Dashticz 3.5 Master
Lokonli
Dashticz 3.5 Master
Post by Lokonli »
Dashticz 3.5 Master has been released!
A lot of great changes have been implemented since the previous master release 3.3.3.1 4 months ago.
Dashticz 3.5 contains all changes from the beta releases.
Some highlights: Some smaller enhancements:
  • Inline images in news block
  • Improved security panel
Dashticz improvements
  • Websocket interface to receive instant device updates
  • Improved block handling (CSS class consistency, customizations via custom.js)
And a lot more small changes and bug fixes.
For the release notes see:
https://dashticz.readthedocs.io/en/mast ... index.html
Attention
There are a few breaking changes. Most importantly: Special thanks to @clinkadink for all the new block types, @HansieNL for maintaining the documentation, and @PietjePuck-132 for the alarmmeldingen.
And of course to all people who helped testing the beta releases.
Enjoy!
Krenstik
Re: Dashticz 3.5 Master
Post by Krenstik »
i really try how to fix empty titles, but can anyone help me? :-)
I´m using:
blocks[511] = { title: '',last_update: false
or
blocks['384_2'] = {}
blocks['384_2']['width'] = 2
blocks['384_2']['title'] = ''
blocks['384_2']['last_update'] = false
and from 3,5 master I get the following block:
Poznámka 2020-06-13 125759.jpg (30.23 KiB) Viewed 880 times
as an old one was:
Poznámka 2020-06-13 125837.jpg (33.35 KiB) Viewed 880 times
Any Idea how delete, or not use a title and get a value bigger?
Thank you very much in advance.
jaaap
Post by jaaap »
You can switch the title and value by adding the switch. See below
blocks['384_2']['switch'] = true
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Hi All,
Just newly installed Dashticz on my Raspberry Pi. So I am complete new to Dashticz. It looks great.
The doc is quite clear for the installation. A few questions.
What is the file where Dashticz makes it initial dashboard with devices from my Domoticz?
Why have a number of blocks the same name? See picture below? Can not find this in the doc.
Greetings McMelloW
Lokonli
Post by Lokonli »
The file 'custom/CONFIG.js' contains the Dashticz configuration. If not screens/columns have been defined in CONFIG.js then Dashticz will show all you Domoticz devices that are marked as Favorite.
The devices you see are the subdevices of a P1 smart meter. In general, if a Domoticz device contains several data items, like a P1 Smart Meter, or a TemperatureHumidityBarometer device, for each data element a block will be created.
If you only want to show a specific subdevice, for instance subindex 2 of device 34, then use the following key in CONFIG.js: '34_2'
For a temphumbar device it's possible to combine the data into a single block by setting the block parameter 'single_block' to true. (not yet documented ...)
McMelloW
Post by McMelloW »
@Lokonli
Thanks for your reply. i will dig into it further and play with it.
Greetings McMelloW
Glennesink
Post by Glennesink »
When using IDX with _x the last update will keep showing when false, and the width won't apply.
HansieNL
Post by HansieNL »
Glennesink wrote: Tuesday 16 June 2020 13:08 Hi,
Can you post the setting of that block and tell us what kind of block you are using?
Blah blah blah
jake
Post by jake »
jaaap wrote:You can switch the title and value by adding the switch. See below
I experience the same problem. Does that mean I have to add this switch to every block on my dashboard? I mean, it's a matter of starting and finishing the job, but why is this necessary all of a sudden? You want, for instance, to read the temperature, knowing the place of the block on the screen. Therefore the title text is not that important, but the sensor value is.
