Page 1 of 2
Zigbee2mqtt network map
Posted: Sunday 05 April 2020 12:07
by ak97
Simple network map for zigbee2mqtt plugin using custom template page
https://github.com/kovainfo/Domoticz-zi ... etwork-map
- screenshot.png (309.14 KiB) Viewed 3194 times
Re: Zigbee2mqtt network map
Posted: Sunday 05 April 2020 13:04
by EddyG
Nice. I have to get a workaround because 2020.1 does not work for me (yet) because of Zwave problems.
Posted: Sunday 05 April 2020 13:10
by ak97
EddyG wrote: Sunday 05 April 2020 13:04
This solution should work on previous versions of Domoticz, but I did not check)
Posted: Sunday 05 April 2020 13:47
by Bigted
Domoticz 4.10717
I can see raw.json gets populated
However the custom panel under Zigbee is blank
Posted: Sunday 05 April 2020 13:54
by ak97
Bigted wrote: Sunday 05 April 2020 13:47
Domoticz 4.10717
Absolute paths are specified in the template and script. are they right?
Posted: Sunday 05 April 2020 14:01
by eleutscher
I did also the install and facing same problem as Bigted.
Posted: Sunday 05 April 2020 14:07
by ak97
What OS and platform for Domoticz you use?
Posted: Sunday 05 April 2020 14:11
by eleutscher
ak97 wrote: Sunday 05 April 2020 14:07
Domoticz v4.10935
Operating System: Raspbian GNU/Linux 9 (stretch)
Kernel: Linux 4.19.42-v7+
Posted: Sunday 05 April 2020 14:15
by ak97
Do you have a file:
/home/pi/domoticz/www/js/jquery-3.4.1.min.js
may be this file is missing in Domoticz less than v2020?
Posted: Sunday 05 April 2020 14:18
by eleutscher
ak97 wrote: Sunday 05 April 2020 14:15
Do you have a file:
I have this one
jquery-3.3.1.min.js
so the 3.4.1 is indeed missing
Posted: Sunday 05 April 2020 14:20
by ak97
ok! that's it!
try modify file in /templates/zigbeemap/zigbeemap.html
and change
<script type="text/javascript" src="/js/jquery-3.4.1.min.js"></script>
to:
<script type="text/javascript" src="/js/jquery-3.3.1.min.js"></script>
Posted: Sunday 05 April 2020 14:25
by eleutscher
ak97 wrote: Sunday 05 April 2020 14:20
ok! that's it!
and change
to:
Yep, I have images now! Great.
But.... I only see the orginal sensors. Your sensors. How do I get my sensors?
Posted: Sunday 05 April 2020 14:32
by ak97
1. Mosquitto clients are installed?
2. dzVents support is enabled in Domoticz?
3. you must create dzVents script from readme:
customEvents = {
'CreateZigbeeMap' -- event triggered by emitEvent
data = {},
logger = {},
execute = function(domoticz, triggeredItem)
function SendCommand()
cmd = "/home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh"
domoticz.utils.osExecute(cmd)
if (triggeredItem.isCustomEvent) then
domoticz.utils._.print(triggeredItem.data)
SendCommand()
Posted: Sunday 05 April 2020 14:36
by ak97
may be need add eXecute attribute for /home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh:
chmod +x /home/pi/domoticz/www/templates/zigbeemap/zigbeemap.sh
Posted: Sunday 05 April 2020 14:44
by Bigted
ok! that's it!
and change
to:
That solved the issue for me
Posted: Sunday 05 April 2020 14:51
by eleutscher
ak97 wrote: Sunday 05 April 2020 14:32
}[/code]
1. Yes
2. Yes
3. Maybe stupid question
Where should the file be located?
a. /home/pi/domoticz/scripts/dzVents/scripts or
b. /home/pi/domoticz/scripts/dzVents/generated_scripts
and what is the extension?
a. lua
b. dzvents
Thanks for your time/help
Posted: Sunday 05 April 2020 15:04
by ak97
eleutscher wrote: Sunday 05 April 2020 14:51
}[/code]
1. Yes
2. Yes
a. lua
b. dzvents
1. Open Domoticz web-interface
2. Setup -> More Options -> Events
3. Create dzVents envent
4. Copy&Paste content of script
Posted: Sunday 05 April 2020 18:50
by eleutscher
ak97 wrote: Sunday 05 April 2020 15:04
[/quote]
That is what I did. But still no luck. Could it be because ! am still on dzVents version: 2.4.24?
Posted: Sunday 05 April 2020 18:56
by ak97
eleutscher wrote: Sunday 05 April 2020 18:50
Here is what I found:
https://www.domoticz.com/wiki/Domoticz_ ... ents_3.0.0
Yes, dzVents must be a 3.0 and above
Maybe there is another way to call the script to create a network map, but I did not think about it. generating an event when opening a page is the easiest solution for me ...
Posted: Sunday 05 April 2020 19:13
by EddyG
ak97 wrote: Sunday 05 April 2020 13:10
I am on version 4.10717 and in that version CustomEvents where not implemented yet.
