Read-out Batrium BMS
Knibor
Domoticz version: Stable
Post by Knibor »
Hi, is it possible to read-out a Battery Management System with a UDP Outbound protocol in Domoticz
If yes, how to do it?
FireWizard
Re: Read-out Batrium BMS
Post by FireWizard »
HI,
@Knibor
I think, that it is possible, as I see in System Op status MqttOffline =9.
This means that this unit may have MQTT available.
In that case with a MQTT server, such as Mosquitto and Node Red, it will not be too difficult.
Can you sort out the MQTT part?
[Added] I'm pretty sure . See:
https://github.com/Batrium/WatchMonUdpListener
Knibor
Post by Knibor »
Hi FireWizard,
Thanks for the response
I'm not familiar with the MQQT. But if I'm right, WatchMon UDP Binary Listener translates to JSON and stores to influxdb or sends it to MQTT . So I need a separate server, e.g. Rasp Pi, which I connect to the wifi from Batrium BMS on which WatchMon UDP Binary Listener runs.
And from Domoticz I connect to the Rasp Pi server MQQT. Doesn't Domoticz have a UDP listerner plugin that can do this? Then it is probably possible to communicate directly with the Batrium from Domticz.
Kind Regards
Knibor wrote: Friday 12 June 2020 8:32 ... Is it not possible to do this directly with Domoticz. The Batrium Windows program does a request of a measured value directly by wifi from the Batrium BMS and presents this in the Batrium windows program. Would this not be possible with a direct http Json request in Domoticz?
If the values can be retrieved using a JSON via HTTP Get then dzVents can collect it and update virtual sensors with the information.
Knibor
Post by Knibor »
I don't know if the values can retrieve using a JSON.
The only thing I have is the UDP outbound protocol.
A few months ago I experimented with an ESP WEMO D1 wifi, with a JSON Command it was indeed possible to retrieve the measured values of the ESP to Domoticz. Now that I am experimenting with the Batrium BMS, I have found that this BMS uses an ESP32.
FireWizard
Have a look here: https://www.npmjs.com/package/watchmonudplistener
From there you can make steps with either dzVents or Node Red.
