Dimmer Light Daytime
djdevil
Domoticz version: 2021.1
Post by djdevil »
Inglese
Hi everyone I use this code to dim the lights according to the time and some switches, it works perfectly, only it sends the z-wave network in tilt by sending the same command twice both when I turn on the light and when off here is a log screen? is there any way to improve the code? thank you
return
   on =
      devices = { 'Studio'},
     logging =
       -- level = domoticz.LOG_DEBUG,
     --   marker = 'dim based on time'
   execute = function(dz, item)
        dz.log('Studio stato: ' .. item.state,dz.LOG_DEBUG)
        if item.active and item.lastUpdate.secondsAgo > 6 then
                if dz.time.matchesRule('at 06:30-15:00') then
                    item.dimTo(10).silent()
                if dz.time.matchesRule('at 15:00-17:00') then
                    item.dimTo(20).silent()
                if dz.time.matchesRule('at 17:00-21:30') then
                    item.dimTo(30).silent()
               if dz.time.matchesRule('at 21:30-22:30') then
                if dz.time.matchesRule('at 22:30-06:30') then
                if dz.devices('TV Studio').state == 'Paused' then
                     item.dimTo(1).silent()
                  if dz.devices('Ospiti').state == 'On' then
                 item.dimTo(80).silent()
                 if dz.devices('Modalità Notte').state == 'On' then
                 if dz.devices('Buonanotte').state == 'On' then
        elseif item.lastUpdate.secondsAgo > 6 then
            item.dimTo(0).silent()
Re: Dimmer Light Daytime
djdevil wrote: Saturday 08 February 2020 0:10 Inglese
Kind of hard to say without debug logging but can you try this ?
return
   on =
     logging =
            elseif dz.time.matchesRule('at 15:00-17:00') then
            elseif dz.time.matchesRule('at 17:00-21:30') then
            elseif dz.time.matchesRule('at 21:30-22:30') then
            elseif dz.time.matchesRule('at 22:30-06:30') then
            elseif dz.devices('TV Studio').state == 'Paused' then
            elseif dz.devices('Ospiti').state == 'On' then
            elseif dz.devices('Modalità Notte').state == 'On' then
            elseif dz.devices('Buonanotte').state == 'On' then
djdevil
Post by djdevil »
i try your code this is the log debug is correct?
 2020-02-08 18:59:31.064 Status: User: davide initiated a switch command (66/Studio/On)
2020-02-08 18:59:31.316 Status: dzVents: Info: dim based on time: ------ Start internal script: Dimmer Studio: Device: "Studio (Z-Wave)", Index: 66
2020-02-08 18:59:31.316 Status: dzVents: Debug: dim based on time: Studio stato: On
2020-02-08 18:59:31.316 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 30
2020-02-08 18:59:31.317 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 30 NOTRIGGER
2020-02-08 18:59:31.317 Status: dzVents: Info: dim based on time: ------ Finished Dimmer Studio
2020-02-08 18:59:31.575 Status: dzVents: Info: dim based on time: ------ Start internal script: Dimmer Studio: Device: "Studio (Z-Wave)", Index: 66
2020-02-08 18:59:31.575 Status: dzVents: Debug: dim based on time: Studio stato: On
2020-02-08 18:59:31.575 Status: dzVents: Info: dim based on time: ------ Finished Dimmer Studio
 2020-02-08 18:59:44.063 Status: User: davide initiated a switch command (66/Studio/Off)
2020-02-08 18:59:44.527 Status: dzVents: Info: dim based on time: ------ Start internal script: Dimmer Studio: Device: "Studio (Z-Wave)", Index: 66
2020-02-08 18:59:44.527 Status: dzVents: Debug: dim based on time: Studio stato: Off
2020-02-08 18:59:44.527 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 0
2020-02-08 18:59:44.527 Status: dzVents: Debug: dim based on time: Constructed timed-command: Set Level 0 NOTRIGGER
2020-02-08 18:59:44.527 Status: dzVents: Info: dim based on time: ------ Finished Dimmer Studio
zwave debug
 2020-02-08 18:59:31.065 OpenZWave: Domoticz has send a Switch command!, Level: 255, NodeID: 2 (0x02)
2020-02-08 18:59:31.338 OpenZWave: Domoticz has send a Switch command!, Level: 30, NodeID: 2 (0x02)
2020-02-08 18:59:44.064 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 2 (0x02)
2020-02-08 18:59:44.544 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 2 (0x02)
djdevil wrote: Saturday 08 February 2020 19:00 i try your code this is the log debug is correct?
Yes it is. I noticed this behavior before but dzVents is only sending the commands once so cannot be solved by changing dzVents code.
djdevil
Post by djdevil »
waaren wrote: Saturday 08 February 2020 20:20
Is a problem of zwave network?
djdevil wrote: Saturday 08 February 2020 20:22
I don't know what the root cause is but I have only seen this with Zwave devices.
djdevil
Post by djdevil »
waaren wrote: Saturday 08 February 2020 20:45
ok thanks for the reply, anyway advice to use the code with the addition of "else if"? how did you reserve it? It's more correct?
djdevil wrote: Sunday 09 February 2020 13:33 ok thanks for the reply, anyway advice to use the code with the addition of "else if"? how did you reserve it? It's more correct?
From what I see in your script I understand that the conditions are to be evaluated as mutual exclusive. In such a case the elseif should be used.
