Dashticz 3.5.2 Beta
Lokonli
Dashticz 3.5.2 Beta
Post by Lokonli »
Dashticz 3.5.2 beta is a small update containing the following changes:
Enhancements
  • New colorpicker for RGB devices, including support for whites. See :ref:`colorpicker`
Fixes
  • Fix for Omrin garbage provider
  • Fix for Venlo garbage provider
With the new RGB colorpicker you can switch between white modus and RGB modus and select the white color temperature for RGB dimmers that support this.
In the current implementation the Domoticz behavior is reproduced. Configuration of the colorpicker currently is limited: Let me know which functionality you like to be added.
You can select the colorpicker with the following block parameter per device:
colorpicker:0, to show a block without colorpicker
colorpicker:1, to use the old colorpicker
colorpicker:2, to use the new colorpicker
By adding the following parameter to CONFIG.js you set the new colorpicker as default for all devices:
config['colorpicker'] =2
For documentation see:
https://dashticz.readthedocs.io/en/beta ... notes.html
ksacca
Re: Dashticz 3.5.2 Beta
Post by ksacca »
I really like the new colorpicker, so couldn't wait to try it. When I enable the new colorpicker as a config paramter, it works for the first rgb block, but all blocks after that one do not load (not only rgb ones, but all blocks refuse to load). If I only add the new colorpicker for my second rgb device, then all blocks load until that one.
This is what I see in the console:
SyntaxError: Unexpected end of JSON input
    at JSON.parse (<anonymous>)
    at new Colorpicker (js/colorpicker.js:50)
    at addColorpicker (js/switches.js:483)
    at getDimmerBlock (js/switches.js:438)
    at handleDevice (js/blocks.js:1355)
    at deviceUpdateHandler (js/blocks.js:174)
    at js/blocks.js:226
    at ListObservable.subscribe (js/domoticz-api.js:529)
    at Object.subscribe (js/domoticz-api.js:450)
    at addDeviceUpdateHandler (js/blocks.js:224)
(anonymous) @ js/main.js:293
mightThrow @ bundle.js?t=4:303
Q @ bundle.js?t=4:303
The devices are of type: Color Switch, subtype RGB. f I set colorpicker to 1, everything works as expected, but with the old colorpicker of course. Did anyone else try the new colorpicker yet?
Lokonli
Post by Lokonli »
Could you post the Domoticz json output of your RGB device?
http://<domoticz ip:port>/json.htm?type=devices&rid=123
Instead of 123 fill in your own Domoticz device id.
Lokonli
Post by Lokonli »
and latest beta might fix this already ...
ksacca
Post by ksacca »
It is indeed fixed in the latest beta. Thanks for that! I will test the colorpicker later today, but it looks great already!
Here's the output for one of my RGB devices (but this is probably not needed anymore). It is a tuya rgb controller flashed with tasmota, added with the MQTT-discovery plugin.
	"ActTime" : 1594393376,
	"AstrTwilightEnd" : "00:00",
	"AstrTwilightStart" : "00:00",
	"CivTwilightEnd" : "22:39",
	"CivTwilightStart" : "04:56",
	"DayLength" : "16:14",
	"NautTwilightEnd" : "23:43",
	"NautTwilightStart" : "03:52",
	"ServerTime" : "2020-07-10 17:02:56",
	"SunAtSouth" : "13:48",
	"Sunrise" : "05:41",
	"Sunset" : "21:55",
	"app_version" : "2020.2 (build 12211)",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"Color" : "",
			"CustomImage" : 0,
			"Data" : "Off",
			"Description" : "",
			"DimmerType" : "abs",
			"Favorite" : 0,
			"HardwareID" : 18,
			"HardwareName" : "Sonoff",
			"HardwareType" : "MQTT discovery",
			"HardwareTypeVal" : 94,
			"HaveDimmer" : true,
			"HaveGroupCmd" : false,
			"HaveTimeout" : false,
			"ID" : "00120003",
			"Image" : "Light",
			"IsSubDevice" : false,
			"LastUpdate" : "2020-07-10 14:55:16",
			"Level" : 99,
			"LevelInt" : 99,
			"MaxDimLevel" : 100,
			"Name" : "LED TV",
			"Notifications" : "false",
			"PlanID" : "10",
			"PlanIDs" :
				10
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"Status" : "Off",
			"StrParam1" : "",
			"StrParam2" : "",
			"SubType" : "RGB",
			"SwitchType" : "Dimmer",
			"SwitchTypeVal" : 7,
			"Timers" : "false",
			"Type" : "Color Switch",
			"TypeImg" : "dimmer",
			"Unit" : 3,
			"Used" : 1,
			"UsedByCamera" : false,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "526"
	"status" : "OK",
	"title" : "Devices"
Lokonli
Post by Lokonli »
The "Color" field in your device was empty. This was not handled correctly by the new colorpicker, which has been fixed in latest beta.
