One script to match multiple devices Topic is solved
shketiev
Post by shketiev »
I have about 200 panic buttons connected to my domoticz with mysensors gateways. These are push buttons , but I added every button as a door contact , because of automatic release. I want to send notification when button is pressed and I can make it from notification section of every single one , but I want to make a script that matches all of them and send notifications when button is pressed , 1 script for all. I set the names for example: PANIC - 1 , PANIC - 2 , PANIC - 3 and so on ... And the script have to be something like:
if (devicechanged['PANIC ???something*'] == 'Closed') then
commandArray['SendNotification']='.. devicename button pressed'
Please anyone help with that.....
jvdz
Domoticz version: 4.107
Re: One script to match multiple devices
Post by jvdz »
Something like this?:
for dev, status in pairs(devicechanged) do
	-- Check Panicbutton pressed
	if (dev:sub(1, 6) == 'PANIC '] and status == 'Closed') then
		commandArray['SendNotification']= dev ..' button pressed'
Jos
shketiev
Post by shketiev »
jvdz wrote: Monday 15 June 2020 13:19 Something like this?:
Jos
Thank you very much ! Yes , exactly like this , but:
It returns error for some reason , Domoticz 2020.2
Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:4: ')' expected near ']'
jake
Post by jake »
Jos
Yes, because of the ] behind the word panic? Please remove.
shketiev
Post by shketiev »
I noticed that , and I actually see that I have posted previous error. After I remove ] after PANIC ' the error is on line 2.
Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:2: bad argument #1 to 'pairs' (table expected, got nil)
I don't why this error appears (every 60 seconds), but the script actually works and notifications is received correctly.
shketiev wrote: Tuesday 16 June 2020 11:08 Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:2: bad argument #1 to 'pairs' (table expected, got nil)
You should save the Lua script as triggered on Device. You now probably saved it to be triggered on 'All'
top right corner of the edit window..
shketiev
Post by shketiev »
waaren wrote: Tuesday 16 June 2020 11:57
YEAH , that works , no more errors. Thank you very much !
shketiev
Post by shketiev »
Just wondering , how can I add some limiting option for example:
If button is pressed , send notification , but once a minute , or every X time.
Now when someone press the button multiple times , it floods the system :(
Thanks !
shketiev wrote: Saturday 25 July 2020 15:36 If button is pressed , send notification , but once a minute , or every X time.
Could look like
    local function string2Epoch(dateString, pattern)
        local pattern = pattern or '(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)'
        local year, month, day, hour, minute, seconds = dateString:match(pattern)
        return os.time({year = year, month = month, day = day , hour = hour, min = minute, sec = seconds })
        if dev:sub(1, 5) == 'PANIC' and status == 'Closed' then
            local secondsAgo = os.time() - string2Epoch(otherdevices_lastupdate[dev])
            if secondsAgo > 60 then
                commandArray['SendNotification']= dev ..' button was pressed before ' .. secondsAgo .. ' seconds Ago'
                 print('No notification send. Last update of ' .. dev .. ' was ' .. secondsAgo .. ' seconds Ago')
            -- commandArray[#commandArray+1] = {[dev] = 'Open NOTRIGGER'} -- Don't know if this is needed and if so it works. Just try after confirming the other part does work
