With an update of Domoticz all the custom made icons are disappeared.
Is it not possible to make an update/program that keep the existing custom made icons?
Why are custom made icons disappeared with an update of Domoticz?
- waaren
Re: Why are custom made icons disappeared with an update of Domoticz?
I too have some custom icons but I cannot replicate this behavior. Only the icons already included in the domoticz package are overwritten. My custom ones (for example the ones named MoonPhases*.png) are untouched when I update.McJohn wrote: Thursday 11 June 2020 9:54 With an update of Domoticz all the custom made icons are disappeared.
Can you describe in a bit more detail how you update and what you see.
McJohn
- Domoticz version: 2020.2
Thanks for the quick reply.
The custom made icons are into the directory:
/home/pi/domoticz/www/images
The last update from Domoticz 2020.2 (build 12067) to Domoticz 2020.2 (build 12154) (done with the WEB GUI),
vanished all the custom made icons
- waaren
Which icons (names) are no longer available ?McJohn wrote: Thursday 11 June 2020 10:30 The last update from Domoticz 2020.2 (build 12067) to Domoticz 2020.2 (build 12154) (done with the WEB GUI),
vanished all the custom made icons![]()
McJohn
We made for example some Beacon icons (Beacon.png). They are all gone after this update.
- FireWizard
HI,
I do not recognize this as well. Never seen this.
Running on the same build (12154), upgraded with the WebGUI
Both standard icons and custom icons are installed in the same directory, ~/domoticz/www/images.
All standard icons are owned by user pi and group pi, with rights 644, while the custom icons are owned by root:root, with rights 640.
McJohn
Thanks for your contribution.
I now see that the problem is not the icon files by themselves (they exist, sorry) but it was the switch_icons.txt file.
The (last) names of the custom made icons in this file were disappeared ..
after the update to
Raspbian Buster 10 Linux raspberrypi 4.19.118-v7+ #1311 (April version)
or the update to Domoticz build (12154).
"Rain;Rain;Rain" was suddenly the last (standard) text and after replacing the beacon text AND a restart of Domoticz, the beacons images were back again! (instead of the lamp).
There is really something strange going on with this April version of Buster.
See also
https://www.domoticz.com/forum/viewtopi ... 35#p250235
I'm going back asap to the January version.
Kind regards.
after the update to
See also
Kind regards.
AllesVanZelf
- Domoticz version: 12467
I do recognise this behaviour.
If I update Domoticz I have to backup switch_icons.txt in domoticz/www first, else this file is overwritten during update.
After the update I paste the extra (custom) line of icons into this file in again.
After a restart, the icons are back. But this is not how it should be in my opinion.
