: "Off"
2020-09-23 00:47:18.733 Status: dzVents: Info: notifyer: ------ Start internal script: Notificatie Script: Device: "Spots Overkapping (MQTT Discovery)", Index: 147
2020-09-23 00:47:18.733 Status: dzVents: Info: notifyer: ------ Finished Notificatie Script
return
    on =
        devices =
            41, 42, 123, 124, 146, 147, 150, 151, 157 -- All devices you want to check
    logging =
    data =
        devices =
            initial = {},
            replacingText =
           return str
            local _, _, msg = string.find(item.description,state .. ":(%b{dummy is veranderd naar})") -- get text between {}
            if msg then
                msg = msg:match("[^].*[^]") -- remove {}
            return msg
        --main
        if msg then
            dz.log(msg)
            dz.notify('notifyer', msg, dz.PRIORITY_HIGH, nil, nil, dz.NSS_TELEGRAM)
Posted: Wednesday 23 September 2020 1:02
by waaren
Larsoss wrote: Wednesday 23 September 2020 0:47 no error in log
I added some extra log statements in my original posted code. Please use this updated one and check the log. It might help to find why it is not working for you.
Posted: Wednesday 23 September 2020 11:44
by Larsoss
I really don't understand sorry .. and I also understand that you don't want to deliver everything in ready-made solutions .. but I really don't see what I'm forgetting .. I've tried to put text in everything, but stay now you get the message Text not found in description 'in the log.
Posted: Wednesday 23 September 2020 12:03
by waaren
Larsoss wrote: Wednesday 23 September 2020 11:44 I really don't understand sorry .. and I also understand that you don't want to deliver everything in ready-made solutions .. but I really don't see what I'm forgetting .. I've tried to put text in everything, but stay now you get the message Text not found in description 'in the log.
Did you enter the exact text in the description field of the device like below? (Click on the edit button of the device in the switches tab to get to this screen)
Re: Notification script  [Solved]
Posted: Wednesday 23 September 2020 12:07
by Larsoss
waaren wrote: Wednesday 23 September 2020 12:03
No i did not, now i have done it. and the telegram arive's.. thank you very much.
Posted: Tuesday 13 October 2020 13:06
by Larsoss
Hey Waaren,
I have a new dummy with the seasons, it contains 4 selector switches that are triggered to the time of the year.
Now it is Autumn, for example. This works with the% value of 10,20,30,40.
Can I also process it in this script? So if a new season starts (winter for example) that there will also be a message about it?
Posted: Tuesday 13 October 2020 13:33
by waaren
Larsoss wrote: Tuesday 13 October 2020 13:06 Can I also process it in this script? So if a new season starts (winter for example) that there will also be a message about it?
Script needs some modification (see below) but yes.
        script to send notifications of selector type switches
return
    on =
        devices =
            668,  -- All devices you want to check
    logging =
        marker = 'selector notifyer',
    data =
        devices =
            initial = {},
        local function procesNotification( label )
            if dz.data.devices[item.id] ~= label then
                dz.data.devices[item.id] = label
                return label
                dz.log('procesNotification: Label did not change', dz.LOG_DEBUG)
        --main
        local msg = procesNotification(item.levelName)
        if msg then
            dz.notify('notifyer','Selector ' .. item.name .. ' switched to ' .. msg, dz.PRIORITY_NORMAL,nil,nil,dz.NSS_TELEGRAM)
Posted: Tuesday 13 October 2020 13:59
by waaren
But why not combine these functionalities into one script. (after restoring level 0 "Off")
        script to set selector switch to season and
        send notifications of levelNames of selector type switches
local time = '08:30'
local spring = '21/03'
local summer = '21/06'
local autumn = '21/09'
local winter = '21/12'
local seasonDevice = 668
return
    on =
        timer =
            'at ' .. time .. ' on ' .. spring,
            'at ' .. time .. ' on ' .. summer,
            'at ' .. time .. ' on ' .. autumn,
            'at ' .. time .. ' on ' .. winter,
        devices =
            seasonDevice,  -- You can add other selector type devices you want to check
    logging =
        marker = 'Season selector notifyer',
    data =
        devices =
            initial = {},
        local season = dz.devices(seasonDevice)
                return label
        --main
        if item.isTimer then
            if item.trigger:find(winter) then season.switchSelector('Winter')
            elseif item.trigger:find(spring) then season.switchSelector('Spring')
            elseif item.trigger:find(summer) then season.switchSelector('Summer')
            elseif item.trigger:find(autumn) then season.switchSelector('Autumn')
                season.switchSelector('Very strange season')
            if msg then
Posted: Tuesday 13 October 2020 15:24
by Larsoss
waaren wrote: Tuesday 13 October 2020 13:59
return
    on =
        timer =
        devices =
    logging =
    data =
        devices =
            initial = {},
                return label
        --main
            if msg then
Yep, this works right away. Thank you. And I haven't recovered anything.
