Weather forecast: darksky.net refused to connect
Woody
Most recent stable build: 4.10717, Aurora theme, zero changes.
I have a darksky dev Secret Key for the API. darksky.net shows that the key is stil valid and I am well under my 1,000 requests a day.
I have a number of weather "devices" which are darksky and they work and update fine and there are no errors in the log file relating to any of them.
However, approx 4 days ago, when I select the forecast page (that has been working fine until now) http://xx.xx.xx.xx:8081/#/Forecast I simply get a page that says darksky.net refused to connect.
This is browser and client machine agnostic - so it is not something that has changed locally, and if I go to the dedicated darksky web page directly - https://darksky.net/forecast/xx.xx,xx,xx/ukxx/en the forecast page loads fine for my correct location.
There is no weird AV involved and while I have PiHole, it is not blocking - so does anyone have any bright ideas?
dobber
- Domoticz version: Beta..
Re: Weather forecast: darksky.net refused to connect
Same problem here. Running beta 11777Woody wrote: Friday 06 March 2020 20:40 Most recent stable build: 4.10717, Aurora theme, zero changes.
doh
Same here on beta 11775
- waaren
Seems like a Darksky policy change.Woody wrote: Friday 06 March 2020 20:40 However, approx 4 days ago, when I select the forecast page (that has been working fine until now) http://xx.xx.xx.xx:8081/#/Forecast I simply get a page that says darksky.net refused to connect.
The message I get (using the Edge browse on version V4.11665 (Synology test system ) )
All other Darksy stuf is working as before.This content cannot be displayed in a frame
There is content, but the publisher does not allow it to be displayed in a frame.
This will better protect the information you may enter on this site.
Try this
Open this in a new window
Report this problem
I think this is because Domoticz makes a call to the API over port 80 (HTTP) and not port 443 (HTTPS). When I curled:
curl http://api.darksky.net/forecast/api.key ... 4,-71.3329
{"code":400,"error":"this call requires HTTPS"}
Where do we change the API call from HTTP to HTTPS? It seems Darksky stopped answering HTTP requests.
Same issue here. Anyone have suggestions on how to fix?
Woody
Thanks - and really well spotted! I am hoping that @leecollings can tell us how to update the call to https.wizworks wrote: Tuesday 10 March 2020 4:02 I think this is because Domoticz makes a call to the API over port 80 (HTTP) and not port 443 (HTTPS). When I curled:
*bump* we need a fix, or at least someone to point out the script object to modify to allow Domoticz to call this API over HTTPS... please help.
dobber
Maybe try posting in the "Bugs and Problems" part of the forum? Or on github.wizworks wrote: Tuesday 17 March 2020 2:44 *bump* we need a fix, or at least someone to point out the script object to modify to allow Domoticz to call this API over HTTPS... please help.
dakarli
- Domoticz version: 2021.1
Same Problem here. I created an Issue on Github:
https://github.com/domoticz/domoticz/issues/4012
Br
Br
dakarli
User gizmocuz provided a temporally fix for this issue on Github:
https://github.com/domoticz/domoticz/co ... 19a2aecc3e
Br
Br
