Page 1 of 2
Dashticz 3.5.2 Beta
Posted: Wednesday 08 July 2020 20:53
by Lokonli
Dashticz 3.5.2 beta is a small update containing the following changes:
Enhancements
- New colorpicker for RGB devices, including support for whites. See :ref:`colorpicker`
Fixes
- Fix for Omrin garbage provider
- Fix for Venlo garbage provider
With the new RGB colorpicker you can switch between white modus and RGB modus and select the white color temperature for RGB dimmers that support this.
- cprgbwwz.jpg (42.99 KiB) Viewed 2976 times
In the current implementation the Domoticz behavior is reproduced. Configuration of the colorpicker currently is limited: Let me know which functionality you like to be added.
You can select the colorpicker with the following block parameter per device:
colorpicker:0, to show a block without colorpicker
colorpicker:1, to use the old colorpicker
colorpicker:2, to use the new colorpicker
By adding the following parameter to CONFIG.js you set the new colorpicker as default for all devices:
For documentation see:
https://dashticz.readthedocs.io/en/beta ... notes.html
Re: Dashticz 3.5.2 Beta
Posted: Friday 10 July 2020 15:13
by ksacca
I really like the new colorpicker, so couldn't wait to try it. When I enable the new colorpicker as a config paramter, it works for the first rgb block, but all blocks after that one do not load (not only rgb ones, but all blocks refuse to load). If I only add the new colorpicker for my second rgb device, then all blocks load until that one.
This is what I see in the console:
SyntaxError: Unexpected end of JSON input
at JSON.parse (<anonymous>)
at new Colorpicker (js/colorpicker.js:50)
at addColorpicker (js/switches.js:483)
at getDimmerBlock (js/switches.js:438)
at handleDevice (js/blocks.js:1355)
at deviceUpdateHandler (js/blocks.js:174)
at js/blocks.js:226
at ListObservable.subscribe (js/domoticz-api.js:529)
at Object.subscribe (js/domoticz-api.js:450)
at addDeviceUpdateHandler (js/blocks.js:224)
(anonymous) @ js/main.js:293
mightThrow @ bundle.js?t=4:303
Q @ bundle.js?t=4:303
The devices are of type: Color Switch, subtype RGB. f I set colorpicker to 1, everything works as expected, but with the old colorpicker of course. Did anyone else try the new colorpicker yet?
Posted: Friday 10 July 2020 16:53
by Lokonli
Could you post the Domoticz json output of your RGB device?
http://<domoticz ip:port>/json.htm?type=devices&rid=123
Instead of 123 fill in your own Domoticz device id.
Posted: Friday 10 July 2020 17:02
by Lokonli
and latest beta might fix this already ...
Posted: Friday 10 July 2020 17:07
by ksacca
It is indeed fixed in the latest beta. Thanks for that! I will test the colorpicker later today, but it looks great already!
Here's the output for one of my RGB devices (but this is probably not needed anymore). It is a tuya rgb controller flashed with tasmota, added with the MQTT-discovery plugin.
"ActTime" : 1594393376,
"AstrTwilightEnd" : "00:00",
"AstrTwilightStart" : "00:00",
"CivTwilightEnd" : "22:39",
"CivTwilightStart" : "04:56",
"DayLength" : "16:14",
"NautTwilightEnd" : "23:43",
"NautTwilightStart" : "03:52",
"ServerTime" : "2020-07-10 17:02:56",
"SunAtSouth" : "13:48",
"Sunrise" : "05:41",
"Sunset" : "21:55",
"app_version" : "2020.2 (build 12211)",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Color" : "",
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"DimmerType" : "abs",
"Favorite" : 0,
"HardwareID" : 18,
"HardwareName" : "Sonoff",
"HardwareType" : "MQTT discovery",
"HardwareTypeVal" : 94,
"HaveDimmer" : true,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "00120003",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2020-07-10 14:55:16",
"Level" : 99,
"LevelInt" : 99,
"MaxDimLevel" : 100,
"Name" : "LED TV",
"Notifications" : "false",
"PlanID" : "10",
"PlanIDs" :
10
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RGB",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Color Switch",
"TypeImg" : "dimmer",
"Unit" : 3,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "526"
"status" : "OK",
"title" : "Devices"
Posted: Friday 10 July 2020 17:11
by Lokonli
The "Color" field in your device was empty. This was not handled correctly by the new colorpicker, which has been fixed in latest beta.
