open multiple urls and combine results  [Solved]
raymond1972
Domoticz version: 2021.1
Post by raymond1972 »
Hi All,
I'm currently the happy owner of two solar systems which I already manage to read in domoticz.
Now I want to combine the reading in one dummy device.
In order to do that I was programming in dzvents to get the results of the CounterToday value of both the inverters.
see the attached script.
        timer = { 'every 1 minutes' },
        httpResponses = {
			'trigger' -- must match with the callback passed to the openURL command
        if (item.isTimer) then
            domoticz.openURL({
                url = 'http://xx.x.x.xxx:8080/json.htm?username=xxxxx=&password=xxxxx=&type=devices&rid=679',
                method = 'GET',
                callback = 'trigger',
        if (item.isHTTPResponse and item.ok) then
            local results = item.json.result
            -- loop through the nodes and print some info
            for i, node in pairs(results) do
                --local lastUpdate = Time(node.LastUpdate)
                --print(node.Name ..' vandaag opgeleverd: ' ..node.CounterToday)
                opbrengst1 = node.CounterToday
                opbr1 = opbrengst1.gsub(opbrengst1, "( kWh)", "", 1)
                opb1 = opbr1 + 0
                print('opb1 :'..opb1)
                results[i] = nil
            local results = nil
            domoticz.openURL({
                url = 'http://xx.x.x.xxx:8080/json.htm?username=xxxxx=&password=xxxxx=&type=devices&rid=680',
                method = 'GET',
            --local Time = require('Time')
                -- convert the time stamp in the raw data into a
                -- dzVents Time object
                local opbrengst2 = node.CounterToday
                opbr2 = opbrengst2.gsub(opbrengst2, "( kWh)", "", 1)
                opb2 = opbr2 + 0
                results[i] = nil
    print('opb1 :'..opb1 ..'&'..'opb2 :'..opb2)
    opbtot = opb1 + opb2
    print('Zonnepanelen opbrengst: ' ..opbtot)
When I debug this all went ok until the translation from string to number value.
the number value is printed twice!
2020-06-04 12:02:00.471 Status: EventSystem: Script event triggered: timer_script_new
2020-06-04 12:02:00.555 Status: dzVents: opb1 :2.183
2020-06-04 12:02:00.621 Status: dzVents: opb1 :1.626
Can anyone help me out to achieve:
Open url device 1 get value of CounterToday as number
Open url device 2 get value of CounterToday as number
calculate the combined new value of CounterToday
write value back to dummy device
Thanx in advance.
HW:Raspberry Pi 3 B, Raspian stretch, Nano, Aeon Labs Aeotec Gen 5 Z-Wave USB
Raspberry Pi 4, Raspian buster, Nano, Aeon Labs Aeotec Gen 5 Z-Wave USB
Re: open multiple urls and combine results
raymond1972 wrote: Thursday 04 June 2020 12:09 I'm currently the happy owner of two solar systems which I already manage to read in domoticz.
You most likely don't need the openURL's at all.
What are the device types and subtypes of the devices that you want to combine and what is the type / subtype of the coombined device?
(as seen on the devices tab)
raymond1972
Hi Waaren,
thank you for your quick response.
the types are:
680 Zonnepanelen Overkapping 00000001 1 Zonnepanelen overkapping General kWh 393.491 kWh
679 Zonnepanelen Woonhuis 00000001 1 Zonnepanelen woonhuis General kWh 15743.851 kWh
combined device:
731 Script device 00082731 1 Zonopbrengst General kWh 0, 5663.0
raymond1972 wrote: Thursday 04 June 2020 12:25 680 Zonnepanelen Overkapping 00000001 1 Zonnepanelen overkapping General kWh 393.491 kWh
Can you check this one?
Please note: The dayTotal will not be accurate on the first day.
return
    on =
        devices =
            'Zonnepanelen overkapping',
            'Zonnepanelen woonhuis',
    logging =
        level = domoticz.LOG_DEBUG,
    execute = function(dz, item)
        dz.log('Device ' .. item.name .. ' triggered this script', dz.LOG_DEBUG)
        local solarIn1 = dz.devices('Zonnepanelen overkapping')
        local solarIn2 = dz.devices('Zonnepanelen woonhuis')
        local solarOut = dz.devices('Zonopbrengst')
        local power   = solarIn1.WhActual + solarIn2.WhActual
        local energy  = solarIn1.WhTotal  + solarIn2.WhTotal
        solarOut.updateElectricity(power, energy)
The target device (731) must be set to receive the energy read from device (like below picture)
raymond1972
Hi Waaren,
That script sure looks a lot more simplified!
At this moment it does not update the virtual sensor.
script is added as dzvents-device
I notice two things:
1. the function refers to dz, instead of domoticz,
2. the values are in Wh instead of kWh
Do those things matter?
the virtual device is configured as follows:
Kind regards,
Raymond
Schermafbeelding 2020-06-04 om 13.45.39.png (28.66 KiB) Viewed 1937 times
raymond1972 wrote: Thursday 04 June 2020 13:45 At this moment it does not update the virtual sensor.
the script will trigger when one of the solar power devices are updated. So if the are updated every 10 seconds it will trigger every 10 seconds. If they are updated once per hour the script will trigger once per hour.
You can check the log to see if the script is triggered.
1. dz is here the name of first parm of the execute function. The name does not matter as long as the same name is used consistent in the execute function.
2. That is how it is coded. The translation to kWh is performed deeper in the domoticz code
raymond1972
Re: open multiple urls and combine results  [Solved]
Hi Waaren,
Thanx a lot.
I just corrected Zonnepanelen Overkapping -> Zonnepanelen overkapping and Zonnepanelen Woonhuis -> Zonnepanelen woonhuis in the script and now it's working.
Thanks for helping me out!
