RGB Color from Dimmer [Solved]
gian72
Hi to all.
I'm trying to get the values of a virtual dimmer (RGB color and master slider), so I can push them via mqtt.
The question is: how can I read this values and put them in variables?
Thanks so much for your help.
Gianluca
Gianluca
- waaren
Re: RGB Color from Dimmer
Reading is the easy part.gian72 wrote: Tuesday 25 August 2020 17:24 Hi to all.
Gianluca
Question is what needs to be done with the values ?
return
on =
devices =
3137, -- idx or 'name' of your RGBW device
logging =
level = domoticz.LOG_DEBUG,
marker = 'getColor',
execute = function(dz, item)
dz.utils.dumpTable(item.getColor() )
dz.log(item.name ..'; color = ' .. dz.utils.toJSON(item.getColor()),dz.LOG_DEBUG)
dz.log(item.name ..'; dimLevel = ' .. item.level,dz.LOG_DEBUG)
- Spoiler: show
gian72
Thanks for the quick reply. I will try it asap.
I've a modified aqaura gateway (https://github.com/cadavre/miio_gateway) and I'm trying to send, via mqtt the commands to change the colors. I've already achieved the on off (via node red), now I'm trying to change the color.
Do you kn ow a simpler way
Thank you!
Thank you!
- waaren
What is the mqtt command you are looking for?gian72 wrote: I've a modified aqaura gateway (https://github.com/cadavre/miio_gateway) and I'm trying to send, via mqtt the commands to change the colors. I've already achieved the on off (via node red), now I'm trying to change the color.
Do you know a simpler way?
Thank you!
gian72
return
on =
devices =
201, -- idx or 'name' of your RGBW device
logging =
comando = 'mosquitto_pub -h mqttserver -t /mihome/brightness -m ' ..item.level
os.execute(comando)
So what i'm trying right now is how to get the RGB value in a format like 'fffff' so I put it in a command like
comando = 'mosquitto_pub -h mqttserver -t /mihome/rgb -m ' ..item.SOMETHING
Gianluca
- waaren
Can you test this?gian72 wrote: Tuesday 25 August 2020 21:14 What i'm trying right now is how to get the RGB value in a format like 'fffff' so I put it in a command likeand to have the item.SOMETHING containing the rgb value.Code: Select all
return
on =
devices =
logging =
marker = 'sendColor',
local mqttServer = '192.168.192.116' -- Change to IP or name of your MQTT server
local color = item.getColor()
local function osCommand(cmd)
dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
if commandOutput:find '::ERROR::' then -- something went wrong
dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_ERROR)
else -- all is fine!!
dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
local function toHex(...)
local hex = ''
for _, rgb in ipairs({...}) do
hex = hex .. string.format('%02X',rgb) -- use string.format('%02x',rgb) if you need lower case hex
return hex
local function createMQTT(server, topic, message)
return 'mosquitto_pub -h ' .. server .. ' -t ' .. topic ..' -m ' .. message
osCommand( createMQTT( mqttServer, '/mihome/brighness', item.level ) )
osCommand( createMQTT( mqttServer, '/mihome/rgb', toHex(color.r, color.g, color.b ) ) )
}Debian buster, bullseye on RPI-4, Intel NUC.
gian72
Re: RGB Color from Dimmer [Solved]
Works great!
The functions toHex and osCommand opened my mind on how dzVents is working
Thanks so much for the solution!
Gianluca
Gianluca
