One script to match multiple devices Topic is solved
I have about 200 panic buttons connected to my domoticz with mysensors gateways. These are push buttons , but I added every button as a door contact , because of automatic release. I want to send notification when button is pressed and I can make it from notification section of every single one , but I want to make a script that matches all of them and send notifications when button is pressed , 1 script for all. I set the names for example: PANIC - 1 , PANIC - 2 , PANIC - 3 and so on ... And the script have to be something like:
if (devicechanged['PANIC ???something*'] == 'Closed') then
commandArray['SendNotification']='.. devicename button pressed'
Please anyone help with that.....
- jvdz
- Domoticz version: 4.107
Re: One script to match multiple devices
Something like this?:
Jos
for dev, status in pairs(devicechanged) do
-- Check Panicbutton pressed
if (dev:sub(1, 6) == 'PANIC '] and status == 'Closed') then
commandArray['SendNotification']= dev ..' button pressed'
return commandArrayRe: One script to match multiple devices
Thank you very much ! Yes , exactly like this , but:jvdz wrote: Monday 15 June 2020 13:19 Something like this?:JosCode: Select all
commandArray = {} for dev, status in pairs(devicechanged) do -- Check Panicbutton pressed if (dev:sub(1, 6) == 'PANIC '] and status == 'Closed') then commandArray['SendNotification']= dev ..' button pressed' end end return commandArray
It returns error for some reason , Domoticz 2020.2
Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:4: ')' expected near ']'
jake
Yes, because of the ] behind the word panic? Please remove.shketiev wrote:Thank you very much ! Yes , exactly like this , but:jvdz wrote: Monday 15 June 2020 13:19 Something like this?:JosCode: Select all
I noticed that , and I actually see that I have posted previous error. After I remove ] after PANIC ' the error is on line 2.
Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:2: bad argument #1 to 'pairs' (table expected, got nil)
I don't why this error appears (every 60 seconds), but the script actually works and notifications is received correctly.
- waaren
You should save the Lua script as triggered on Device. You now probably saved it to be triggered on 'All'shketiev wrote: Tuesday 16 June 2020 11:08 Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:2: bad argument #1 to 'pairs' (table expected, got nil)
top right corner of the edit window..
YEAH , that works , no more errors. Thank you very much !waaren wrote: Tuesday 16 June 2020 11:57You should save the Lua script as triggered on Device. You now probably saved it to be triggered on 'All'shketiev wrote: Tuesday 16 June 2020 11:08 Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:2: bad argument #1 to 'pairs' (table expected, got nil)
Just wondering , how can I add some limiting option for example:
If button is pressed , send notification , but once a minute , or every X time.
Now when someone press the button multiple times , it floods the system
Thanks !
Thanks !
- waaren
Could look likeshketiev wrote: Saturday 25 July 2020 15:36 If button is pressed , send notification , but once a minute , or every X time.
Now when someone press the button multiple times , it floods the system![]()
local function string2Epoch(dateString, pattern)
local pattern = pattern or '(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)'
local year, month, day, hour, minute, seconds = dateString:match(pattern)
return os.time({year = year, month = month, day = day , hour = hour, min = minute, sec = seconds })
if dev:sub(1, 5) == 'PANIC' and status == 'Closed' then
local secondsAgo = os.time() - string2Epoch(otherdevices_lastupdate[dev])
if secondsAgo > 60 then
commandArray['SendNotification']= dev ..' button was pressed before ' .. secondsAgo .. ' seconds Ago'
print('No notification send. Last update of ' .. dev .. ' was ' .. secondsAgo .. ' seconds Ago')
-- commandArray[#commandArray+1] = {[dev] = 'Open NOTRIGGER'} -- Don't know if this is needed and if so it works. Just try after confirming the other part does work
