Weather forecast: darksky.net refused to connect
Woody
Post by Woody »
Most recent stable build: 4.10717, Aurora theme, zero changes.
I have a darksky dev Secret Key for the API. darksky.net shows that the key is stil valid and I am well under my 1,000 requests a day.
I have a number of weather "devices" which are darksky and they work and update fine and there are no errors in the log file relating to any of them.
However, approx 4 days ago, when I select the forecast page (that has been working fine until now) http://xx.xx.xx.xx:8081/#/Forecast I simply get a page that says darksky.net refused to connect.
This is browser and client machine agnostic - so it is not something that has changed locally, and if I go to the dedicated darksky web page directly - https://darksky.net/forecast/xx.xx,xx,xx/ukxx/en the forecast page loads fine for my correct location.
There is no weird AV involved and while I have PiHole, it is not blocking - so does anyone have any bright ideas?
dobber
Domoticz version: Beta..
Re: Weather forecast: darksky.net refused to connect
Post by dobber »
Woody wrote: Friday 06 March 2020 20:40 Most recent stable build: 4.10717, Aurora theme, zero changes.
Same problem here. Running beta 11777
doh
Post by doh »
Same here on beta 11775
Woody wrote: Friday 06 March 2020 20:40 However, approx 4 days ago, when I select the forecast page (that has been working fine until now) http://xx.xx.xx.xx:8081/#/Forecast I simply get a page that says darksky.net refused to connect.
Seems like a Darksky policy change.
The message I get (using the Edge browse on version V4.11665 (Synology test system ) )
This content cannot be displayed in a frame
There is content, but the publisher does not allow it to be displayed in a frame.
This will better protect the information you may enter on this site.
Try this
Open this in a new window
Report this problem
All other Darksy stuf is working as before.
wizworks
Post by wizworks »
I think this is because Domoticz makes a call to the API over port 80 (HTTP) and not port 443 (HTTPS). When I curled:
curl http://api.darksky.net/forecast/api.key ... 4,-71.3329
{"code":400,"error":"this call requires HTTPS"}
Where do we change the API call from HTTP to HTTPS? It seems Darksky stopped answering HTTP requests.
jimm2
Post by jimm2 »
Same issue here. Anyone have suggestions on how to fix?
Woody
Post by Woody »
wizworks wrote: Tuesday 10 March 2020 4:02 I think this is because Domoticz makes a call to the API over port 80 (HTTP) and not port 443 (HTTPS). When I curled:
Thanks - and really well spotted! I am hoping that @leecollings can tell us how to update the call to https.
wizworks
Post by wizworks »
*bump* we need a fix, or at least someone to point out the script object to modify to allow Domoticz to call this API over HTTPS... please help.
dobber
Post by dobber »
wizworks wrote: Tuesday 17 March 2020 2:44 *bump* we need a fix, or at least someone to point out the script object to modify to allow Domoticz to call this API over HTTPS... please help.
Maybe try posting in the "Bugs and Problems" part of the forum? Or on github.
dakarli
Domoticz version: 2021.1
Post by dakarli »
Same Problem here. I created an Issue on Github:
https://github.com/domoticz/domoticz/issues/4012
Br
dakarli
Post by dakarli »
User gizmocuz provided a temporally fix for this issue on Github:
https://github.com/domoticz/domoticz/co ... 19a2aecc3e
Br
Woody
Post by Woody »
