Searching a specific widget.
Thorgal789
Post by Thorgal789 »
Hello I m searching a widget to display on the same widget power and energy.
There is "Electric (Instant+Counter)" but this one use an incremental counter for energy, and I want to use my own value for energy and power.
I can retreiving the old value and make calcul to send the good value to have the correct value displayed for energy, but it's a little overkill.
FireWizard
Re: Searching a specific widget.
Post by FireWizard »
I think it is possible to use Electric (Instant and Counter)
From the Wiki:
Electricity (instant and counter)
/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=POWER;ENERGY
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
POWER = current power
ENERGY = cumulative energy in Watt-hours (Wh) This is an incrementing counter. (if you choose as type "Energy read : Computed", this is just a "dummy" counter, not updatable because it's the result of Domoticz calculations from POWER)
You can choose between "Computed" and "From device". You need the last one.
Thorgal789
But it's my problem, the device don't send periodic power for domoticz can compute it, but it calcule itself the value and send power + computed energy.
So I want to use the value send by the device.
