Philips hue dimmer switch  [Solved]
kroonp
Post by kroonp »
I am looking for a way to use the hue dimmer / switch in dzvents. Until now nothing can be found. There are 4 buttons that can be pressed short and long. I have not been able to find how to use this in dzVents. Is there anyone who has information about it.
Thankx,
Peter
Re: Philips hue dimmer switch
kroonp wrote: Thursday 06 August 2020 15:17 I am looking for a way to use the hue dimmer / switch in dzvents. Until now nothing can be found. There are 4 buttons that can be pressed short and long. I have not been able to find how to use this in dzVents. Is there anyone who has information about it.
Thankx,
Peter
This Hue device was implemented in domoticz in version V.11454 as a selector switch with 9 levels. (see below)
NB. Depending on the set poll interval for the Hue hardware module in domoticz there can be delay between pressing the button and the event triggered.
Hue twilight.png (31.36 KiB) Viewed 2953 times
A dzVents script to make use of the selector could look like
return
    on =
        devices =
            'Hue twilight', -- change to name of your Hue selector / dimmerswitch
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Hue dimmer / selector',
    execute = function(dz, item)
        dz.log('Device ' .. item.name .. ' updated. Last level was ' .. item.lastLevel .. '; new level is ' .. item.level .. ' (' .. item.levelName .. ')', dz.LOG_DEBUG)
        actions =
            ['Button 1 long'] = function() return '1L'  end,
            ['Button 2 long'] = function() return '2L'  end,
            ['Button 3 long'] = function() return '3L' end,
            ['Button 4 long'] = function() return '4L' end,
            ['Button 1 short'] = function() return '1S' end,
            ['Button 2 short'] = function() return '2S' end,
            ['Button 3 short'] = function() return '3S' end,
            ['Button 4 short'] = function() return '4S' end,
            ['Off'] = function() return 'Off' end,
        dz.log('Short name for ' .. item.levelName .. ' ==>> ' .. actions[item.levelName](),LOG_DEBUG)
kroonp
Post by kroonp »
Thank you for the reply. Unfortunately I do not yet understand how I can switch on a device with for example -button1 short-. But that is due to my inconsideration. I keep trying.
kroonp wrote: Friday 07 August 2020 0:40 Thank you for the reply. Unfortunately I do not yet understand how I can switch on a device with for example -button1 short-. But that is due to my inconsideration. I keep trying.
Hope this will help you understand
return
    on =
        devices =
    logging =
        deviceToSwitch = dz.devices('testDevice') -- change to name of device to switch when button 1 is pressed short
        actions =
        if item.levelName == 'Button 1 short' then
            deviceToSwitch.switchOn()
kroonp
Re: Philips hue dimmer switch  [Solved]
Post by kroonp »
Thank you very much, I get it now. I have adjusted my script and it now works the way I intended it to. Thanks again and have a nice weekend.
Obelix
Post by Obelix »
Is there also a possibility to use the switch for 'dynamic' dimming like the Hue dimmer switch can do using the Hue AP?
So press and hold button 2 to have dynamic brighter light?
Now I can also press longer to add a delta to the status.
I would like dynamic dimm + and -.
Is that possible?
Obelix wrote: Tuesday 06 April 2021 13:46 I would like dynamic dimm + and -.
Is that possible?
I don't think this is possible other then with native Hue hub.
Obelix
Post by Obelix »
That's too bad,
thanks!
