Four water tanks
Vikin
Four water tanks
Post by Vikin »
Hello
I have one water pump, four valves, and four water level switch (XKC-Y25) in four tanks.
How to replenish the tanks one by one at a specific time?
Thanks for your idea.
psubiaco
Re: Four water tanks
Post by psubiaco »
Hi.
You have to make a blocky or LUA script that chek the water level switches and control the valves and water pump.
I believe it's easy, if you know a little bit of programming.
In my signature below you can find a link for some scripts. There is also a schema to measure water tank level by a waterproof ultrasonic sensor.
Good luck.
Paolo
Dave21w
Domoticz version: Stable
Post by Dave21w »
do you intend on keeping the 4 tanks permanently full? if not then you need an upper and lower level switch otherwise the instant the tank level drops by an inch the pump will cut in.
HvdW
Domoticz version: 2023.2
Post by HvdW »
Hey @psubiaco, nice those scripts!
Bugs bug me.
