Hello
I have one water pump, four valves, and four water level switch (XKC-Y25) in four tanks.
How to replenish the tanks one by one at a specific time?
Thanks for your idea.
Four water tanks
- psubiaco
Re: Four water tanks
Hi.
You have to make a blocky or LUA script that chek the water level switches and control the valves and water pump.
I believe it's easy, if you know a little bit of programming.
In my signature below you can find a link for some scripts. There is also a schema to measure water tank level by a waterproof ultrasonic sensor.
Good luck.
Good luck.
Paolo
Dave21w
- Domoticz version: Stable
do you intend on keeping the 4 tanks permanently full? if not then you need an upper and lower level switch otherwise the instant the tank level drops by an inch the pump will cut in.
