Doorbell
edwin1234
Domoticz version: 2021.1
Doorbell
Post by edwin1234 »
How to ad the byron doorbell?
I have the byron protocol on and also ac arc x10 ligtning4 , but its not regonized by Domoticz
How to add it?
edwin1234
Re: Doorbell
Post by edwin1234 »
No one ?
FireWizard
Re: Doorbell
Post by FireWizard »
Hello Edwin,
@edwin1234
In order to get some advice's and/or support, I think you should submit more information.
Which Domoticz version?
Which software version in your RFXCom device (which device)?
Does you RFXCom device recognize your Doorbell?
Which type of Doorbell. Byron produces more than 1 type, and you can not expect that forum members are sorting that out, based on a picture of the push button. So,there exist no "the byron doorbell".
edwin1234
Re: Doorbell
Post by edwin1234 »
Ok
This is my domoticz version. 410717
This is rfxcom rfxtrx 433 version ext2/1025
On the back of the byron dby-21131
Hope this is enough information
Thanks for your help
FireWizard
Re: Doorbell
@edwin1234
From the RFXCom RFXtrx User guide, I found that the Byron BY chime is supported by software version Pro1 and ProXL1
If there are differences between BY chime and DBY chime, I don't know, but you can try it.
The Pro1 firmware is only available for RFXtrx433E (version 1043) For the ProXL1, you need the RFXtrx433XL.
For hardware RFXtrx433, the latest software is Type 1 (1025)
However, you mentioned that you use Ext2/1025 firmware. this is according to: http://www.rfxcom.com/epages/78165469.s ... /Downloads not available for RFXtrx433. but it is available for RFXtrx433E.
If it happens, that you have a RFXtrx433E, instead of RFXtrx433, you are lucky and you should upgrade to Pro1 (1043)
If not, you have to upgrade, your RFXCom device.
edwin1234
Re: Doorbell
Post by edwin1234 »
Thanks for your answer
Im gonna try it
edwin1234
Re: Doorbell
Post by edwin1234 »
I now have the firmware pro1 on it
Do i now have to do a auto detect or do i have to fill in something manually ?
FireWizard
Re: Doorbell
@edwin1234
I suppose, that it is sufficient to tick the box "Accept new Hardware Devices", or push "Allow for 5 Minutes" in the Setup > System tab.
If you have the correct protocols ticked in "Set Mode" of the RFXtrx433E device, I expect that if you press the push-button, the device is automatically detected.
Just try,
edwin1234
Re: Doorbell
Post by edwin1234 »
I tried I have the byron protocol on and also ac arc x10 ligtning4 But nothing shows in the log or devices
Is there another way?
FireWizard
Re: Doorbell
@edwin1234
I suggest that you contact the helpdesk of RFXCom and ask if your specific brand/model is supported. If it is, they can tell you also the settings.
edwin1234
Re: Doorbell
Post by edwin1234 »
Good idea
I will
