Hue formula with openURL [Solved]
johnnyboy1984
Post by johnnyboy1984 »
Hi there,
I am trying to switch a formula (tv mimicking) on/off with a dummy switch.
I want when the dummy switch is switched on/off to start or stop the hue tv mimicking formula. Unfortunatly it doesn't work. I retrieved the api and code with the HUE clip api debugger and that works, but i don't know how to convert the code into a script, please help:
          devices = {
             'test1'
          if (switch.state == 'On') then
             domoticz.log('TV Mimick on')
                        domoticz.openURL({
                        url = 'http://<my hue ipadress>/api/<my api code>/sensors/55/state',
                        method = 'PUT',
                        put = { "status": 1 }
             domoticz.log('TV Mimick off!')
                        domoticz.openURL({
                        method = 'PUT',
                        put = { "status": 0 }
Last edited by johnnyboy1984 on Friday 05 June 2020 10:59, edited 1 time in total.
Re: Hue formula with openURL
johnnyboy1984 wrote: Thursday 04 June 2020 11:26 I retrieved the api and code with the HUE clip api debugger and that works, but i don't know how to convert the code into a script, please help:
From the wiki:
postData: Optional. When doing a POST, PUT 3.0.2 or DELETE 3.0.2 this data will be the payload of the request (body).
so try with:
          devices = {
             'test1'
                        domoticz.openURL({
                        method = 'PUT',
                        postData = { "status" = 1 }
                        domoticz.openURL({
                        method = 'PUT',
                        postData = { "status" = 0 }
If it still fails, please share the relevant loglines and the version you are on.
johnnyboy1984
still no succes, error log sais:
2020-06-04 11:55:26.006 Error: dzVents: Error: (3.0.1) error loading module 'Script Hue TV mimicking' from file '/usr/local/domoticz/var/scripts/dzVents/generated_scripts/Script Hue TV mimicking.lua':
 2020-06-04 11:55:26.006 ...ts/dzVents/generated_scripts/Script Hue TV mimicking.lua:14: '}' expected near ':'
i have dzVents Version: 3.0.1
johnnyboy1984 wrote: Thursday 04 June 2020 11:58 Still no succes
The methods PUT and DELETE are not available in dzVents version 3.0.1
These methods were introduced in Version 3.0.2
Also change "status" : 1 to "status" = 1
johnnyboy1984
ok, and dzVents 3.0.2 is in Domoticz 2020.2 right?
But that vesrsion is not available for Synology, is there another way with Lua maybe to achivef my goals?
johnnyboy1984 wrote: Thursday 04 June 2020 12:25 ok, and dzVents 3.0.2 is in Domoticz 2020.2 right?
But that version is not available for Synology, is there another way with Lua maybe to achieve my goals?
Not natively with dzVents or Lua but os.execute(CurlCommand) in a dzVents script could be a work around.
johnnyboy1984
ok, so i found this other https://www.domoticz.com/forum/viewtopi ... 36&t=31481, and used a part of the script, but still an error in my log:
          devices = {
             'test1'
             os.execute('curl --header "Content-Type: application/json"   --request PUT  --data '{"status":1}'   http://<my hue ipadress>/api/<my api code>/sensors/55/state')
             os.execute('curl --header "Content-Type: application/json"   --request PUT  --data '{"status":0}'   http://<my hue ipadress>/api/<my api code>/sensors/55/state')
log:
2020-06-04 13:52:58.977 Error: dzVents: Error: (3.0.1) error loading module 'Script Hue TV mimicking 2' from file '/usr/local/domoticz/var/scripts/dzVents/generated_scripts/Script Hue TV mimicking 2.lua':
2020-06-04 13:52:58.977 .../dzVents/generated_scripts/Script Hue TV mimicking 2.lua:11: ')' expected near '{'
johnnyboy1984 wrote: Thursday 04 June 2020 13:54 ok, so i found this other https://www.domoticz.com/forum/viewtopi ... 36&t=31481, and used a part of the script, but still an error in my log:
some quote problems..
Can you try:
return
    on =
        devices =
            'test1',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Curl to hue' ,
    execute = function(dz, switch)
        dz.log('TV Mimick ' .. switch.state, dz.LOG_DEBUG)
        local hueCommand = ( switch.state == 'On' and 1 ) or 0
        local curlCommand = 'curl --header "Content-Type: application/json"   --request PUT  --data \'{"status": '  .. hueCommand .. ' }\'   http://<Hue IP>/api/<API CODE>/sensors/55/state'
        os.execute(curlCommand)
        dz.log('curl Commnand: ' .. curlCommand, dz.LOG_DEBUG)
If it does not work yet just copy the command you see in the log and try it from the CLI.
curl will show you what's wrong.
johnnyboy1984
This works!!! Thanks a lot.
I removed the extra loggin now and can use it.
return
    on =
        devices =
            'test1',
        local curlCommand = 'curl --header "Content-Type: application/json"   --request PUT  --data \'{"status": '  .. hueCommand .. ' }\'   http://<my hue ipadress>/api/<my api code>/sensors/55/state'