Posted: Friday 10 July 2020 18:28
by ksacca
Hi Lokonli. The way the MQTT discovery works doesn't seem to be storing the color information (whatever I do). That also explains why I never had a correct color preview with the color picker (previously it was always black, now always white). I changed the way my led strips are integrated in domoticz (directly instead of MQTT discovery) and now everyhting works as it should. Thanks for pointing in the right direction. How can I buy you a beer
Posted: Friday 10 July 2020 20:16
by HansieNL
Thanks for the new colorpicker.
Because I wanted just only a triangle in front of the slider I had to change it by css:
/* RGB Lights - Colorpicker */
.rgbholder,
.cpholder {
flex: 0 0 20px !important;
.sp-replacer,
.sp-light {
border: 0px;
background-color: rgba(0,0,0,0.0);
.sp-dd {
font-size: 16px;
padding-top: 3px;
[class*="block_light_"].off .sp-dd {
color: rgba(255,255,255,0.4);
[class*="block_light_"].on .sp-dd {
color: rgba(255,255,255,1.0);
.sp-preview {
display: none;
Posted: Monday 13 July 2020 21:49
by HansieNL
The new default colorpicker settings can be set via the Dashticz settings menu in latest beta. The 'no_rgb' setting is absolete.
Posted: Tuesday 28 July 2020 10:25
by Brinkie
I have an issue with the dials. Since the latest update the font is a lot bigger.
Any suggestions to solve that?
Posted: Tuesday 28 July 2020 20:10
by madpatrick
Brinkie wrote: Tuesday 28 July 2020 10:25
Try this is your custom.css
.graphbuttons {
display: none;
font-size:10px;
Posted: Wednesday 29 July 2020 9:25
by Brinkie
Thanks for your reply madpatrick!
It didn't work for the dials (switches), but works only for the buttons in the graphs.
Posted: Thursday 30 July 2020 10:58
by Brinkie
After a complete reboot of the NAS, the dials are back to normal.
Posted: Thursday 30 July 2020 16:02
by Vomera
Hi! Can you plesae update the fontawsome to 5.14.0 ? I wanted to make a corona dashboard and there are some icons that are added in the 5.14.0 but 5.13.0 is installed. Tried to manually update the svg files, but would not help, file names are coded.
Posted: Wednesday 05 August 2020 18:38
by Lokonli
Vomera wrote: Thursday 30 July 2020 16:02
FontAwesome 5.13 and higher don't work on Internet Explorer 11.
I didn't find a way to fix this. Anyone ideas?
It seems to work on Chrome, Edge, etc.
Shall we drop support for IE11?
Posted: Wednesday 05 August 2020 18:48
by clinkadink
According to Font Awesome, 5.14 is supported on IE11. Where did you see this?
https://fontawesome.com/how-to-use/on-t ... er-support
Posted: Wednesday 05 August 2020 18:50
by clinkadink
Is this still an issue? If so, please post you block from CONFIG.js. Also, please let me know which beta you are on, and check if there is any custom.css that may be interferring.
Posted: Wednesday 05 August 2020 20:14
by Lokonli
For Dashticz with FA 5.14 on IE11 half the icons disappear. It was the same issue as with FA 5.13 which we tried in the past.
See:
https://github.com/Dashticz/dashticz/pull/473
Posted: Wednesday 05 August 2020 20:24
by clinkadink
Posted: Wednesday 05 August 2020 20:28
by Lokonli
Font download is enabled already