The dummy is as above
Posted: Friday 23 October 2020 15:46
by Jan Jansen
While converting a blockly script (burglar alarm) I came across this thread. In the event of a burglary, it is relevant to know which door or window is opened. If that can be done via a notification, fantastic! This concerns specific devices under specific circumstances.
		devices = {
			'Voordeur',                                         -- door contact
			'Woonkamer (voorzijde)',                            -- door contact
			'Slaapkamer (voorzijde)',                           -- door contact
			'Keukendeur',                                       -- door contact
			'Inbraak keukendeur',                               -- dummy switch (on delay)
			'Schuurdeur',                                       -- door contact
			'Inbraak schuurdeur',                               -- dummy switch (on delay)
			'Beveiliging'                                       -- dummy selector levels 'Uit', 'Thuis' and 'Afwezig'
	logging =
        marker = 'inbraak',
	    local vd = dz.devices('Voordeur')
	    local wk = dz.devices('Woonkamer (voorzijde)')
	    local slpkmrvz = dz.devices('Slaapkamer (voorzijde)')
	    local kd = dz.devices('Keukendeur')
	    local inbkd = dz.devices('Inbraak keukendeur')
	    local sd = dz.devices('Schuurdeur')
	    local inbsd = dz.devices('Inbraak Schuurdeur')
	    local bev = dz.devices('Beveiliging')
	    local asinb = dz.devices('Alarmsignaal inbraak')
	    local iva = dz.devices('Inschakelvertraging alarm')     -- dummy switch on delay
		if (vd.state == 'On' or wk.state == 'On' or slpkmrvz.state == 'On' or kd.state == 'On' or sd.state == 'On') and bev.state == 'Thuis' then
		    asinb.switchOn()
		    dz.notify('Inbraak (thuis)!!','   ??  geactiveerd',dz.PRIORITY_HIGH)
		if (vd.state == 'On' or wk.state == 'On' or slpkmrvz.state == 'On' or inbkd.state == 'On' or inbsd.state == 'On') and iva.state == 'On' then
		    asinb.switchOn()
		    dz.notify('Inbraak (afwezig)!!','   ??   geactiveerd',dz.PRIORITY_HIGH)
		if bev.state == 'Uit' and asinb == 'On' then
		    asinb.switchOff()
		    dz.notify('Reset alarm','Alarminstallatie gereset',dz.PRIORITY_HIGH)
In case of bev.state == 'Thuis' it only concerns the devices 'Voordeur', Woonkamer (voorzijde), Slaapkamer (voorzijde), Keukendeur and Schuurdeur
In case iva.state == 'On' it only concerns the devices 'Voordeur', Woonkamer (voorzijde), Slaapkamer (voorzijde), Inbraak keukendeur and Inbraak schuurdeur.
Thanks in advance!
Regards Jan
Posted: Friday 23 October 2020 16:24
by waaren
Jan Jansen wrote: Friday 23 October 2020 15:46 While converting a blockly script (burglar alarm) I came across this thread. In the event of a burglary, it is relevant to know which door or window is opened.
Can you try after changing
'   ??   geactiveerd'
to
item.name .. ' geactiveerd'
