make one script from two scripts  [Solved]
PatrickDV
Target OS: OS X
Post by PatrickDV »
I have two Qubino smart dimmers, type ZMNHDD1
This is connected to an double pulse Botton
How it works is when I pushed the second button, there will be an defined group switch on
when I pushed again it switch off.
To let this work I have one dzVents script and one Blockley.
the first script is an toggle script to switch on and off an dummy switch
The second is an blocky that when de dummy switch is on the group wil go on.
It would be nice to get one script that can switch on and off an group.
I tried something, but it won't work.
see the script en blocky below.
I hope someone can help me with this.
        devices = { 3722, 3736 }
    execute = function(dz, item)
        if item.active then
	    dz.devices('DM Thuiskomen').toggleSwitch()
}/code]
[attachment=0]Schermafbeelding 2020-07-05 om 21.18.52.png[/attachment]
Beste regards,
Patrick
Schermafbeelding 2020-07-05 om 21.18.52.png (30.08 KiB) Viewed 785 times
Re: make one script from two scripts
PatrickDV wrote: Sunday 05 July 2020 21:27 It would be nice to get one script that can switch on and off an group.
can you try this?
return
    on =
        devices = { 3722, 3736 },
        if item.active then
            thuiskomDevice = dz.devices('DM Thuiskomen')
            thuiskomGroup = dz.groups('Thuiskomen')
            if thuiskomDevice.state == 'On' then
                thuiskomGroup.switchOff()
                thuiskomGroup.switchOn()
            thuiskomDevice.toggleSwitch()
PatrickDV
Target OS: OS X
Re: make one script from two scripts  [Solved]
Post by PatrickDV »
Hello Waaren,
it is working, I changed it a little bit so I can remove the dummy switch DM Thuiskomen
Thanks for the help!
return
    on =
        if item.active then
            if thuiskomGroup.state == 'On' then
            thuiskomGroup.toggleSwitch()
