Read-out Batrium BMS
Posted: Thursday 11 June 2020 22:13
by Knibor
Hi, is it possible to read-out a Battery Management System with a UDP Outbound protocol in Domoticz
If yes, how to do it?
- Batrium.png (397.05 KiB) Viewed 1932 times
Re: Read-out Batrium BMS
Posted: Thursday 11 June 2020 23:02
by FireWizard
HI,
@Knibor
I think, that it is possible, as I see in System Op status MqttOffline =9.
This means that this unit may have MQTT available.
In that case with a MQTT server, such as Mosquitto and Node Red, it will not be too difficult.
Can you sort out the MQTT part?
[Added] I'm pretty sure . See:
https://github.com/Batrium/WatchMonUdpListener
Posted: Friday 12 June 2020 8:32
by Knibor
Hi FireWizard,
Thanks for the response
I'm not familiar with the MQQT. But if I'm right, WatchMon UDP Binary Listener translates to JSON and stores to influxdb or sends it to MQTT . So I need a separate server, e.g. Rasp Pi, which I connect to the wifi from Batrium BMS on which WatchMon UDP Binary Listener runs.
And from Domoticz I connect to the Rasp Pi server MQQT. Doesn't Domoticz have a UDP listerner plugin that can do this? Then it is probably possible to communicate directly with the Batrium from Domticz.
Kind Regards
Posted: Friday 12 June 2020 8:51
by waaren
Knibor wrote: Friday 12 June 2020 8:32
... Is it not possible to do this directly with Domoticz. The Batrium Windows program does a request of a measured value directly by wifi from the Batrium BMS and presents this in the Batrium windows program. Would this not be possible with a direct http Json request in Domoticz?
If the values can be retrieved using a JSON via HTTP Get then dzVents can collect it and update virtual sensors with the information.
Posted: Friday 12 June 2020 9:07
by Knibor
I don't know if the values can retrieve using a JSON.
The only thing I have is the UDP outbound protocol.
A few months ago I experimented with an ESP WEMO D1 wifi, with a JSON Command it was indeed possible to retrieve the measured values of the ESP to Domoticz. Now that I am experimenting with the Batrium BMS, I have found that this BMS uses an ESP32.
Posted: Friday 12 June 2020 10:55
by FireWizard
Have a look here:
https://www.npmjs.com/package/watchmonudplistener
From there you can make steps with either dzVents or Node Red.
