RGB Color from Dimmer  [Solved]
gian72
Post by gian72 »
Hi to all.
I'm trying to get the values of a virtual dimmer (RGB color and master slider), so I can push them via mqtt.
The question is: how can I read this values and put them in variables?
Thanks so much for your help.
Gianluca
Re: RGB Color from Dimmer
gian72 wrote: Tuesday 25 August 2020 17:24 Hi to all.
Gianluca
Reading is the easy part.
Question is what needs to be done with the values ?
return
    on =
        devices =
            3137, -- idx or 'name' of  your RGBW device
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'getColor',
    execute = function(dz, item)
        dz.utils.dumpTable(item.getColor() )
        dz.log(item.name ..'; color = ' .. dz.utils.toJSON(item.getColor()),dz.LOG_DEBUG)
        dz.log(item.name ..'; dimLevel = ' .. item.level,dz.LOG_DEBUG)
Info: getColor: ------ Start internal script: 20200826 dz senColorToMQTT: Device: "Hue gevel zuid (Hue)", Index: 3137
> cw: 0
> isWhite: false
> hue: 45.0
> r: 255
> brightness: 100.0
> m: 3
> temperature: 0
> warm white: 0
> g: 242
> cold white: 0
> blue: 203
> ww: 0
> b: 203
> mode: 3
> green: 242
> value: 100.0
> saturation: 20.392156862745
> t: 0
> red: 255
Debug: getColor: Hue gevel zuid; color = {"b":203,"blue":203,"brightness":100.0,"cold white":0,"cw":0,"g":242,"green":242,"hue":45.0,"isWhite":false,"m":3,"mode":3,"r":255,"red":255,"saturation":20.392156862745,"t":0,"temperature":0,"value":100.0,"warm white":0,"ww":0}
Debug: getColor: Hue gevel zuid; dimLevel = 94
Info: getColor: ------ Finished 20200826 dz senColorToMQTT
gian72
Post by gian72 »
Thanks for the quick reply. I will try it asap.
I've a modified aqaura gateway (https://github.com/cadavre/miio_gateway) and I'm trying to send, via mqtt the commands to change the colors. I've already achieved the on off (via node red), now I'm trying to change the color.
Do you kn ow a simpler way :roll: ?
Thank you!
gian72 wrote: I've a modified aqaura gateway (https://github.com/cadavre/miio_gateway) and I'm trying to send, via mqtt the commands to change the colors. I've already achieved the on off (via node red), now I'm trying to change the color.
Do you know a simpler way :roll: ?
Thank you!
What is the mqtt command you are looking for?
gian72
Post by gian72 »
return
    on =
        devices =
            201, -- idx or 'name' of  your RGBW device
    logging =
        comando = 'mosquitto_pub -h mqttserver -t /mihome/brightness -m ' ..item.level
        os.execute(comando)
The function above sets the brightness level correctly!
So what i'm trying right now is how to get the RGB value in a format like 'fffff' so I put it in a command like
comando = 'mosquitto_pub -h mqttserver -t /mihome/rgb -m ' ..item.SOMETHING
and to have the item.SOMETHING containing the rgb value.
Gianluca
gian72 wrote: Tuesday 25 August 2020 21:14 What i'm trying right now is how to get the RGB value in a format like 'fffff' so I put it in a command like
Can you test this?
return
    on =
        devices =
    logging =
        marker = 'sendColor',
       local mqttServer = '192.168.192.116' -- Change to IP or name of your MQTT server
       local color = item.getColor()
       local function osCommand(cmd)
            dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
            local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
            local commandOutput = assert(fileHandle:read('*a'))
            local returnTable = {fileHandle:close()}
            if commandOutput:find '::ERROR::' then     -- something went wrong
               dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_ERROR)
            else -- all is fine!!
                dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
            return commandOutput,returnTable[3] -- rc[3] contains returnCode
        local function toHex(...)
            local hex = ''
            for _, rgb in ipairs({...}) do
                hex = hex .. string.format('%02X',rgb) -- use string.format('%02x',rgb) if you need lower case hex
            return hex
        local function createMQTT(server, topic, message)
            return 'mosquitto_pub -h ' .. server .. ' -t ' .. topic ..' -m ' .. message
        osCommand( createMQTT( mqttServer, '/mihome/brighness', item.level ) )
        osCommand( createMQTT( mqttServer, '/mihome/rgb', toHex(color.r, color.g, color.b ) ) )
gian72
Re: RGB Color from Dimmer  [Solved]
Post by gian72 »
Works great!
The functions toHex and osCommand opened my mind on how dzVents is working :D .
Thanks so much for the solution!
Gianluca
