johnnyboy1984
Posts: 13 Joined: Thursday 14 March 2019 17:46
Post
by johnnyboy1984 » Thursday 04 June 2020 11:26
Hi there,
I am trying to switch a formula (tv mimicking) on/off with a dummy switch.
I want when the dummy switch is switched on/off to start or stop the hue tv mimicking formula. Unfortunatly it doesn't work. I retrieved the api and code with the HUE clip api debugger and that works, but i don't know how to convert the code into a script, please help:
devices = {
'test1'
execute = function(domoticz, switch)
if (switch.state == 'On') then
domoticz.log('TV Mimick on')
domoticz.openURL({
url = 'http://<my hue ipadress>/api/<my api code>/sensors/55/state',
method = 'PUT',
put = { "status": 1 }
domoticz.log('TV Mimick off!')
domoticz.openURL({
method = 'PUT',
put = { "status": 0 }
johnnyboy1984 on Friday 05 June 2020 10:59, edited 1 time in total.
Posts: 6028 Joined: Tuesday 03 January 2017 14:18
Post
by waaren » Thursday 04 June 2020 11:47
johnnyboy1984 wrote: Thursday 04 June 2020 11:26
From the wiki:
postData: Optional. When doing a POST, PUT 3.0.2 or DELETE 3.0.2 this data will be the payload of the request (body).
so try with:
devices = {
'test1'
domoticz.openURL({
method = 'PUT',
postData = { "status" = 1 }
domoticz.openURL({
method = 'PUT',
postData = { "status" = 0 }
If it still fails, please share the relevant loglines and the version you are on.
dzVents wiki
johnnyboy1984
Post
by johnnyboy1984 » Thursday 04 June 2020 11:58
still no succes, error log sais:
2020-06-04 11:55:26.006 Error: dzVents: Error: (3.0.1) error loading module 'Script Hue TV mimicking' from file '/usr/local/domoticz/var/scripts/dzVents/generated_scripts/Script Hue TV mimicking.lua':
2020-06-04 11:55:26.006 ...ts/dzVents/generated_scripts/Script Hue TV mimicking.lua:14: '}' expected near ':'
i have dzVents Version: 3.0.1
Post
by waaren » Thursday 04 June 2020 12:19
johnnyboy1984 wrote: Thursday 04 June 2020 11:58
Still no succes
The methods PUT and DELETE are not available in dzVents version 3.0.1
These methods were introduced in Version 3.0.2
Also change "status" : 1 to "status" = 1
dzVents wiki
johnnyboy1984
Post
by johnnyboy1984 » Thursday 04 June 2020 12:25
ok, and dzVents 3.0.2 is in Domoticz 2020.2 right?
But that vesrsion is not available for Synology, is there another way with Lua maybe to achivef my goals?
Post
by waaren » Thursday 04 June 2020 12:29
johnnyboy1984 wrote: Thursday 04 June 2020 12:25
But that version is not available for Synology, is there another way with Lua maybe to achieve my goals?
Not natively with dzVents or Lua but os.execute(CurlCommand) in a dzVents script could be a work around.
dzVents wiki
johnnyboy1984
Post
by johnnyboy1984 » Thursday 04 June 2020 13:54
ok, so i found this other
https://www.domoticz.com/forum/viewtopi ... 36&t=31481 , and used a part of the script, but still an error in my log:
devices = {
'test1'
os.execute('curl --header "Content-Type: application/json" --request PUT --data '{"status":1}' http://<my hue ipadress>/api/<my api code>/sensors/55/state')
os.execute('curl --header "Content-Type: application/json" --request PUT --data '{"status":0}' http://<my hue ipadress>/api/<my api code>/sensors/55/state')
log:
2020-06-04 13:52:58.977 Error: dzVents: Error: (3.0.1) error loading module 'Script Hue TV mimicking 2' from file '/usr/local/domoticz/var/scripts/dzVents/generated_scripts/Script Hue TV mimicking 2.lua':
2020-06-04 13:52:58.977 .../dzVents/generated_scripts/Script Hue TV mimicking 2.lua:11: ')' expected near '{'
Post
by waaren » Thursday 04 June 2020 14:25
johnnyboy1984 wrote: Thursday 04 June 2020 13:54
some quote problems..
Can you try:
return
on =
devices =
'test1',
logging =
level = domoticz.LOG_DEBUG,
marker = 'Curl to hue' ,
execute = function(dz, switch)
dz.log('TV Mimick ' .. switch.state, dz.LOG_DEBUG)
local hueCommand = ( switch.state == 'On' and 1 ) or 0
local curlCommand = 'curl --header "Content-Type: application/json" --request PUT --data \'{"status": ' .. hueCommand .. ' }\' http://<Hue IP>/api/<API CODE>/sensors/55/state'
os.execute(curlCommand)
dz.log('curl Commnand: ' .. curlCommand, dz.LOG_DEBUG)
If it does not work yet just copy the command you see in the log and try it from the CLI.
curl will show you what's wrong.
dzVents wiki
johnnyboy1984
Post
by johnnyboy1984 » Thursday 04 June 2020 14:42
This works!!! Thanks a lot.
I removed the extra loggin now and can use it.
return
on =
devices =
'test1',
local curlCommand = 'curl --header "Content-Type: application/json" --request PUT --data \'{"status": ' .. hueCommand .. ' }\' http://<my hue ipadress>/api/<my api code>/sensors/55/state'