ksacca
Post by ksacca »
Hi Lokonli. The way the MQTT discovery works doesn't seem to be storing the color information (whatever I do). That also explains why I never had a correct color preview with the color picker (previously it was always black, now always white). I changed the way my led strips are integrated in domoticz (directly instead of MQTT discovery) and now everyhting works as it should. Thanks for pointing in the right direction. How can I buy you a beer :D .
HansieNL
Post by HansieNL »
Thanks for the new colorpicker.
Because I wanted just only a triangle in front of the slider I had to change it by css:
/* RGB Lights - Colorpicker */
.rgbholder,
.cpholder {
	flex: 0 0 20px !important;
.sp-replacer,
.sp-light {
	border: 0px;
	background-color: rgba(0,0,0,0.0);
.sp-dd {
	font-size: 16px;
	padding-top: 3px;
[class*="block_light_"].off .sp-dd {
	color: rgba(255,255,255,0.4);
[class*="block_light_"].on .sp-dd {
	color: rgba(255,255,255,1.0);
.sp-preview {
	display: none;
Blah blah blah
HansieNL
Post by HansieNL »
The new default colorpicker settings can be set via the Dashticz settings menu in latest beta. The 'no_rgb' setting is absolete.
Blah blah blah
Brinkie
Domoticz version: 2020.1
Post by Brinkie »
I have an issue with the dials. Since the latest update the font is a lot bigger.
Any suggestions to solve that?
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Brinkie wrote: Tuesday 28 July 2020 10:25 I have an issue with the dials. Since the latest update the font is a lot bigger.
Try this is your custom.css
.graphbuttons {
display: none;
font-size:10px;
Brinkie
Post by Brinkie »
Thanks for your reply madpatrick!
It didn't work for the dials (switches), but works only for the buttons in the graphs.
Brinkie
Post by Brinkie »
After a complete reboot of the NAS, the dials are back to normal. :shock:
Vomera
Post by Vomera »
Hi! Can you plesae update the fontawsome to 5.14.0 ? I wanted to make a corona dashboard and there are some icons that are added in the 5.14.0 but 5.13.0 is installed. Tried to manually update the svg files, but would not help, file names are coded. :)
Lokonli
Post by Lokonli »
Vomera wrote: Thursday 30 July 2020 16:02 Hi! Can you plesae update the fontawsome to 5.14.0 ? I wanted to make a corona dashboard and there are some icons that are added in the 5.14.0 but 5.13.0 is installed. Tried to manually update the svg files, but would not help, file names are coded. :)
FontAwesome 5.13 and higher don't work on Internet Explorer 11.
I didn't find a way to fix this. Anyone ideas?
It seems to work on Chrome, Edge, etc.
Shall we drop support for IE11?
clinkadink
Post by clinkadink »
According to Font Awesome, 5.14 is supported on IE11. Where did you see this?
https://fontawesome.com/how-to-use/on-t ... er-support
clinkadink
Is this still an issue? If so, please post you block from CONFIG.js. Also, please let me know which beta you are on, and check if there is any custom.css that may be interferring.
Lokonli
Post by Lokonli »
clinkadink wrote: Wednesday 05 August 2020 18:48 According to Font Awesome, 5.14 is supported on IE11. Where did you see this?
For Dashticz with FA 5.14 on IE11 half the icons disappear. It was the same issue as with FA 5.13 which we tried in the past.
See:
https://github.com/Dashticz/dashticz/pull/473
clinkadink
Lokonli wrote: Wednesday 05 August 2020 20:14
See:
Could this help?
https://github.com/FortAwesome/Font-Awe ... -201043264
Lokonli
Post by Lokonli »
clinkadink wrote: Wednesday 05 August 2020 20:24
See:
Could this help?
Font download is enabled already
